jimmoscheck
Reged: 01/08/07
Loc: Under the SE Michigan lightdom...
I thought I read somewhere that the Paracorr is supposed to be placed in the Powermate/barlow,so the Powermate/barlow won't scratch the Paracorr lens??? Al
You are correct, sir, but I think it's to keep the same spacing between the EP and Paracorr and is only with the 2" 2X powermate or 2" barlow. Obviously, a 1.25" powermate/barlow would have to come after the Paracorr.
-------------------- Jim Moscheck
14.5" f4.3 home built Kriege stlye truss
Stevens primary
"A mind is like a parachute. It doesnt work if it's not open." - Frank Zappa
HellsKitchen
Reged: 09/05/08
Loc: Australia
Lash 'em up!
-------------------- S 38º 00' E 145º20'
Custom 12" F/4.6 dob
10" GSO dob
4.5" Meade Newtonian
Set of Vixen LVWs + TV barlows + powermates
Astronomik 0III, UHC, H-beta filters
HellsKitchen
Reged: 09/05/08
Loc: Australia
again...
10" GSO dob
csa/montana
Astro Ambassador
Reged: 05/14/05
Loc: montana
-------------------- Carol
AstroTech 16" Dob (Thanks ASTRONOMICS!)
AstroTech 66ED / Vixen 80MF/AstroTech Voyager
Masuyama's 7.5, 15, 25W, 35mm,
Tak LE 5mm B/TMB 3.2
7mm Pentax XL, 10mm Pentax XW
14mm Meade 4000 UWA
22mm Pan, 35mm Pan
DreamCatcher Dobservatory, #2
mazzefr
I'll take door number three...
Reged: 02/12/07
Loc: Behind the Wheel in PA
WOW! Whats the magnification on that stack?
-------------------- Franco
Orion XT12i w/ MoonLite
13T6, 9T6, Pan24
Scopos 35mm
Lumicon UHC, Baader M&S
DIY- Denver Chair, Light shields
"All that is necessary for the triumph of evil is that good men do nothing." (Edmund Burke)
Lehigh Valley, PA
Starman1
Vendor - Scope City
Reged: 06/24/03
Loc: Los Angeles
Some Poster in another thread yesterday said:
I especially wouldn't want to use a Big Barlow/Paracorr/Ethos combo!
So, in the spirit of scientific experimentation for the benefit of the astro community....well, ok maybe it's more the astro equivalent of an Evil Knevil stunt to titillate your voyeuristic curiosity and my sense of reckless adventure...HERE ARE SOME PICS of some of the most gnarly, scary eyepiece/barlow/parcorr combos that can possibly be conjured up. (Actually, those are TV Powermates, not barlows in the pictures, but...for present purposes, that's not important). The point is whether these absurd combos are fun to look *at*, not whether they're ideal to look *through*.
OK, LET'S GET STARTED: First, here's a picture of: 31 Nagler => 2x 2" TV Powermate => TV Parcorr (=> Moonlite Focuser) hanging off an Orion XT12i reflector. Notice that there's a difficult dilemna here to setting up these pics: I don't want to get the scope too far off vertical because of balance issues, but leaving the scope too close to vertical leaves the eyepiece optical train hanging rather precariously horizontal off the scope. Therefore, the combos didn't stay mounted any longer than necessary to take the pics.
I've used this combination in the field. You have the Paracorr and Powermate reversed, though. The PowerMate goes first, then the Paracorr and eyepiece. It's important to maintain a correct distance from the Paracorr's lens to the focal plane of the eyepiece.
-------------------- Don Pensack
12.5" Truss Dob, 5" Maksutov
Sustaining Lifetime IDA member, TeleVue junkie
star drop
Guilty as Charged
Reged: 02/02/08
Loc: Cattaraugus Co., NY
With all that stuff sticking out of the focuser I would not know where to place my ladder and wouldn't be able to reach the end of my dobs tube to track without falling off.
-------------------- Ted
HellsKitchen
Reged: 09/05/08
Loc: Australia
it's about 12100x
If I replaced those barlows with five 5x Powermates, it'd be over 1,200,000x
10" GSO dob
surfindogg
Reged: 06/05/08
Loc: Not quite darkest Dorset, UK.
Is it dark yet?
-------------------- Whasup? Oh pretty stars.
turtle86
Reged: 10/09/06
Loc: Between Umatilla and Astatula
The only caveat would be *not* to use a Barlow with the tunable top Paracorr. According to TeleVue, the Barlow might contact the Paracorr lens:
http://www.televue.com/engine/page.asp?ID=230
-------------------- Rob
18" Starmaster
8" LX200
Too many Naglers
Off-topic distractions:
Red Sox, modern lit, golf, tennis, Pearl Jam, Monty Python, fine beer and cheap wine
sixela
Reged: 12/23/04
Loc: Boechout, Belgium
If it inserts as deeply as their own 2x barlow. Many do not, and Televue specifically says this advice does not hold for their own 1.25" Powermate either.
I used a 1.8x TMB barlow, and you couldn't insert it deeply enough for it to stop requiring lots of focuser in-travel. I'm using a Baader/Zeiss now, and there's no way to make the barlow contact the Paracorr lens - not even if you set the tunable top to the lowest setting.
There are other slightly dangerous combinations that don't involve barlows at all -- a 13mm Ethos with a stack of filters (e.g. a variable polarising filter plus a Baader Moon&Skyglow) definitely *is* dangerous if you forget to set the tunable top high.
400mm f/4.46 David Lukehurst truss Dobsonian on Tom Osypowski equatorial platform
Orion Starblast (114mm f/4 reflector, Alt/Az)
Lawrence Sayre
Reged: 10/16/04
Loc: N.E. Ohio
Actually the only important thing is to maintain the proper spacing between the resultant focal plane of the combined Barlow and eyepiece 'as a unit' and the Paracorr, which is no different than placing an eyepiece with a built in Barlow into the Paracorr. I routinely placed my 2" 1.6X Antares Barlow directly into my Visual Paracorr, and I always got fantastic results. If I still had a Paracorr, my current 2" 1.5X Proxima Barlow would most certainly go directly into it. If the Barlow fits without hitting the Paracorrs eye element, then go for it.
-------------------- My philosophy, in essence, is the concept of man as a moral being, with his own happiness as the moral purpose of his life, with productive achievement as his noblest activity, and reason as his only absolute.
Ayn Rand (in the appendix to 'Atlas Shrugged')
Starkler
Reged: 11/04/05
Loc: Australia, Melbourne
As I found after trying a 2" OIII filter on my 31 nagler and discovered it wouldn't seat fully into the paracorr.
-------------------- Geoff
15" SDM truss dob | Vixen r130sf | GSO 10" dob
bykhed
Reged: 10/22/07
Loc: Westminster, CO
You people are DEMENTED! The really scary one is the guy on AM selling his Zeiss EPs and AP binoviewer with damage from a fall on concrete. Talk about seeing a grown man cry....
-------------------- Orion 150mm Mak-Cass
Wegat ETX-125 Mak-Cass
Celestron C11 XLT
Starizona Hyperstar 3
Skywatcher EQ6 mount
"The evolution of the universe can be likened to a display of fireworks that has just ended: some few wisps, ashes and smoke. Standing on a well-cooled cinder, we see the fading of the suns, and try to recall the vanished brilliance of the origins of the worlds." - Georges Lemaitre
