Vars191
Reged: 05/24/08
Loc: Queensland Australia
Hi All Astro Nuts Will a Meade 494 autostar work on a ETX90 if not why not and can it be made to Poverty Stricken Astro Nuts Vars
john D
All you have to do is ask!!
Reged: 08/05/07
Loc: Midlothian, VA
hey Vars, i think it should work. my friend has a etx-80 and he uses a 494 with it. so you should be fine.
-------------------- Meade ETX-125
Meade LXD55 mount
Philips SPC900NC webcam
Some Accessories!
My Blog
-Midlothian VA
--Land Of The Free Because Of The Brave--
rutherfordt
Reged: 05/07/06
Loc: Blountville, Tennessee USA
No, I don't think it will. The ETX-80 is the same, as far as the AutoStar is concerned as an ETX-60 or ETX-70, so the 494 works fine with either. The 90, 105, and 125's are different, though, and the AutoStar knows that-- my 494 would not work with my ETX105-- a message appeared on the screen that told me I needed the 497 (I don't remember the exact wording, but that is essentially what it said). I suspect that you'll get the same message.
-------------------- Tom Rutherford
10-inch f/6 Homemade Dobsonian (Cave mirror)
8-inch f/6 Homemade Dobsonian
6-inch f/5 Meade SN6
6-inch f/10 Celestron C6
5.5-inch f/3.6 Celestron Comet Catcher
66mm f/6 WO Petzval
2-inch f/15 Nippon Kogaku (my first telescope)
assorted unassembled pieces and parts
Edited by rutherfordt (10/11/08 08:43 AM)
yock1960
Reged: 06/22/08
Loc: SW Ohio, USA
Did you check the 'Telescope Model' setting in Setup? If it's in there it should work. If not and from what Tom said regarding the 494 'knowing' it was attached to a 'wrong' scope, you may be out of luck. Based on a quick search and anecdotal info...it looks like it should work, but it probably depends on the firmware in your 494, whether the ETX90 is a known scope.
Good Luck!
-------------------- LXD75 GEM
Orion Starblast 4.5" Imaging Reflector
William Optics Zenithstar 66 SD APO
Meade DSI II OSC
Meade DSI III OSC
Orion Starshoot Autoguider
Televue Powermate 2.5x
Discovery 6" Dobsonian
Nikon Action Extreme 10x50's
Gallery
Darenwh
Reged: 05/11/06
Loc: Covington, GA
Depends on the model of ETX90 also. The RA version and origional version are not able to be used with any controller as they only have an RA drive, no DEC motor or control circuitry included with the scope. Thanks, Daren
-------------------- Daren
Covington, GA
1 registered and 3 anonymous users are browsing this forum.
Moderator: Shadowalker, oldsalt
