Telescope Specific Forums >> Meade ETX
yock1960
Reged: 06/22/08
Loc: SW Ohio, USA
ETX 80 RA Clutch info new
      #2690912 - 10/10/08 11:34 AM Attachment (9 downloads)
I've had a few issues with my ETX80 and have found some info scattered around. However, most of the information regarding fixes for mechanical problems are
either for 90,105,125's, were text only or the pictures left something to be desired. Here is a sketch and some photo's of the inside of the RA/AZ body
of my scope, along with my understanding of how it works. I will disclaim that 1) I'm not a draftsman or an engineer and 2) I probably don't have a
complete understanding of everything that's going on in there 3) I take no responsibility for any damage that may occur from anyone using this info.
That being said, some other owners of ETX80's may find some of this helpful.
Discovery 6" Dobsonian
ETX80 Backpack Edition + Meade #884 Tripod
Astronomiser ASTSC1C
Meade DSI II
Televue Powermate 2.5x
Gallery
yock1960
Reged: 06/22/08
Loc: SW Ohio, USA
Re: ETX 80 RA Clutch info new [Re: yock1960]
      #2690913 - 10/10/08 11:35 AM Attachment (10 downloads)
INNER WORKINGS OF THE RA/AZ AXIS OF AN ETX-80
The body of the ETX80 is two 'halves' that I'll call the UPPER and LOWER halves. There is a central axle through which passes a screw which threads
into a locking nut. The nut and other hardware can be seen by removing the cover plate on the bottom of the scope. The screw, which I'll call the
ACTUATION SCREW, helps hold the two halves together, along with a nylon bushing or RETAINING NUT which threads into the axle. This RETAINING NUT is
originally glued into the mating threads, these threads are very shallow and are unavoidably stripped during disassembly, you can't seperate the two
halves without removing it though. I suppose that Meade would use a new part when re-assmbling, but who knows! This nut really does most of the work
holding the two halves together (along with the ACTUATION SCREW assembly) and it fits back in rather snugly after reassembly, it could be glued back
in, but I haven't seen the need as of yet. The end of the nut has 4 protrusions which fit into mating holes on the THREADED LOCK WASHER to keep the
washer from backing off from clamping/unclamping using the ACTUATION SCREW. Beneath the lock washer is a plain washer which sandwiches a needle bearing
between itself and what I will call the CLUTCH PRESSURE PLATE. Moving on to the actual interior, we have a nylon washer I call the LOWER CLUTCH DISC,
which has three tabs that fit into slots to keep it from rotating. The RA/AZ GEAR is next; it rotates freely around the axle and can also slide up and
down. This freedom of movement allows rotation when the RA axis is unclamped. Beyond that the UPPER CLUTCH PLATE, which is unable to rotate, being
pretty solidly attached to the lower half. Before I got inside here, I had a tough time understanding how this thing worked or didn't work as the case
may be. Here is how it works:
The WORM GEAR is always engaged into the RA GEAR, held against by a clip spring. The RA GEAR floats, it's not attatched to anything, this is what
allows rotation when the RA clamp is loosened. Tightening the ACTUATION SCREW causes the CLUTCH PRESSURE PLATE to force the LOWER CLUTCH DISC into the
bottom of the RA GEAR which forces the gear into the UPPER CLUTCH PLATE. The UPPER CLUTCH PLATE is attached by three screws to the lower half of the
body and can't turn. The worm gear is attached to the UPPER half, where the scope is and the RA GEAR is now 'fixed' between the two halves, at least to
some degree and the scope will now rotate when the motor turns the worm gear. Of course, this sometimes doesn't work too well. I have read that
sometimes grease gets between the clutch surfaces, thereby reducing friction, which is what we don't want to happen! So, if we want friction, why don't
we just clamp the daylights out of it? Well, too much of a good thing is not a good thing I always say, and I guess you run the risk of deforming the
CLUTCH PRESSURE PLATE causing it to have a reduced footprint where it pushes the LOWER CLUTCH DISC and possibly even stripping the threads on the
screws which hold the UPPER CLUTCH PLATE. The general consensus is to increase the friction between the gear and clutch plates by roughening the
surfaces slightly, so that they grab more easily with not too much pressure.
The only part that I haven't discussed is what I call the AXLE BEARINGS. These split nylon sleeves fit betweeen the axle, which is on the upper half
and the axle housing on the lower half. They did appear to have some lubricant on them. Enough or not enough, I don't know. I added some white lithium
grease to mine.
Meade DSI II
Gallery
yock1960
Reged: 06/22/08
Loc: SW Ohio, USA
      #2690914 - 10/10/08 11:36 AM Attachment (11 downloads)
another photo...
Meade DSI II
Gallery
yock1960
Reged: 06/22/08
Loc: SW Ohio, USA
      #2690915 - 10/10/08 11:36 AM Attachment (11 downloads)
#3...
Meade DSI II
Gallery
yock1960
Reged: 06/22/08
Loc: SW Ohio, USA
      #2690919 - 10/10/08 11:37 AM Attachment (8 downloads)
#4...
Meade DSI II
Gallery
yock1960
Reged: 06/22/08
Loc: SW Ohio, USA
      #2690923 - 10/10/08 11:37 AM Attachment (8 downloads)
#5...
Meade DSI II
Gallery
yock1960
Reged: 06/22/08
Loc: SW Ohio, USA
      #2690926 - 10/10/08 11:38 AM Attachment (8 downloads)
#6...
Meade DSI II
Gallery
yock1960
Reged: 06/22/08
Loc: SW Ohio, USA
      #2690930 - 10/10/08 11:39 AM
text formatting didn't work too well...but I wasn't typing that over again!
If I ever have to get back in to the fork arms...I'll do that too.
Steve
Meade DSI II
Gallery
astrowolf67
Reged: 12/15/07
Loc: W. KY
      #2691665 - 10/10/08 06:25 PM
Steve,
What kind of problems were you having with yours? Mine, just this week, started slightly jumping while tracking in azimuth. I tried to do a train drives on it, which was near impossible to recenter my reference point due to the jumping. I'm going to try to contact Meade, since I purchased it in Feb, and it's still under warranty. I suspect, that the azimuth lock was set too tight from the factory (unlocked, it's much tighter than my ETX60), and over time, the clutches have been deformed from too much pressure when locked.
David
"Seek the Spirit of the Wolf, for He holds the Secret of Life."
8" F/6 Original Celestron Starhopper w/custom oak and birch base
Edmund Astroscan on a Meade DS 2000 tripod
Meade ETX 80
Meade 70 AZ
Meade ETX 60 (x2)
Celestron 60mm EQ Deluxe
Tasco 60mm EQ
yock1960
Reged: 06/22/08
Loc: SW Ohio, USA
Re: ETX 80 RA Clutch info new [Re: astrowolf67]
      #2691802 - 10/10/08 08:00 PM
Originally, I had a problem with the DEC/ALT lock. Based on the info given, I felt like it took too much tightening to keep the front of the OTA to not slip down and/or allow the motors to slew the OTA up. I guess I should have sent it back then, but having read about people going through multiple scopes to get one that worked, I decided not to.
More recently, after purchasing a tripod to allow me to try using polar mode, the RA/AZ axis slips when trying to slew the OTA up. So far, it's hit or miss whenever I try polar mode. I'll keep working at it. It's too late to send it back now and I can still do some imaging. In time, conditions permitting, I'll get another scope/mount that is more appropriate for doing the imaging I would like to try my hand at.
Meade DSI II
Gallery
astrowolf67
Reged: 12/15/07
Loc: W. KY
      #2691844 - 10/10/08 08:42 PM
Your descriptions, drawing, and pics, are excellent, and could prove to be a valuable resource in the future. Thank you for taking the time to post them.
I just got off the phone with Meade, and, already have a return order number. I'm having to pay shipping both ways, due to it being over 30 days from original purchase date. But, it'll be going back as of Monday. If the next one develops problems, I'll likely tear into it my self, as I'm sure the shipping to them isn't going to be cheap (they only charged 15 to send me a new one).
David
Meade ETX 80
Meade 70 AZ
Meade ETX 60 (x2)
Tasco 60mm EQ
1_old_dog
Reged: 09/07/07
Loc: Smoky Mnts
      #2692563 - 10/11/08 09:48 AM
Hi Steve
Excellent post This thread will definitely help others understand the workings of the ETX.
OD
yock1960
Reged: 06/22/08
Loc: SW Ohio, USA
      #2693387 - 10/11/08 05:55 PM
Thanks! Hope you get a good one! let us know.
Meade DSI II
Gallery
yock1960
Reged: 06/22/08
Loc: SW Ohio, USA
Re: ETX 80 RA Clutch info [Re: 1_old_dog]
      #2693399 - 10/11/08 06:00 PM
Thanks OD! I hope it does.
Meade DSI II
Gallery
2 registered and 4 anonymous users are browsing this forum.
Moderator:  Joe Cipriano
Home
