Telescope Specific Forums >> Meade ETX
yock1960
Reged: 06/22/08
Loc: SW Ohio, USA
ETX 80 DSO M27
      #2697275 - 10/13/08 07:14 PM Attachment (56 downloads)
Well, I've decided to post this after finally getting an image where M27 can actually be seen! It was quite faint originally, but after over a day of playing around, research and buying Noel Carboni's Astronomy Tools for Photoshop, I think I am finally seeing first hand and for the first time, what can be done with the 'hidden' image data. Now if I can just get the ETX to be a little more consistent tracking wise. I'll be happy....for now!
Ooops! Forgot. M27 Oct. 11, 2008, 2322EDT 30x10s.
Discovery 6" Dobsonian
ETX80 Backpack Edition + Meade #884 Tripod
Astronomiser ASTSC1C
Meade DSI II
Televue Powermate 2.5x
Gallery
Edited by yock1960 (10/13/08 07:19 PM)
sang33ta
Reged: 07/08/08
Loc: UK
Re: ETX 80 DSO M27 new [Re: yock1960]
      #2697290 - 10/13/08 07:20 PM
That's very nice for the budget, well done.
Hioptic 152mm f12.5 Maksutov
Celestron Advanced CG5-GT Mount (Mr Noisy!)
Meade 4000 Super Plossl Set
Casio QV-2900UX
Got fed up of waiting for Meade ETX-150 so put this together for £500/$1000
surfindogg
Reged: 06/05/08
Loc: Not quite darkest Dorset, UK.
Re: ETX 80 DSO M27 new [Re: sang33ta]
      #2698047 - 10/14/08 05:26 AM
Way to go - and with an 80.
Whasup? Oh pretty stars.
justabob
Reged: 05/05/07
Re: ETX 80 DSO M27 new [Re: surfindogg]
      #2741249 - 11/08/08 01:00 PM
Nice shot! I gave it a few tweaks.
http://www.pbase.com/rkn/astro&page=all
Vixen Sphinx SXW LXD55
Self modded 350d
DSI PRO II
73 DE W9HS
Bob
cnstarz
Reged: 12/22/07
Loc: Kentucky, USA
Re: ETX 80 DSO M27 new [Re: justabob]
      #2742243 - 11/09/08 04:00 AM
Excellent image! It's tough to improve tracking and extend exposure time. Moving to polar mode should help but the apparent flex in the base results in stickiness and jerking in RA. I'm still experimenting with my ETX-60 system.
Clear Skies,
Matt
Apogee 50mm BB scope
ETX-60 BB
Meade 70-az
5" DIY Newt (wip)
C6-N on CG-4 GEM
Gallery
yock1960
Reged: 06/22/08
Loc: SW Ohio, USA
      #2742719 - 11/09/08 12:47 PM
Thanks. I was more pleased with this one:
http://tinyurl.com/674zjd
No nasty noise from too high gain.
Still trying to better this one with my new DSI II, but not yet!
Meade DSI II
Gallery
yock1960
Reged: 06/22/08
Loc: SW Ohio, USA
Re: ETX 80 DSO M27 new [Re: cnstarz]
      #2742741 - 11/09/08 12:55 PM
Yeah, I know! I was so hopeful when I got the #884 tripod, but I don't think polar mode is going to be workable. When the really rotten weather moves in, perhaps I'll experiment
to see if I can get it to work. Just keep in mind that you really can't do AP with these scopes, I've read it!
Steve
Meade DSI II
Gallery
justabob
Reged: 05/05/07
      #2742806 - 11/09/08 01:27 PM
Keep em coming Steve, This is how I started with a etx90. Learn polar alignment, the longer the exposure the better in most cases. I just picked up the dsi pro II and am looking foreword to trying some small targets with it.
Self modded 350d
DSI PRO II
73 DE W9HS
Bob
MtnGoat
Reged: 02/18/07
Loc: Columbia Gorge, WA
      #2744367 - 11/10/08 11:53 AM Attachment (7 downloads)
I've found polar mode to be pretty sucky after quite a while attempting to tweak the system. In my opinion the scope is not well designed for the loads placed on it by putting it equatorial position. The entire platform loads up one side of base when it's tilted over and I could never escape having problems with it dragging a bit while tracking.
Looks fine for a bit...then drift starts as the base bearing hangs up somewhere and it slows down the works, then the motor loads it enough to pop it free from where it's hung up. Repeat. Smooth...stick..jump. Smooth..stick..jump.
I pulled it apart numerous times messing with the clutch and RA nut tension, and trying all kinds of lubricants on the rim of the base. Some worked better than others, but I could never get it reliable.
The other issue I continually fought was the clutch...when the system is tipped over to polar mode, any slewing in RA which not near the meridian means the clutch must be tight enough to rotate the whole works without slipping.
With a DSI on there it's a fair load and balancing it with some lead helped a lot, but every other night it would slip halfway through a slew and bollix up my Autostar alignment.
I worked all these issues concerning a polar setup for some months and also broke the stupid plastic RA/Clutch nut along the way. (What a lousy part to choose to make from plastic). I learned a lot about this system along the way. Somewhere I ran across a hack for the RA axis on these things which involved cutting some small slots in the base circle and installing teflon pads as friction bushings to make the RA axis better, this may work.
I finally tired of it and went back to Alt/az where none of these issues crop up. Having the base properly tightened and clutched and lubed will result in a fine Alt/az unit for one made so...modestly, but I was simply never happy with polar mode. With a smooth running alt/az setup and Drizzle, you should be able to take some pretty decent shots even without polar mode. I know I did. At this image scale I found I could run 15 sec subs in alt/ax mode just fine, and with Drizzle to derotate, you can do a lot. You can definitely take OK astrophotos in stock mode, as long as you know the limits.
What essentially ended my experiments in polar mode for good was the aquisition of a 4.5" Starfinder 4504 Newtonian for cheap off of Craigslist. I gave away the OTA, redid the motor mountings, set up the worm tension right, and got a $50 german equatorial in return that works pretty danged well with the ETX tube assembly on it. GOTO's are excellent and I routinely get 30 sec subframes that are pretty good.
Below is an example from the current setup (DSI-C, ETX70 OTA, 4504 GEM), I didn't have the pole dialed in all that well yet so there is a slight bit of trailing. 30 second subs x 34 frames. Also, I screwed up and was running in BMP mode so the pixel depth is not what it should be. Still, it gives an idea of what is possible.
"Ignorant people think it's the noise which fighting cats make that is so aggravating, but it ain't so; it's the sickening grammar they use." Mark Twain
Edited by MtnGoat (11/10/08 12:48 PM)
6 registered and 4 anonymous users are browsing this forum.
Moderator:  Joe Cipriano
Home
