Telescope Specific Forums >> Meade ETX
FLNightSky
Reged: 03/13/06
Re: GOTOs way off new [Re: john D]
      #2705155 - 10/18/08 01:01 AM
Update: a better outcome this evening. The alignment stars were just out of the EP, but easily findable. After alignment, the GOTOs were better; the moon was right on, hard to miss, Polaris was again slightly out of the field. Maybe I need to use a reticle EP for alignment.
I also noticed that when I switched to my binoviewers, while observing Polaris, the star seemed to migrate down in the FOV and stay there, even if I tried to center it. I was using 20mm EP with the binoviewers and 26mm when I did the alignment. Strange.
Reged: 07/06/07
Re: GOTOs way off [Re: FLNightSky]
      #2705544 - 10/18/08 10:50 AM
Don't worry about the alignment stars being in the eyepiece; just center them up (make sure you are centering the correct stars, of course). If you've got a good drive trainin' and are careful about centering alignment stars, all will be well.
Uncle Rod
Rod's New Book:
Choosing and Using a New CAT
Available now!
1 registered and 3 anonymous users are browsing this forum.
Moderator:  Shadowalker, oldsalt
