EdZModerator
Professor EdZ
Reged: 02/15/02
Eyepieces for the Oberwerk BT100 & BT80
      #271284 - 12/04/04 01:59 AM
I wrote some on this topic in the articles forum and based on a discussion with NW, I tried some new things tonight so I'm bringing the discussion over here.
The BT100 is a straight thru 100mm binocular with a focal length of 620mm. The standard issue eyepieces both have an Afov of 62°. One is 24.5mm for 25x with 2.5° and the other is 10mm for 62x with 1.0°.
I've owned a 30mm Ultima for 5 or 6 years and it is a favorite in my various scopes. In the BT100, it would give 20.7x with an exit pupil of 4.8mm and a field of view of 2.4°. I've tried my single 30mm in the BT and it performs pretty well. It's edge performance is not as well corrected as the Televue plossls, but it's not bad either. the view is very bright. Seems to me it would make a great large exit pupil eyepiece. So, a few months ago, and again this week, I purchased three other 30mm Celestron Ultimas. Well the 30mm Ultima is notorious for having a tight barrel. And I can now say the BT100 has extremely tight tolerance for a 1.25" eyepiece. None of the three new purchases will fit in the barrel. I measured the barrels on all the 30s with my calipers. The three I recently purchased are all one half of 1/10th of a mm wider. I'm getting ready to give up on the 30mm Ultima.
So far my favorite low powered eyepiece is an unmatched pair of older 26mm Televue plossls. These give 23.8x with a 2.2° filed of view and a 4.2mm exit pupil. The view of nebula is stunning.
My most used eyepiece is a pair of 20mm Televue plossls. At 31x the little extra power is quite noticable. I think it helps finding faint galaxies. Field of view is 1.6°, and exit pupil is 3.2mm.
I have a pair of 17mm Orion Sirius plossls that I like for sharpness of image. magnification is 36x, fov is just under 1.5°. The 20mm TV actually sees more stars, but these 17mm are pretty good if I want a little magnification boost.
I tried my single 18mm Meade SWA in one barrel, but the edge sharpness is much better in the 17mm Sirius plossl and the 20mm TV plossl, so the 18SWA got passed over as a choice. I tried my single 15mm TV plossl in one side, but the eye relief is so short I would need to use these without my glasses, so I decided not to purchase another one. I have astigmatism in one eye that becomes noticable with exit pupils larger than 2mm.
I have a pair of 12.5mm UO orthos that, although very narrow about just under 1°, provide the most incredible crystal clear sharpest view you could imagine. At 50x, it's a great power. With these I have seen resolution in several globulars. Far better image than the 10mm WA. One of the best high-powered views ever in the BT100 was with a 12.5mm UO ortho at 50 power when I resolved some 30 to 40 stars in the very dense open cluster M11.
I also have a pair of 9mm UO orthos (69x), but I found the eye relief to be much to short. In most of my scopes, I don't use my glasses with the 9mm, in the BT100 I do. To get the best use out of the 12.5mm and 9mm orhto, I have to take my glasses off. In addition, it is extremely difficult getting the tiny orthos in and out of the tight BT eyepiece holder. I still have the pair of 9mm, but I haven't used them in a while. I find it easy enough to just not stick the 12.5 UOs all the way into the barrel. There is almost 28mm of focus travel in the BT100, so there is plenty of room for focusing.
The stock 10mm WA Oberwerk eyepiece gives 62x with a 1° field of view. However, the 12.5mm and 9mm UO orhtos seem to pass more light. I can see fainter stars in the 12.5mm UO than I can in the 10mm WA. In addition, 62x accentuates some slight astigmatism in one barrel and a little bit of miscollimation. I must read the instructions and get this taken care of to really get the best out of these high powered eyepieces.
The TV20, Orion17 and UO12.5 provide such an incredibly sharp image right out to the very edge of the field that I have observed doubles of less than 7" with all of these right up to the field stop. The standard issue 25x WA eyepiece is good to 70% out and the 62x WA maybe to 80-85% out.
Recently I purchased a pair of Meade 13.8mm SWAs on sale. At $99 each I thought these would be a great choice. After using these several times, I am extremely disappointed in the performance of this eyepiece. Beyond 60% out from the center of the view, the image is deplorable. The eyepiece has extremely short eyerelief and I can only see about 75%-80% of the field if wearing glasses. Without glasses, the eye relief is not much better than my 12.5mm UO orhto, in fact I'd say it's more difficult to use because it has a wider filed to try and see. The 12.5 UO ortho, even though eye relief is not long, is pretty easy to see the 44° Afov. The 13.8mm SWA is definitely not made to be used in an f6.2 instrument. In fact I tried one of these 13.8s in my f11 5" SCT and I was still not at all impressed with the performance. I will be passing this pair of 13.8 SWAs on to a new home.
I'm considering purchasing another 14mm Radian to go with my existing. I think these might work well at 44x with a 1.4° fov.
Because I prefer to use my glasses while binocular observing, I would prefer to use all long eye relief eyepieces. The 14mm would be a good choice. Tonight I tried using a barlow. The TV 2x barlow fits with plenty of room to spare without hitting the prisms and works well with my 30mm Ultimas and my Televue eyepieces. This is encouraging. And the performance of the 30mm Ultima was much improved in the 2x barlow. With the addition of another 2x TV barlow I could use my 30mm Ultimas, my 26mm TV plossls and my 20mm TV plossls to also provide 15mm, 13mm and 10mm combos, although fields would be narrow, but better than the high powered orthos.
I tried my Celestron Ultima 2x barlow. Interesting was that it worked with the TV20mm, but would not work with the 30mm Ultima eyepiece. Needed more in travel.
Here's what else I tried tonight. I tried to use a diagonal. Wouldn't it be nice if a diagonal could be used with the BT100 to give 90° eyepiece viewing! I didn't expect it to work and it didn't. That's because the focal point is inside the focus tube and the diagonal is like trying to extend the tube by maybe 50 to 60mm. You can't do it. But, if you put a barlow in front of the diagonal it changes the position of the focal point. So I tried out barlows in front of diagonals with several combinations. One thing to keep in mind, a 2x barlow placed in front of the diagonal is acting more like a 3x barlow. That makes for a very long focal length binocular with a narrow filed of view. But it's worth a shot.
With my TV 2x barlow, I needed less than a mm more of in travel in the focuser to bring my 30mm Ultima and 20mm TV into focus. I mean, it was so close that less than a half turn of the focuser dial would have brought these eyepieces into focus. I used two different 90°diagonals, a Celestron prism and an standard issue mirror diagonal. I also tried my Celestron Ultima 2x barlow in front of the diagonals, but it needed even more in travel in the focuser. The 2x TV barlow seems like it may hold some promise. I have at least three other diagonals around the house that I'm going to try. I have a TV standard diagonal and a TV Everbright. If the length of the light path is just a bit different in one of these, It might just work.
Keep in mind, with the barlow in front of the diagonal and a 30mm eyepiece, If it works I'm going to get the equivalent of a 10mm eyepiece or 62x. But man you should see the Orion nebula at 62x in the BT100. Wow! And just imagine if I can get this to work with a 90° eyepiece setup!
edz
Edited by EdZ (01/15/06 05:13 PM)
KennyJ
Reged: 04/27/03
Loc: Lancashire UK
Re: Eyepieces for the Oberwerk BT100 new [Re: EdZ]
      #271339 - 12/04/04 06:19 AM
Ed,
Great report , which ought to give many readers much to chew over.
It would indeed , be "dreamland" if you could find a way to satisfactorily overcome the "90 degree problem" !
Regards , Kenny
If everyone is thinking the same thing , no-one is thinking - General George S.Patton
Zeiss 7 x 42 BGAT
Captain's Helmsman 7 x 50
Nikon 10 x 42 Superior E
Swift Audubon Kestrel 10 x 50
Helios 15 x 70 Observation
Strathspey 20 x 90
Televue 76 APO
Zeiss 85 Diascope
Helios 102 f5 refractor
Anonymous
Unregistered
Re: Eyepieces for the Oberwerk BT100 new [Re: KennyJ]
      #271354 - 12/04/04 08:05 AM
EdZ, thank you so much for posting your "trails and tribulations" with various EPs and the BT100. I am sad that I have not purchased a few EPs by now for the BT100. Other things keep coming up. I want power in the mid 30x range, mid 40x range and mid 50x range. I have been looking at EPs online for several weeks, but I have been afraid of the quality being poor and/or the EPs not fitting. Even the EPs that come with the BT100 require quite a bit of elbow grease to install. The EP experiences you have posted gives me some confidence.
Like yourself, at 62x with the 10mm EPs that come with the BT100, it is difficult to get the sharp image I want. The culprit is in the right barrel. I surmise that the problem is a slight mis-collimation. The view is not THAT bad, but it's not as sharp as what I see at lower power due to this. Additionally, the 10mm EPs themselves are not that good...which compounds the problem. I have attempted to adjust the massive right prism, but the adjustment screws are stuck I think. Either that, or I wasn't applying enough torque. Speaking with Kevin at Oberwerks, I thought that if I tried any harder, something was going to break. Aside from sending the BT100 to Oberwerks to be examined, I don't know what else to do.
What can one do with EPs that are hard to pop in? Is it safe to use some type of lubricant? Can you properly file down the EPs to improve the fit?
I was walking home for work yesterday wondering if you have attempted anything using diagonals. Yes. The BT100 would be ever so much improved if it had angled EPs. It's too bad your first "go" with a diagonal didn't work. I wish it had. Please let us know how the barlow and diagonal works out. If you can get your BT100 to operate with angled viewing, I'm buying the hardware immediately.
Erik D
Reged: 04/28/03
Loc: Central New Jersey, USA
Re: Eyepieces for the Oberwerk BT100 new [Re: ]
      #271369 - 12/04/04 08:50 AM
I was walking home for work yesterday wondering if you have attempted.......
NW,
This is off topic....but any man who has a walking commute is a lucky one! :-))
My commute over the last 3 jobs were 60+, 50 and 32 miles one-way. I have been doing the 32 miler for the last 10 years....I am extemely well acquainted with National Public Radio prorgamming. ;-))
Erik D
medinabrit
Reged: 10/27/04
Loc: medina ohio USA.
Re: Eyepieces for the Oberwerk BT100 new [Re: Erik D]
      #271393 - 12/04/04 09:33 AM
very interested in your bt 100 article. i own the apogee ra 88,s which do have 90 degree eye pieces does any one know of any eye pieces that will give me more mag than the 32x i get now? about your tight eye pieces . find a m/c shop with an o.d grinder &get them to skim a couple of thousands off
brian
Erik D
Reged: 04/28/03
Re: Eyepieces for the Apogee RA 88 new [Re: medinabrit]
      #271403 - 12/04/04 09:44 AM
Brian,
Forum member Joe Ogiba also has the RA 88.(Aug 04) He has posted a brief review and commented on using some non-Apogee EPs. You can find it in the mini review section. I don't know if shorter focal length EPs will come to focus.....You may want to contact Joe via Private Message and ask him if he has an update.
Erik D
Anonymous
Unregistered
Re: Eyepieces for the Apogee RA 88 new [Re: Erik D]
      #271920 - 12/04/04 10:17 PM
Erik, yep I am lucky to have a job that I can walk to (for the time being). I work with people who burn 2-3 hours a day of their lives in a car driving to and from work. It's terrible in my opinion! YUCK!
ANYWAY, I think I would need a machine that could spin the EPs while I file them down to a slightly smaller diameter. I do not have such a machine, nor the steady hands (thanks to my coffee addiction) to make the filing uniform. I guess I will just have to deal with it.
KennyJ
Reged: 04/27/03
Loc: Lancashire UK
Re: Eyepieces for the Apogee RA 88 new [Re: ]
      #272156 - 12/05/04 05:54 AM
It's not the first I've heard of this problem , nor possibly the first time I've complained about it , but WHY don't manufacturers' construct eyepiece holders of such dimensions to accomodate ALL eyepieces of any given size ?
Either that or make ALL 1.25 inch eps EXACTLY the same outside diameter ?
Given the real world situation of SOME 1.25 inch eps being slightly larger than others , it would seem to me that even making eyepiece holders too LARGE would be preferable to making them too SMALL.
At least that way , any eps which were slightly too small could easily be "built-up" by wrapping something like PTFE tape around the barrel until a good fit is found.
Anyone know WHY this ridiculous situation continues ?
Regards , Kenny
Zeiss 7 x 42 BGAT
Strathspey 20 x 90
Televue 76 APO
Zeiss 85 Diascope
Anonymous
Unregistered
Re: Eyepieces for the Apogee RA 88 new [Re: KennyJ]
      #272189 - 12/05/04 08:00 AM
Kenny, I think this is an issue of tolerance for both the EP holder and the EP. Should either one depart from 1.25", you have a problem. And I agree, if anything the holder should err on the side of being too large. I also assume that if the EP holder of the BT100 was proprietary, then the EPs would fit perfectly. I'm guessing. So this may be the "price to pay" for being able to use whatever EPs you want.
EdZModerator
Professor EdZ
Reged: 02/15/02
      #272274 - 12/05/04 10:58 AM
Kenny,
The tolerance that I'm measuring as a difference, one half of 1/10th of a mm, is the equivalent of 2/1000ths of an inch. I know it causes me problems, but I think it is not unrealistic to see that variance in the types of products we are dealing with here.
It could very well be that both the eyepiece sleeve and the barrel insert are to within tolerance of 1/1000th of an inch, but it just so happens each is 1/1000 the wrong way in this case.
BTW, I would not take any of my eyepieces to have them ground down anywhere.
edz
Teach a kid something today. The feeling you'll get is one of life's greatest rewards.
member#21
Anonymous
Unregistered
Re: Eyepieces for the Apogee RA 88 new [Re: EdZ]
      #272340 - 12/05/04 12:10 PM
Do you think some type of lubricant would help EdZ? I would worry about contaimination of the prims, but if a small amount of lubricant would help greatly, then I would consider using it.
EdZModerator
Professor EdZ
Reged: 02/15/02
      #272623 - 12/05/04 06:32 PM
I think no amount of lubricant is going to allow inserting these 30mm Ultimas. You've seen the fit tolerance. Even the eyepieces that do fit are as snug as you could possibly get. I measuered 6-7 eyepieces. There is no question these few 30mm Ultimas at 2/1000ths bigger.
edz
member#21
Anonymous
Unregistered
      #273056 - 12/06/04 08:20 AM
I suppose you're right and it's not a huge deal. I just wish swapping out EPs was a smoother process.
EdZModerator
Professor EdZ
Reged: 02/15/02
      #339441 - 02/10/05 12:24 PM
After my disappointment with the 13.8mm Meade Superwide, distortion at 60% to 70% out from center, I've decided I'm going to sell that pair and pick up a second 14mm Radian to use with my current 14. I tried the single Radian I have and the illumination measures up very good.
A pair of 14mm radians will give me 44x with a 2.25mm exit pupil and a 1.36° Tfov. I can get to like that, I think even more than the 12.5mm UO orhtos which give 50x with a 2mm exit pupil, but only a 0.9° TFOV. Hover that field is super sharp right off the edge of the field stop.
member#21
thane
Reged: 01/26/05
Loc: Poulsbo, WA 47° 43.907' N ...
Re: Eyepieces for the BT100 new [Re: EdZ]
      #339447 - 02/10/05 12:36 PM
EdZ,
I took your lead after asking crazy questions about 7mm... and I have a set of new 14mm TV Radians and 9mm TV T6 Naglers on their way and will be here tomorrow. In my mind it seemed if I was going to a higher x, the field should be wider...60deg vs 82deg? Is this correct thinking?
Oberwerk BT100, 7x50 Mariner, 11x56
Mak 127mm
16" SCT f/1.2 Project
eBay ID: thane*grooms
EdZModerator
Professor EdZ
Reged: 02/15/02
Re: Eyepieces for the BT100 new [Re: thane]
      #339450 - 02/10/05 12:50 PM
Sure it is. At least 60° anyway. The Naglers will provide much greater Tfov, but at substantial cost!
I use mostly plossls, 26, 20 and 17. I like the perfect view and they all cost between $40 and $80. I've even been using 12.5mm orthos, $40-$45. I've never found myself using these binocular at 50x and complaining I didn't have enough field of view. If you want that highly corrected field of view, you need highly corrected eyepieces.
edz
member#21
Anonymous
Unregistered
      #339455 - 02/10/05 12:55 PM
I will be curious to read about your experience with TWO 14mm radians. I really need to purchase at least two more pairs of EPs. The TV 20mm plossls are a definite, but the other pair is still a question.
Thane, if by "higher x" you mean "higher focal length", not necessarily. An EP with a longer focal length can have a smaller AFOV compared to an EP with a smaller focal length.
thane
Reged: 01/26/05
Re: Eyepieces for the BT100 new [Re: ]
      #339583 - 02/10/05 02:54 PM
Night Watch,
By "higher x", I meant higher magnification. I figured if I was going to push it by going to 69x, I should afford myself a wider field (Naglers 82deg VS. the Radians 60deg).
Mak 127mm
Anonymous
Unregistered
      #339626 - 02/10/05 03:25 PM
Oh, my mistake. Your statement was a little ambiguous to me.
One question to all, are there any EPs that, due to their design, would limit the full IPD range of the BT100? Meaning the EPs would touch before the IPD is at its smallest mechanical limit...
EdZModerator
Professor EdZ
Reged: 02/15/02
      #339644 - 02/10/05 03:34 PM
Well, the stock eyepieces are just about as wide as the 8.8mm Meade UWA, which is about as wide as the wide body Naglers, so I'm guessing the answer is no.
Since the minimum IPD is 58mm, any two eyepieces of 57mm diameter or less should work. This is what you would need to measure against.
edz
member#21
13 registered and 25 anonymous users are browsing this forum.
Moderator:  EdZ
Home
