russty55
Reged: 07/18/07
Loc: New Zealand
Yashica 10x40 binoculars
      #2740845 - 11/08/08 07:32 AM Attachment (33 downloads)
I have just purchased these at auction but cannot find any information regarding them. They are 10x40 in what appears to be of roof prism constructiom. Yet to receive them but any comments from other members with any experience of this model would be appreciated
Edited by russty55 (11/08/08 07:39 AM)
charen
Reged: 05/28/05
Loc: New Zealand
Re: Yashica 10x40 binoculars new [Re: russty55]
      #2741581 - 11/08/08 05:36 PM
Hi ! fellow New Zealander here. Yaschica produced Hi quality Japanese binoculars and cameras from the late 1950s.
The binoculars made at the time were equal to Ashai Pentax of that 60- 80’s era.
I have 3 porro prism ones - 2x 7x50’s and a 8x40. They give reasonably sharp images they have Bk-7 prisms and ‘coated’ only optics. Build quality is very good.
I had to have 2 of them cleaned and collimated – internal mildew being the problem of these older Japanese binos.
In the the mid 1980’s Yashica was taken over by the electronic giant Kyocera who moved there production to Hong Kong. They began outsourcing their binoculars and Camera production for the mass market with a resulting deterioration in quality.
I had a later 10x50 which unfortunately was not as good optically as my 60’s and 70’s ones - there was marked distortions and aberrations.
The 8x40 you have should be of ‘reasonable’ optical quality. I have not personally seen a Yashica ‘roof’ like that. I don’t believe it is W.P.
The main concern would be internal deterioration, collimation and is the focusing system smooth.
I would be interested in your feedback and a ‘mini review’.
Chris
35 binos.
80mm Cat.
WO66ED
SV NH 80mm / EQ3
Meade 8in.LX90
Skywatcher Equinox ED120 / Goto HEQ5.
russty55
Reged: 07/18/07
Loc: New Zealand
Re: Yashica 10x40 binoculars new [Re: charen]
      #2748910 - 11/12/08 09:44 PM
Hi Chris and thanks for your comments. I have not received them as yet. (but hopefully should arrive in the next day or so) I am a little cautious as I cannot find any information regarding them, they appear a little unusual but the price was right so not a lot lost if they prove to be damaged. I have always had a respect for Yashica products, while not always top shelf they have generally proven to be good.
I will test these out when they arrive and indeed will post a 'mini-review'
I enjoyed your mini review of Meade's 9x63 bino's, your article was instrumental in my buying a pair.
You may have noticed that a seller on NZ's Trademe site was recently selling bino's marked "Baigish", "made in Russia". I note now that they are no longer marked or being sold as "Baigish", only represented as "Russian style" binoculars.
I must comment though that a recent pair of Chinese made "Kumning" 7x50 I purchased have proven to be very satisfactory!
Thanks again and I will report back on the Yashica's ASAP
russty55
Reged: 07/18/07
Loc: New Zealand
      #2765185 - 11/22/08 07:57 PM
~Mini review YASHICA 10x40 roof prism binoculars.~
OK, the Yashica's arrived a couple of days ago, nice leather case and complete with original lens caps for both objectives and eye pieces. A good clean removed the years of dirt etc. and the binoculars appeared to be in pretty good condition. Internally they were nice and clean, no sign of fungus etc. Next a quick check of the focusing mechanism revealed a problem, the left eyepiece didn't move when the focusing wheel was turned. To be fair this problem was alluded to by the seller. Dismantling the binoculars was relatively simple and the problem was located, the left eyepiece yoke was broken, obviously the binoculars had sustained a direct blow to the left eyepiece. Two hours later the repair has been made good and the binoculars are reassembled and now focusing smoothly!
Handling them feels very good, they are compact, not too light and have a "quality" feel to them. I am unsure of age and googling for any information has so far proved negative. They appear to be of 1970's vintage?
Eye relief measures 12mm, certainly a little tight but OK for non eyeglass wearers. FOV is marked as 6.5 degrees. Optical surfaces appear to be fully coated,? prisms appear to have a 'pinkish' coating. I am uncertain if the prisms are phase coated. They are not water proof.
It's now night and a quick check outside at a streetlight shows a sharp, bright, well collimated image with very little flare. However, as is normal with any optic destined to be tried astronomically the sky is heavily overcast......
Its now daylight and images appear to be very sharp on land based objects, good contrast and colour rendition as well. Very slight pin cushioning at very edge of field. A test object (a cell phone tower some 3 kilometres away) with fine structure proved that these bino's will be keepers. Sharpness appears to be comparable, in fact slightly better than a pair of porro Pentax's.
A week later and a cold front has just moved through, the night sky is ink black and the stars shine with that magical clarity when the air is perfectly clear, not a twinkle to be seen! A few minutes of dark adaptation and the first check on a star reveals a nice, perfectly collimated pin point of light at the centre of the field. Moving to the edge and sharpness falls off as expected. Next is the Pleiades, and the image is very nice. Orion is rising in the east and a look at M42 is very satisfying. The LMC is high in the southern sky and given the small 40mm aperture the view is again satisfying. The Tarantula nebula stands out boldly.
Am I pleased I bought these?, most definitely, they are very comfortable to use and the images are very satisfying. Performance on stellar objects was better than I imagined given their small aperture. Given that I paid $8.00 for them plus a couple of hours of my time to repair, (that was something I enjoy doing anyway), I am more than satisfied. If anyone has had/owned a pair of these their comments would be appreciated.
- Chris, thanks for your comments, re my comment about NZ's clear night skies, should we let the secret out to our fellow astronomers in the northern hemisphere!!?? Also, I note you list some 35 binoculars, I have some way to go to catch you but I have a feeling that this collecting of binoculars could become a 'problem'. Mustn't let my wife know how many I have! she will only want me to sell them. She doesn't seem to understand that I need these cheers to all.
11 registered and 12 anonymous users are browsing this forum.
Moderator:  EdZ, Joad
Calendar Event: 11/08/08
