Telescope Specific Forums >> Meade ETX
BobH
Reged: 01/03/08
Loc: PA
Manual Micro-focuser for ETX-125PE ??
      #2827138 - 12/27/08 08:33 AM
I'm looking for a gadget to attach to the focus knob of an ETX-125 PE that would allow manual fine focus and have a flex extension cable. All I can find is the motorized type.
Any suggestions?
Bob
"Wise men learn more from fools than fools from the wise." - Cato the Elder
Meade 8" LX200 GPS
ETX 125 PE
Tasco 50mm x 600mm
StellarVue 115ST on MiniTower
Orion Astroview 100
Celestron 8x42 Outland LX
'03 Harley FXDL (oops, wrong forum)
Reged: 07/06/07
Re: Manual Micro-focuser for ETX-125PE ?? new [Re: BobH]
      #2827188 - 12/27/08 09:14 AM
Any suggestions?
Bob
It's not clear to me exactly what you want. If just a flex-focus extension, they are available from numerous vendors. Those sold on Ebay work fine...or as well as this sort of thing can. As for "fine focus" AFAIK, nobody makes a replacement focuser knob that provides fine focus.
Uncle Rod
Rod's New Book:
Choosing and Using a New CAT
Available now!
BobH
Reged: 01/03/08
Loc: PA
Re: Manual Micro-focuser for ETX-125PE ?? new [Re: rmollise]
      #2827603 - 12/27/08 02:03 PM
I guess I'm looking for something like the JMI Motofocus, only without the "moto." Something with reduction gears to allow for much slower turning of the focusing knob, only controlled manually rather than by an electric motor.
Bob
Meade 8" LX200 GPS
ETX 125 PE
Tasco 50mm x 600mm
Orion Astroview 100
jgraham
Reged: 12/02/04
Loc: Dayton, Ohio
      #2827645 - 12/27/08 02:42 PM
I thought about designing a lever I could clip onto the focus knob of an ETX (and onto my StarBlast), that would make it easier to make tiny changes in the focus.
-John
Homebuilt scopes from 4.25-16.5"
Meade LXD75-N6/SN6/SC8, DSX-90, ETX-60BB, ETX-125PE, DS-2130
Orion StarBlast, BinoViewers, Coronado PST
Rebel XT/XTi, DSI Pro (I, II, & III), DSI, LPI, Electronic Eyepiece, Phillips SPC900NC
Tasco 60mm Refractors
blb
Reged: 11/25/05
Loc: Piedmont NC
Re: Manual Micro-focuser for ETX-125PE ?? new [Re: jgraham]
      #2827756 - 12/27/08 04:18 PM
A clothespin on the focus knob works well for fine focus
C-11, C-6, XT10i Dob, ETX125PE, TV102, & AT66
Reged: 07/06/07
      #2827933 - 12/27/08 06:29 PM
Bob
IOW, like a Feathertouch focuser for the ETX. Alas, ain't one or I'd have one.
I get along OK with the flexifocus (which I only use when the knob is inaccessble. Works OK.
Uncle Rod
Rod's New Book:
Available now!
jgraham
Reged: 12/02/04
Loc: Dayton, Ohio
      #2827975 - 12/27/08 07:03 PM
Perfect! I'll have the try the clothspin idea.
-John
BobH
Reged: 01/03/08
Loc: PA
      #2829146 - 12/28/08 03:25 PM
Well, I couldn't find a clothes pin lying around the house, so I ordered a flex cable.
Bob
Meade 8" LX200 GPS
ETX 125 PE
Tasco 50mm x 600mm
Orion Astroview 100
BobH
Reged: 01/03/08
Loc: PA
      #2832203 - 12/30/08 08:14 AM
I do have another question, though.
In searching for a flexicable, I ran across some comments about keeping the OTA pointed upward while installing the cable to avoid having the focusing shaft fall into the housing.
I looked at my ETX, and pushed and pulled on the focusing knob and it doesn't move in or out.
Was that caveat for earlier versions of the ETX?
Bob
Meade 8" LX200 GPS
ETX 125 PE
Tasco 50mm x 600mm
Orion Astroview 100
Joe Lalumia
Reged: 01/24/07
Loc: Rockwall, Texas, USA
      #2832310 - 12/30/08 09:35 AM
There is a tiny set-screw on the side of the focusing knob-- which you need to loosen to remove the knob.
LX90 8" LNT, SV Nighthawk & TelePOD, SV 80/9D & M4 mount, ETX 90, Orion XT10i, 20x80 binoculars, SV-BV3s-- www.texasastro.org
"Great minds discuss ideas;Average minds discuss events;Small minds discuss people." Unknown
yock1960
Reged: 06/22/08
Loc: SW Ohio, USA
      #2832319 - 12/30/08 09:39 AM
ETX's certainly don't have 'fine' focus! The flexible focusers do make it more accesible, especially when the OTA is pointing near the zenith, but it really doesn't change the fineness of focus. Maybe the larger diameter knob helps a little? I've wondered about something like this:
http://www.sciencecenter.net/hutech/borg/parts/html/7315.htm
maybe overkill and maybe there isn't enough focus travel on the ETX to use it anyway.
Steve
LXD75 GEM
Orion Starblast 4.5" Imaging Reflector
William Optics Zenithstar 66 SD APO
Meade DSI II OSC
Meade DSI III OSC
Orion Starshoot Autoguider
Televue Powermate 2.5x
Discovery 6" Dobsonian
Nikon Action Extreme 10x50's
Gallery
nytecam
Reged: 08/20/05
Loc: London UK
Re: Manual Micro-focuser for ETX-125PE ?? new [Re: yock1960]
      #2832356 - 12/30/08 09:59 AM
http://www.sciencecenter.net/hutech/borg/parts/html/7315.htmmaybe overkill and maybe there isn't enough focus travel on the ETX to use it anyway.Steve
Will it cope with the backlash that I've found common to my ETXs
Nytecam 51N 0.1W
Meade 30cm LX200+ETX-70+e-finder+C8+Ha+CaK PSTs SBIG SGS+homebuilt spectrographs
Starlight SXVF_M9+Lodestar CCDs/Canon 300D DSLR/Fuji E550
My observatory build-ETX-70 imaging-my videos
Reged: 07/06/07
      #2832379 - 12/30/08 10:11 AM
Bob
AFAIK, this is a potential problem with any ETX once the knob is off.
Uncle Rod
Rod's New Book:
Available now!
jgraham
Reged: 12/02/04
Loc: Dayton, Ohio
      #2832423 - 12/30/08 10:35 AM
For a cheap fine-focus thingy I tried the clip idea on my StarBlast last night and it was very effective. To grib the focus knob on the StarBlast I used a small shop clip rather than a clothes pin, but the idea is the same. I'll have to try it with my ETX. Another possible benefit of the clip is that if you install it right it might be easily accessible with the telescope pointed near zenith.
-John
nighty
Reged: 12/31/06
Loc: 75w39n
      #2836222 - 01/01/09 10:19 AM
Check this link for the vernier mechanism (second item). Some multi-speed focusers use similar parts.
http://www.oselectronics.com/ose_p101.htm
Here is a link to a ATM design using this part.
http://www.bedair.org/Focus/focusproject.html
I use one on my 5" refractor with homemade knobs from radio shack.
Terry
Stuff to look at stars and things
Scopes For Kids Project
BobH
Reged: 01/03/08
Loc: PA
Re: Manual Micro-focuser for ETX-125PE ?? new [Re: nighty]
      #2839683 - 01/02/09 10:21 PM
Terry,
That's exactly what I have been looking for! Unfortunately, making my own is beyond my talents.
Thanks, at least now I know there is/can be such a gadget.
Meade 8" LX200 GPS
ETX 125 PE
Tasco 50mm x 600mm
Orion Astroview 100
nighty
Reged: 12/31/06
Loc: 75w39n
      #2840339 - 01/03/09 09:19 AM
I was sure I could not make one, but just drilled a hole through a large plastic knob and attached it to the tabs. This version required holding the large knob and turning the small knob. Second version attached the tabs to the bottom of the focuser via an aluminum strip and both knobs attached to the shafts. Each application took much planning and fiddle time but only about ten minutes of work.
I think the shaft on the ETX will fit directly so an adapter is not needed. You should be able to make it work for around $20.
Terry
DMRandall
newbie
Reged: 12/25/08
      #2857822 - 01/11/09 11:40 AM
I could sure see a marketable product in that fine focuser. Wish I had the ability to build a dozen or so to test market them. Esp if they were as easy as a "replacement focuser knob for ETX"...
Jason Rader
Reged: 12/06/08
Loc: Douglasville, GA
Re: Manual Micro-focuser for ETX-125PE ?? new [Re: DMRandall]
      #2858102 - 01/11/09 01:19 PM
Thanks for the clothes-pin idea. I'll give it a try when the skies clear up!
ETX-70AT(For the kids)
ETX-125AT(Delivered 1/7/09!)
Meade 26mm 400 Series Plossl
Meade 25mm MA
Meade 9mm MA
Criterion A.R. 18mm(No idea what this is except it's an 18mm)
Criterion Ortho 6mm(Ditto)
Criterion A.R. 9mm(Ditto)
BobH
Reged: 01/03/08
Loc: PA
      #2858514 - 01/11/09 04:31 PM
Bob
Now my problem is how to get the knob off.
Scoptronix flex focuser arrived today. Supplied hex key does not fit existing focuser knob set screw. No key I have fits. Appears to be stripped. I've never had it off, but the scope was returned to Meade once for repairs.
What to do?
Meade 8" LX200 GPS
ETX 125 PE
Tasco 50mm x 600mm
Orion Astroview 100
0 registered and 6 anonymous users are browsing this forum.
Moderator:  Shadowalker, oldsalt
