Announcements and News >> Discussion of CN Articles, Reviews, and Reports
Pages: 1 | 2 | 3 | (show all)
asaintAdministrator
Reged: 04/25/03
Astro-Tech Voyager Mount
      #2857369 - 01/11/09 06:20 AM
Astro-Tech
Tom TrusockAdministrator
Reged: 02/26/02
Re: Astro-Tech Voyager Mount new [Re: asaint]
      #2859887 - 01/12/09 10:12 AM
Nice review Jason!
Jason BAdministrator
My wife says I am Obsessed...
Reged: 06/21/04
Loc: Mid-Michigan
Re: Astro-Tech Voyager Mount new [Re: Tom Trusock]
      #2859979 - 01/12/09 11:20 AM
Thank you!
JimMo
I'd Rather Do It Myself
Reged: 01/08/07
Loc: Under the SE Michigan lightdom...
Re: Astro-Tech Voyager Mount new [Re: Jason B]
      #2860759 - 01/12/09 05:46 PM Attachment (126 downloads)
Hi Jason,
Great review. I was tempted to write a review myself on the Voyager I've had for about a year and I agree that it's an awesome grab and go set up. As for the height, I opted to use a CG5 tripod which gets the scope up far enough for me to stand while observing. I just need to bend over a little bit to see to the zenith.
Geo557
Astro-Scout
Reged: 10/10/07
Loc: SE GA
Re: Astro-Tech Voyager Mount new [Re: JimMo]
      #2860944 - 01/12/09 07:13 PM
Very good informative review Jason. Ideal G&G mount. I plan to own one someday.
Robo-bob
Reged: 05/02/05
Loc: Central Alberta
Re: Astro-Tech Voyager Mount new [Re: Geo557]
      #2860973 - 01/12/09 07:25 PM
Would this be a good mount for a 4" F6 refractor? I have tried a bunch of alt.az. mounts only to be disappointed by the
motions and the vibrations. I really want something that will be reasonably stable and still keep vibrations under 1 second with a sharp rap to the tube. What do you all think?
I could also put the mount head on a beefier tripod if that would give me the desired result.
Rob
TONGKW
Reged: 01/16/07
Re: Astro-Tech Voyager Mount new [Re: Robo-bob]
      #2861089 - 01/12/09 08:29 PM Attachment (97 downloads)
I occasionally mount my TSA102 (102 mm f/8) on the Voyager for a quick look. The set up is usable but unfortunately as the center line of the refractor OTA is offset to one side I am a bit scared of the stability problem so I always stand by the side for fear of tipping over in case some enthusiastic viewer might give it an accidental nudge.
K W TONG
C8 + CG-5GT, TSA102 + HEQ5 PRO, MK67 + Voyager Mount, WO ZS 80FD + Kenko NES, NexStar 6SE, WO Megrez 72 + Mizar K Mount, Mini Borg 50, C5, PST
TONGKW
Reged: 01/16/07
Re: Astro-Tech Voyager Mount new [Re: TONGKW]
      #2861092 - 01/12/09 08:30 PM Attachment (103 downloads)
The Voyager is actually more stable for mounting short length OTA such as the C8
Reged: 06/21/04
Loc: Mid-Michigan
      #2861271 - 01/12/09 09:45 PM
Thanks guys! This is my first "real" review so I appreciate the feedback.
Reged: 06/21/04
Loc: Mid-Michigan
      #2861283 - 01/12/09 09:50 PM
Rob
Depends on what 4" F6 it is. My 3" F8 is about the same length. I would guess the slight weight difference wouldn't be much. If it's a smaller, lighter OTA like the Orion 100mm F6, it should be fine in the 1-2 second range. A heavier triplett APO might be slightly worse but not much. With my 6" F5, it is still 1-2 seconds on the grass so I can't imagine it would be any worse than that.
dvb
different Syndrome.
Reged: 06/18/05
Loc: Vancouver, Canada
      #2861393 - 01/12/09 10:57 PM
An excellent review.
The movements aren't buttery smooth like an EZTouch, but that means that balance is not as critical, which helps. The slo-mos are also a plus.
I bought mine to mount a C6, but last time had the ED100 f/9 on it. The mount worked well with both -- but the tripod is too short!
I have considered the available extender, but will probably look for a CG-5 or a wood compatible tripod.
DLB242
Mr. Warmth
Reged: 07/29/08
Loc: Pen Argyl, PA
Re: Astro-Tech Voyager Mount new [Re: dvb]
      #2862998 - 01/13/09 07:07 PM
Ditto to the nice review. I usually observe seated even for grab and go. Right now I am using a Stellarvue M1 mount on a home made wooden tripod with my 80mm scopes. But 80mm is about the upper limit for this mount so I am looking for an Alt Az for my 102mm f/8.7 SV102BV. Doesn't sound encouraging so far.
Reged: 06/21/04
Loc: Mid-Michigan
Re: Astro-Tech Voyager Mount new [Re: DLB242]
      #2863192 - 01/13/09 08:51 PM
Thanks guys!
paul hart
Reged: 06/01/04
Loc: Lawn Guyland, New Yawk, Earth
      #2868810 - 01/16/09 12:09 PM
Jason,
Thank you also. I was on the fence about getting a Voyager, and after reading your review, I ordered one.
AstronomicsAdministrator
Vendor if you must, AKA The Mighty Kong.
Reged: 06/07/04
Loc: Right Here
      #2869226 - 01/16/09 03:18 PM
It will most certainly take more then an 80mm scope. No worries.
Chris Schroeder
Reged: 12/11/04
Loc: N.E. WI Sky Glow
Re: Astro-Tech Voyager Mount new [Re: Astronomics]
      #2869437 - 01/16/09 05:11 PM
Great review Jason
Chris Schroeder
Reged: 12/11/04
      #2869445 - 01/16/09 05:15 PM
Hi David, I used my 102ED F7 on this mount and felt the mount the could handle the weight, changing the tripod legs to wood ones would increase the stabilty for a heavy scope such as yours.
Reged: 06/21/04
Loc: Mid-Michigan
Re: Astro-Tech Voyager Mount new [Re: Chris Schroeder]
      #2869530 - 01/16/09 05:56 PM
Thanks Chris and Paul!
I agree with Mike on the assertion of taking more than an 80mm scope. My 6" F5 rides very nice on this mount. The only thing I would worry about is if it was a really long scope, such as an F10 4". The moment arm might lengthen the time the vibrations dampen out by a second or so. Some wouldn't mind it, some might. YMMV as they say.
I will try it one of these nights if it ever clears in mid-Michigan with one of my larger refractors. I'd do it tonight but I have a new MX7C to try out and it's actually clear!
Reged: 06/21/04
Loc: Mid-Michigan
      #2869534 - 01/16/09 05:58 PM
Paul,
It will be a great match for the 127mm Starmax if that is the scope you intend to use it for!
paul hart
Reged: 06/01/04
      #2869786 - 01/16/09 08:06 PM
Paul,
Yes that it will be used for primarily. It's going to fly with me to New Mexico in June. Plus I have a small car and want to take it to my brother's place in northern Michigan.
1 registered and 5 anonymous users are browsing this forum.
Moderator:  droid, iceblaze
