Telescope Specific Forums >> Meade ETX
1_old_dog
Reged: 09/07/07
Loc: Smoky Mnts
Re: Manual Micro-focuser for ETX-125PE ?? new [Re: BobH]
      #2858610 - 01/11/09 05:10 PM
I had this problem with one of my ETX's.
My solution was to sacrifice a very small (cheapy) screwdriver. I used a file and sharpened the driver end so it fit the hex hole. With a little twisting pressure on the screwdriver, being careful not to damage anything the hex screw came out.
OD
old stuff but good stuff
http://chu65nang67.us/nam/vietnam.html
BobH
Reged: 01/03/08
Loc: PA
Re: Manual Micro-focuser for ETX-125PE ?? new [Re: 1_old_dog]
      #2858649 - 01/11/09 05:26 PM
Well, I tried to get back here and delete my post before someone answered, but for an Old Dog, you're pretty fast.
I solved the problem with a 1/16" titanium drill bit.
Flex focuser is now installed and based on observing a distant neighbor's lamp post, works pretty well.
I believe it will be a good solution to fine focusing and the shakes in general.
In case i ever want to reintall the original knob, where on earth would I find a replacement set screw?
bob
"Wise men learn more from fools than fools from the wise." - Cato the Elder
Meade 8" LX200 GPS
ETX 125 PE
Tasco 50mm x 600mm
StellarVue 115ST on MiniTower
Orion Astroview 100
Celestron 8x42 Outland LX
'03 Harley FXDL (oops, wrong forum)
1_old_dog
Reged: 09/07/07
Loc: Smoky Mnts
      #2858771 - 01/11/09 06:18 PM
I'm glad you found a solution.
OD
Reged: 07/06/07
Re: Manual Micro-focuser for ETX-125PE ?? [Re: BobH]
      #2859740 - 01/12/09 08:03 AM
Now my problem is how to get the knob off.
Scoptronix flex focuser arrived today. Supplied hex key does not fit existing focuser knob set screw. No key I have fits. Appears to be stripped. I've never had it off, but the scope was returned to Meade once for repairs.
What to do?
There should have been a little Allen wrench shipped with the ETX. If you can find that, try that.
Uncle Rod
Rod's New Book:
Choosing and Using a New CAT
Available now!
1 registered and 3 anonymous users are browsing this forum.
Moderator:  Shadowalker, oldsalt
