Telescope Specific Forums >> Meade ETX
werewolf6977
Lord High Smasher
Reged: 12/15/03
Loc: Hanover, Ohio
Re: Meade new [Re: Michael Cox]
      #2850140 - 01/07/09 07:56 PM
I'm going to move this to the ETX forum, but if the ccd doesn't work thru the ota, what use is it?? Sounds like a marketing ploy to me, IMHO.
Pete
6" Apogee/LXD55
Starhopper 6" Dob
Spaceprobe 130EQ
Black C8 OTA
WO Zenith Star 66 Patriot Edition
Sun Pak Pro 7500 Platinum Edition
8X42 Bushnell H2O Porro
7X35 Tasco
10X50 Nikon Actions (Type 7)
15X70 Skymasters
Dell Inspiron Dual Core 531s
"Science without Religion is lame, Religion without Science is blind" A.Einstein.
Solar Ken
Reged: 02/07/06
Loc: Oregon
      #2850348 - 01/07/09 09:34 PM
I also thought about a pre-order in early December, and after reading about how the camera really works, I decided otherwise. The idea of doing astro-imaging without a laptop seemed appealing. Too good to be true in this case.
Astronomics web site has the best description of this scope I've found. The standard Meade jargon found on most other sites, plus lots more.
Daytime:
Coronado PST Ha
Lunt LS60THa/B600C
Nighttime:
Meade LX90 SCT 8"
Orion XX12 Intelliscope Dob 12"
meltdown
newbie
Reged: 07/25/06
      #2864198 - 01/14/09 11:48 AM
The ccd camera doesn't go through the tubes optics!
It has it's own (small) lens. It's like a piggyback webcam.
Don't expect much from it.
Edited by meltdown (01/14/09 11:50 AM)
Starlighter
Reged: 08/03/07
Loc: Sunny California
Re: Meade new [Re: meltdown]
      #2864287 - 01/14/09 12:25 PM
Well, in order to go through the tube optics, they'd have needed to install a flip mirror or some prism gizmo that would send the image to two sources at once. (The latter not being a good idea)
Hopefully, S&T or some astronomy mag will do a full review. I have a friend who attended CES and he told me they really had no way to demo it since it was inside a building during the daytime. He also said it looks all to be all made of plastic.
Celestron C4-R 102mm achromat
Celeston Nexstar 6SE SCT
Meade 80mm APO Triplet
Televue NP-101
Televue TV-85
Vixen A70Lf
Vixen A80Mf
William Optics 66mm Zenithstar Patriot
Celestron CG4 EQ mount
Orion Skyview Pro AZ mount
Vixen Portamount
Reged: 07/06/07
Re: Meade new [Re: Starlighter]
      #2866159 - 01/15/09 08:05 AM
I doubt it, especially since Meade intends to use this mount for larger OTAs. Looking at the Meade ETX125 PE, you'd think "all plastic" as well, but the fork is actually aluminim; the plastic is just an outer covering. Same goes for many of Celestron's telescopes.
Uncle Rod
Rod's New Book:
Choosing and Using a New CAT
Available now!
jgraham
Reged: 12/02/04
Loc: Dayton, Ohio
Re: Meade new [Re: rmollise]
      #2866288 - 01/15/09 09:45 AM
I thought the same thing about my original DS-2130. From what I could see (and the price) I assumed the mount was all plastic. I was pleastantly surprised to find the single-arm fork assembly was a finished aluminum casting. It has proven to be very solid and stable.
-John
Homebuilt scopes from 4.25-16.5"
Meade LXD75-N6/SN6/SC8, DSX-90, ETX-60BB, ETX-125PE, DS-2130
Orion StarBlast, BinoViewers, Coronado PST
Rebel XT/XTi, DSI Pro (I, II, & III), DSI, LPI, Electronic Eyepiece, Phillips SPC900NC
Tasco 60mm Refractors
Jim10
newbie
Reged: 10/07/08
Re: Meade new [Re: star drop]
      #2914257 - 02/07/09 09:37 PM
The present meade GOTO system seems to rely on Magnetic north for it's alignments. If this the case for the new scope, it will still have the magnetic North declination problems of the original ETX's. That is, the farther north the observing site, the farther east or west the scope will think the aligning star is located. For the US, this could be errors in the tens of degrees. The inexperienced will still have to learn their stars and constellations to use something with that magnitude of error.
Edited by Jim10 (02/07/09 09:59 PM)
Starlighter
Reged: 08/03/07
Re: Meade new [Re: Jim10]
      #2914276 - 02/07/09 09:48 PM
It also has a huge center obstruction. That I don't like. The CO on my 6SE is big enough. Looking at the full moon I can sometimes see it as a lack of contrast in the middle.
Properly corrected ED and APO refractors are far better for viewing the moon.
Televue NP-101
Televue TV-85
Vixen A70Lf
Vixen A80Mf
Vixen Portamount
pullin-gs
Reged: 11/18/07
      #2914842 - 02/08/09 09:09 AM
Why?
Does not the alignment process (two stars) line things up?
My goto is spot-on.
Cheers
jgraham
Reged: 12/02/04
Loc: Dayton, Ohio
Re: Meade [Re: pullin-gs]
      #2914982 - 02/08/09 10:44 AM
This should only affect the initial guess where the Autostar thinks the alignment stars are located. If you center the alignment stars as instructed it should work fine.
-John
0 registered and 6 anonymous users are browsing this forum.
Moderator:  Shadowalker, oldsalt
