PGW Steve
Reged: 10/03/06
Loc: Winnipeg, Canada
EQ6 Pro/Atlas in -30C weather........works fine!!!
      #2954163 - 02/28/09 01:02 AM
Yesterday I had my EQ6 Pro outside in -30C weather for about 5 hours. I was photographing Lulin as well as some random galaxies, some shots unguided and some guided with PHD. My exposures were 3-4 minutes and I'm happy to say that the mount, even with it's factory lube job, tracked fine and yielded nice round stars at ~400mm focal length. I did have a Kendrick hand pad heater on and it helped, but the numbers on the display are verrrrrry lazy and you have to warm up the LCD with your hand if you want to see it change digits.
I've used my 1200GTO in very cold and had been reluctant to try the EQ6 because it's made 'over yonder', I'm glad I gave it a chance because not it can impress me in the cold as much as it does in the warm. I will say that the alt ajustments suck big time and I'm working on a serious upgrade, stay tuned......
marktownley
Reged: 08/19/08
Loc: West Midlands, UK
Re: EQ6 Pro/Atlas in -30C weather........works fine!!! new [Re: PGW Steve]
      #2954299 - 02/28/09 04:27 AM
I had the same problem with the display on mine being sluggish in low temperatures - rest of the mount was greta tho!
TheMenace
Reged: 10/21/08
Re: EQ6 Pro/Atlas in -30C weather........works fine!!! new [Re: marktownley]
      #2954314 - 02/28/09 04:53 AM
Mine lost it's alignment after a couple hours at below zero temperatures.
My power supply is a little under rated though.
Ed B
Reged: 08/29/07
Loc: Geneva, Illinois, USA
Re: EQ6 Pro/Atlas in -30C weather........works fine!!! new [Re: TheMenace]
      #2954705 - 02/28/09 11:11 AM
I have my mount on a pier outside and this winter I fired it up at -29F. It worked but was really slow and labored. At a balmy -15 it work perfectly.
Ed
20 registered and 32 anonymous users are browsing this forum.
