Privacy Policy |
Please read our Terms
of Service | Signup and
DFEmery
Reged: 05/09/08
Loc: Maine
GOTO using CCD reference?
#2955247 - 02/28/09 05:07 PM
Hard to know exactly where to post this question... but is anyone aware of a GOTO mount, with appropriate software, that uses CCD images to improve pointing and tracking accuracy? What I mean is... if a CCD image is captured through a telescope and that image is compared to an existing image database, it would seem logical that it would be a fairly straightforward matter to correct pointing and tracking errors and fix the exact scope coordinates with great accuracy. Is there some system available to amateurs that will do this?
--Dave
jrcrilly
Refractor wienie no more
Reged: 04/30/03
Loc: NE Ohio
Re: GOTO using CCD reference?
[Re: DFEmery]
#2955270 - 02/28/09 05:15 PM
TheSky6 plus either CCDSoft or Maxim/DL and a CCD camera provides that functionality with nearly all goto mounts.
Miguel Lopes
Reged: 01/04/07
Loc: Portugal
[Re: DFEmery]
#2955280 - 02/28/09 05:21 PM
Yes there is, but it takes some €€€ and a lot of patience. You need something like: #1 - Pinpoint for astrometric measures. That will read your CCD images and calculate the location, sampling and rotation #2 - A CCD controlling application like Maxim or CCDSoft that supports automation #3 - An application to orchestrate all that, like CCDAutopilot or ACP #4 - A mount that accepts sync commands(?). Or a TPoint model for TheSky6 (?)
I'm still trying to do that myself, so a lot of question marks...
jrcrilly
Reged: 04/30/03
Loc: NE Ohio
[Re: Miguel Lopes]
#2955287 - 02/28/09 05:29 PM
I've done it without Pinpoint (though, when using Maxim, I do use the included PinPoint Lite) or a separate control application (though I intend to incorporate one later for greater automation). No TPoint model is required and Synch can be used or not used. TheSky6 Pro plus either CCDSoft or Maxim/DL suffices.
Setup is, as you mention, fairly involved.
hersey0308
Reged: 12/04/08
Loc: Ontario Canada
[Re: DFEmery]
#2955326 - 02/28/09 05:54 PM Attachment (26 downloads)
hi dave - maxpoint is a fairly low cost addition to maxim dl that will use a ccd camera to automatically improve pointing. a few caveats: i still like to do this manually or at least nearby because on automode the scope is slewing all over the place (as it should), but i get nervous about a cable getting caught up. screenshot attached. nice interface and pretty easy to use as well. the modeling file .clb will interface with Astronomer Control Panel and probably a few other programs. best, david
JAT Observatory
NOT a Wimp
Reged: 02/20/05
Loc: In the Primordial Soup
[Re: DFEmery]
#2955338 - 02/28/09 06:00 PM
Once you begin use plate solving to accurately point your mount you'll find it very hard to go back to not using it. I currently use Pinpoint with CCDSoft under control of CCD Autopilot.
As John mentioned TPoint is not required, but I since I use TheSky to control my mount I also use TPoint in order to get the initial pointing as close as possible. That results in no plate solve corrections in some areas of the sky for my setup.
I used a program called AAG Automapper to build my TPoint models. The AAG software uses plate solving to build very accurate TPoint models.
InterStellarGuy
Reged: 06/25/08
Loc: Nebraska
[Re: DFEmery]
#2955539 - 02/28/09 08:10 PM
the Meade ETX-LS coming out soon is said to use its CCD Eclipse imager for that very function, for alignment.
30 registered and 38 anonymous users are browsing this forum.
