InterStellarGuy
Reged: 06/25/08
Loc: Nebraska
CG5GT and powertank
#2953982 - 02/27/09 10:22 PM
I have acquired a bunch of new equipment recently including the CG5 ASGT mount and I am aware it uses more power then the alt az mount.
I have the CG5, a Orion Deep Sky imager Pro, and a laptop that will all need power. I currently have a Celestron power tank 7 and was thinking of acuqiring the 17 and having the Mount as well as the camera running off the 17, and the laptop on the 7. would this work, or am i going to need more juice?
Patrick
Reged: 05/16/03
Loc: Franklin, Ohio
Re: CG5GT and powertank
[Re: InterStellarGuy]
#2954059 - 02/27/09 11:18 PM Attachment (31 downloads)
I think you would be more comfortable with a little more power. You might consider a 12 volt, 33 amp hour wheel chair battery which cost about $80. Not too big, but lots of power.
Patrick
InterStellarGuy
Reged: 06/25/08
Loc: Nebraska
[Re: Patrick]
#2954117 - 02/28/09 12:15 AM
umm doesnt look like it has any plugs to plug stuff in
Fred1
Reged: 09/19/07
Loc: Somewhere in the Orion Spur
[Re: Patrick]
#2954127 - 02/28/09 12:27 AM
You might find the link below very helpful, too. After you access the link, scroll down to "What size battery should I get?" Find out the power requirements for your equipment. For example, simply speaking, figure the CG5 runs at around 2 amps, so your 7Ah battery will last about 3.5 hours more or less for the CG5 alone. The 17Ah about 8 hours, again, just for the CG5. The 33Ah that Patrick suggests is nice, but be sure you have an understanding of all of your equipments' power requirements. http://www.dewbuster.com/faq/2_batteries-power.htm
InterStellarGuy
Reged: 06/25/08
Loc: Nebraska
[Re: Fred1]
#2954151 - 02/28/09 12:53 AM
yea accept that doesnt look like a battery you can actualy plug into something :P lol
I think he was joking with me
Edited by InterStellarGuy (02/28/09 01:18 AM)
Reged: 07/06/07
#2954438 - 02/28/09 08:24 AM
This will work IF...you do very little go-to slewing and/or don't observe very long. A 17ah is the minimum for this very power hungry mount _and it does not like to share_...
Reged: 07/06/07
#2954441 - 02/28/09 08:26 AM
Well, no. But the cure is simple. Trot to your local automotive/sporting goods store where you will find a Thing with two alligator clips and a female cigarette lighter receptacle. Just be careful to clip positive to positive and negative to negative and you will be fine.
Skylook123
Reged: 04/30/05
Loc: Tucson, AZ
#2954483 - 02/28/09 08:58 AM
I agree with Patrick's recommendation. With a laptop, the draw may be enough among all the piece parts to demand more reserve than a 17 Ah supply.
Do a little surfing over in the Equipment forum; going back a year or two there are several threads on power sources. Some are enclosed in a box with bells and whistles like the Celestron/Orion 17Ah units, some have been home build to enclose large capacity supplies with recharging and other utilities built into the box.
I used the 17Ah Orion power supply, and for visual use with a computer attached and frequent gotos I would only get about four hours of use at most. The big draw is the computer. Later I found some tricks to do to the laptop to triple the life on its own battery, so all the power tank now runs is the mount. Setting up your display and power functions in the computer will greatly reduce your needs. My laptop now runs almost 8 hours on the internal battery only, and I bought a spare to go with me on weekend star parties so I only have to charge it from the truck during daytime.
Visual use of the mount with lots of gotos is also pretty taxing. So is using my mount for satellite tracking. Can't do much about that except a deeper supply. But with the photography, the mount draw should be low with the variable being the draw of the imaging and guiding equipment.
In any event, I'd go surfing for a deeper supply than the 17Ah; start with the Equipment forum. Lots of information there.
Patrick
Reged: 05/16/03
Loc: Franklin, Ohio
#2955001 - 02/28/09 02:16 PM Attachment (27 downloads)
Me??? Nah.
Seriously, here's what you need to make it work...available at Radio Shack. I actually use the 33 amp hour battery alone to power my mount. I have two 6 volt 220 amp hour golf cart batteries wired in series to provide 12 volts for all the other accessories.
Patrick
InterStellarGuy
Reged: 06/25/08
Loc: Nebraska
[Re: Patrick]
#2955012 - 02/28/09 02:25 PM
Is there a way to recharge it?
Patrick
Reged: 05/16/03
Loc: Franklin, Ohio
#2955046 - 02/28/09 02:48 PM
Sure. You can get battery chargers a lot of different places...Sears, Tractor Supply, etc.
This is the One I use which uses 3 stage charging.
I learned the hard way the importance of keeping ANY battery properly charged, even the Power Pack kind of batteries. You can't use them and then neglect them unless you want a permanently dead battery. Good batteries are too expensive to not maintain them. Even though I don't use my batteries much over the winter, every month they're put on the charger for a tuneup.
Batteries can be a whole big subject all by themselves.
Patrick
dickbill
Reged: 09/30/08
[Re: Patrick]
#2955370 - 02/28/09 06:18 PM
My suggestion is to keep the battery for the CG5, for everthing else, laptop, dsi and usb adaptors (that have to be powered too) use....extension cords. I got a 150 feet of them, it's too complicated otherwise.
