daniel_h
Reged: 03/08/08
Loc: VIC, Australia
Vixen polaris drive help
#2959387 - 03/02/09 05:17 PM
Hello, I am about to acquire a 1986 vixen polaris EQ mount, but cannot find if i can get a RA motor drive for it. Does anyone know what type of drive / where i could get one thankyou
mathteacher
Reged: 05/13/07
Loc: Oakland, CA
Re: Vixen polaris drive help
[Re: daniel_h]
#2959777 - 03/02/09 08:57 PM
What is your purpose? Just for visual or AP?
I would contact Vixen.
JMI sells an AC motor for Right Ascension. It it listed under "celestron polaris" on this link: http://www.jimsmobile.com/buy_ra_motors.htm#Celestron I use this motor on my super polaris to make the unguided shots in my gallery.
Ron359
Reged: 04/21/08
Loc: Evergreen, CO. USA
[Re: daniel_h]
#2959800 - 03/02/09 09:08 PM
I have a celestron-vixen SP mount from that era and put an Orion true track drive motor on it. I have the dec motor too but havent gotten around to mounting it. I think the celestron motor kits are similar. It was fairly easy to adapt by drilling a hole in through the back side of he altitude part of the head to put the RA motor mounting bolt through. Your mount may already have that. You can get the Vixen motor and drive control, but it costs over 200 bucks if I remember right. HTH Ron
daniel_h
Reged: 03/08/08
Loc: VIC, Australia
[Re: Ron359]
#2959876 - 03/02/09 09:55 PM
the purpose is for camera lens astrophoto, have not had luck contacting vixen dealers so far - i think the motor is an MD-5
mathteacher
Reged: 05/13/07
Loc: Oakland, CA
[Re: daniel_h]
#2959884 - 03/02/09 09:59 PM
I assume you are taking wide shots of the sky, then. I think the JMI drive will work for you.
John Carruthers
Skiprat
Reged: 02/02/07
Loc: Kent, UK
[Re: daniel_h]
#2960243 - 03/03/09 03:19 AM
The Vixen MT1 is original equipment but any of the eq5 144 tooth drives can be made to fit with some degree of surgery. Alan does a full goto conversion if you have the wonga http://www.awrtech.co.uk/ih/ih_eq5.htm
Skywatchr
Reged: 06/03/06
Loc: North-Central Pa.
[Re: daniel_h]
#2962947 - 03/04/09 10:51 AM Attachment (33 downloads)
The original RA motor was an 8 pin Vixen motor and uses the MD-6 Single Axis controller. JMI used to make a DEC motor and an add-on controller that screwed to the top of the MD-6 for dual-axis control. I have a spare motor, but no spare controller.
Jeff
Skywatchr
Reged: 06/03/06
[Re: Skywatchr]
#2962951 - 03/04/09 10:52 AM Attachment (34 downloads)
The coupler end.
johnfdean
Reged: 06/04/06
Loc: southern tip of Illinois
[Re: daniel_h]
#2964277 - 03/04/09 09:53 PM
I have Polaris on my C-6. I put a drive for an EQ 3 on it. It works well.
