JimWaterford
Reged: 01/20/09
Can you mount 9.25" Celestron SCT on MiniTower?
      #2999133 - 03/22/09 10:48 PM
I realize a 8" optical tube would be no problem but will a 9.25" tube be OK? I really do not want to push the MiniTower beyond its capabilities. The MiniTower is great so far with my 4" refractor. Thank you & Best Regards, Jim
Mlehere
Reged: 07/06/04
Loc: NE Ohio
Re: Can you mount 9.25" Celestron SCT on MiniTower? new [Re: JimWaterford]
      #2999621 - 03/23/09 08:56 AM
Jim:
This can be done with the 9.25 but modifications to the mount are reccomended. I sent my mount to Trapezium Telescopes in NH and had the bearings replaced with Timken bearings, grease change, gears lapped and field tested. This makes a significant difference in the performance of the mount and increases it capacity. Cost was $300 but entirely worth it.
Telescopeman54
Vendor - Trapezium Telescopes & Services, LLC.
Reged: 08/17/07
Loc: New Hampshire
Re: Can you mount 9.25" Celestron SCT on MiniTower? new [Re: Mlehere]
      #2999675 - 03/23/09 09:42 AM
Mike is only one of a number of people that have been using a C9.25 with their Mini Tower. We have at least 8 - 10 other clients that are quite happy with that set up. So, yes, it will work.
At the WSP we even mounted a C11 on the Mini Tower. It was a bit much for the stock mount, but, once we replaced the bearings the owner noticed a huge difference in stability and accuracy.
CS
Steve
27 registered and 25 anonymous users are browsing this forum.
