Privacy Policy |
Please read our Terms
of Service | Signup and
David Pavlich
Transmographied
Reged: 05/18/05
Loc: Mandeville, LA USA
Gemini and warm restart...
#3020457 - 04/02/09 05:19 PM
I usually do a warm restart, however, when I slew to an object and if's off a little, I center it, but when I goto "Align Telescope" the only option is to Sync. Question: If I Sync it remembering that it's a warm restart, will it cancel my pointing model?
The reason I ask is that on a Cold Start, anytime you select sync, it's like starting over.
Thanks! David
f29pc
Reged: 05/23/05
Loc: Maine
Re: Gemini and warm restart...
[Re: David Pavlich]
#3020535 - 04/02/09 06:08 PM
David, after a warm restart and pressing Sync should only sync the current model to where the scope is. When you do a cold start it wipes out any modeling and starts over. Paul
David Pavlich
Transmographied
Reged: 05/18/05
[Re: f29pc]
#3020558 - 04/02/09 06:20 PM
Thanks, Paul! I figured that was the case, but I didn't want to have to do the alignment over.
David
HunterofPhotons
Reged: 04/26/08
Loc: Rhode Island, USA
[Re: David Pavlich]
#3021830 - 04/03/09 11:50 AM
.... I figured that was the case, but I didn't want to have to do the alignment over.....David
Don't worry about losing a model. A flawed model is worse than no model. I would be concerned about losing a perfect model like Heidi Klum, but who wouldn't? I used to image at long focal lengths with a Gemini. It only took me 5 minutes to make a new model that would center objects in the test image. The quality of your 'synchs' and 'additional aligns' is important, though. Use crosshairs to center your stars and a 5 star model will get you off and running. Doing a few aligns at the end of a night out will give you a widely-spaced model which, I believe, helps refine the model's accuracy.
dan
David Pavlich
Transmographied
Reged: 05/18/05
[Re: HunterofPhotons]
#3022557 - 04/03/09 06:09 PM
dan
That's exaclty what I do. That's why I like the Gemini. Last night, I did the Sync thing and it was fine. As it turns out, M64 was only off by the tiniest bit from center. I use a reticle ep for my star alignments. It's the only way.
David
23 registered and 39 anonymous users are browsing this forum.
