Privacy Policy |
Please read our Terms
of Service | Signup and
Mark Schulz
Reged: 09/06/04
I am building a kit dob and using a red Moonlite focuser. I'd like to carry the red color on somewhere on the rocker base or mirror box. Maybe a design on the mirror box cover or on the alt bearings. Does anyone know a source for red anodized sheet aluminum that I could use for this? Red paint would be possible but I'd like it to match that focuser better than that.
Thanks for the help!
Mark Schulz
-------------------- Mark Schulz
13.1" Tscopes Kit Dob
TV 85
127mm Orion mak
Denk II and Denk Standard Binoviewers
MMICKELS
Aluminum Knight
Reged: 01/20/04
Loc: The Land of Shake and Bake
Mark, you would need to have it plated afterwards. I know of no one selling red anodized aluminum sheets.
"The only thing wrong with immortality is that it tends to go on forever."
Herb Caen
John Jarosz
I'm being watched...
Reged: 04/25/04
Loc: Chicago area, IL
Dr Mickels is correct.
Aluminum is mainly anodized so that there is no long term oxidation, precision fits remain the same, and the aluminum surface is harder. Anodizing is an electrical process and the entire exposed surface of the part becomes coated. The coating is essentially clear(and extremeely thin), although without any colorization the aluminum turns a darkish grey. The exact grey is determined by the exact alloy of aluminum and the temperature of the anodizizing process. Coloring is done after anodizing by dying the color into the coating. So even if you had the exact same alloy as the parts you are trying to match, you would also need to match the dye as well. I know of no pre-anodized material, as machining any part of it would expose the base aluminum, thus negating most of the benefits of the process.
John
-------------------- 6" F4.6(w/Paracorr) GEM reflector, 8" F11 Dall Relay Scope
6" F5 RFT Refractor, Garrett Gemini 20x80 LW
Mark Schulz
Reged: 09/06/04
Thanks for the help. So what other possibilities would people suggest to add some red accents that would match the look of a red Moonlite focuser?
Mark
TV 85
127mm Orion mak
MMICKELS
Aluminum Knight
Reged: 01/20/04
Even the dye in plating will vary somewhat, so an exact match will be challenging.
Herb Caen
MMICKELS
Aluminum Knight
Reged: 01/20/04
Black contrasts nicely with red. Have a look at my black and red scope in the members gallery.
Herb Caen
13 registered and 11 anonymous users are browsing this forum.
Moderator: Don W, Joe Cipriano
