Pages: 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | 19 | (show all)
Jason D
Reged: 10/21/06
Loc: California
Useful info about secondary mirror alignment
      #3033065 - 04/08/09 10:14 PM Attachment (365 downloads)
When a laser collimator is used to achieve axial alignment, it aligns the focuser axis against the center of the primary mirror then aligns the primary axis against the center of the focuser. However, unless a holographic laser is used, the laser collimator (including barlowed laser) is not adequate to align the secondary mirror.
The secondary mirror alignment is different from the focuser axial alignment and primary axial alignment. Click and watch the following animation. In each frame, both the focuser and primary axes are aligned yet the secondary mirror alignment is all over the place.
When the focuser axis is aligned using a quality tool, you are guaranteed to see primary mirror concentric with the focuser edge (or the sight-tube edge). The primary center spot will be precisely centered in the focuser or sight-tube. This is true regardless of the primary axial alignment or the secondary alignment. A misalignment secondary will clip part of the primary mirror reflection which implies part of the light cone will also be clipped. The objective of the secondary mirror alignment is to position the secondary mirror in such a way to optimally intercept the light cone. Given a well-aligned secondary mirror, if you place your eye exactly at the center of the focuser and look down precisely along the focuser axis (a quality sight tube will help you position your eye in this manner), then you should see the whole primary mirror reflection. But that is not all, if you move your eye back and away from the focuser, you should get to a point where the primary mirror reflection edge will overlap with the secondary mirror edge. If you keep going, then the primary mirror clips will start to be clipped by the secondary mirror edge in “almost” at the same rate.
Here is a photo of a well-aligned secondary mirror.
XT10 classic with premium optics
Tri-knob CR2 with compression rings
Round Table Platform
4.5" StarBlast
6" StarBlast6
TV EPs
Jason D
Reged: 10/21/06
Loc: California
Re: Useful info about secondary mirror alignment [Re: Jason D]
      #3033067 - 04/08/09 10:15 PM Attachment (335 downloads)
Here is the same photo with overlaid lines and circles. Note the following:
1- Focuser and primary reflection edges are concentric and the primary center spot is centered under the focuser.
2- The secondary silhouette (secondary shadow) is pointing towards the primary mirror as indicated by the red arrow
4.5" StarBlast
6" StarBlast6
TV EPs
Jason D
Reged: 10/21/06
Loc: California
      #3033068 - 04/08/09 10:16 PM Attachment (219 downloads)
We can control 3 movements for the secondary mirror.
The first movement is along the OTA/UTA axis by loosening or tightening the secondary holder center screw. That is, moving the secondary mirror closer or away from the primary mirrior.
4.5" StarBlast
6" StarBlast6
TV EPs
Jason D
Reged: 10/21/06
Loc: California
      #3033070 - 04/08/09 10:16 PM Attachment (187 downloads)
The second movement is by adjusting the appropriate spider vanes thumb knobs to move the secondary holder towards the upper wall or the lower wall of the OTA.
4.5" StarBlast
6" StarBlast6
TV EPs
Jason D
Reged: 10/21/06
Loc: California
      #3033072 - 04/08/09 10:17 PM Attachment (206 downloads)
The third movement is called tilt/rotate which is accomplished by loosening the secondary mirror adjustment set-screws by a tad, rotate the secondary mirror by a tad, then finally adjust the set-screws to re-align the focuser axis. This is the key movement to point the secondary silhouette offset towards the primary mirror.
Note how the silhouette offset changes direction in the attached animation
4.5" StarBlast
6" StarBlast6
TV EPs
Jason D
Reged: 10/21/06
Loc: California
      #3033074 - 04/08/09 10:18 PM
Putting it all together:
After you finish collimation (at least the focuser axial alignment which is accomplished by adjusting the secondary mirror to place the primary center spot reflection under the cross-hairs of the sight tube), check the primary reflection and see how it is clipped. Then use the 3 movements mentioned in the prior posts until the whole primary mirror reflection is visible and the primary reflection and the secondary edges overlap as you move your head back.
IMPORTANT:
1- Do not evaluate the primary reflection clipping unless you have completed at least the focuser axial alignment step. That is, if the primary mirror center spot is not located under the cross hairs of the sight-tube, clipping visual information is false or unreliable.
2- Seeing the whole primary reflection is not enough. You need to move your head back until the primary reflection edge overlaps with the secondary mirror edge. You need to be looking through the sight tube during this evaluation
3- Do your best. Perfect secondary alignment is not necessary unless you have a relatively small secondary mirror.
Jason
4.5" StarBlast
6" StarBlast6
TV EPs
helpwanted
Reged: 07/04/07
Loc: Phoenix, AZ
      #3033159 - 04/08/09 11:24 PM
Jason... excellent thread!!!! nice animation!!!
this should be a required read for anyone buying a newt!
Dean Norris
Reged: 11/05/08
Loc: Santa Cruz, Ca
Re: Useful info about secondary mirror alignment [Re: helpwanted]
      #3033195 - 04/08/09 11:46 PM
Thank you Jason for your informative post. Your animations are great!
Dean
1971 10" Cave Newtonian F/6
MoonLite CR Focuser Telrad Finder 8x50 finder
TV 40mm, 32, 20, 7.4, Meade 6mm, UO 5mm, Meade 2x Barlow
7x50 Binoculars
Lamb0
Reged: 07/25/07
Loc: Fairbury, Nebraska
Re: Useful info about secondary mirror alignment [Re: Dean Norris]
      #3033258 - 04/09/09 12:19 AM
I likee! Please add a link to this thread in the "How to Collimate your Newtonian" sticky!
oalithgow
Reged: 08/16/08
Loc: Dominican Republic
Re: Useful info about secondary mirror alignment [Re: Lamb0]
      #3033374 - 04/09/09 01:56 AM
wow..!! Very nice and detailed explanation men' A++++
1000 Thanks!! put it on my favorite list.
-Orion 254mm f/4.7 Reflector Custom Dob. mount
-Orion 80ST
-32mm GSO plosl
-21mm hyperion, 14mm finetuning ring
-8mm Agena WA
-5mm Paradigm
-2" GSO ED barlow
senske
Reged: 01/10/09
Loc: Spokane, WA
Re: Useful info about secondary mirror alignment [Re: oalithgow]
      #3033378 - 04/09/09 02:02 AM
Excellent! Thank you Jason.
Andrew
Orion SkyQuest XT10 Intelliscope with Orion 9x50 and Telrad Finders
Orion WorldView 10x50 Binoculars
Celestron NexStar 8 SE with GSO 8x50 and Red Dot Finders
Galileoscope
14dobguy
Reged: 12/09/08
Loc: rhode island
Re: Useful info about secondary mirror alignment [Re: senske]
      #3033420 - 04/09/09 03:04 AM
ya man thats a really good thread...the annimation is a lot easier to understand too.good job!
Brian
14" dob
sky commander
jonstarrysky
Reged: 01/03/09
Loc: England, U.K.
Re: Useful info about secondary mirror alignment [Re: 14dobguy]
      #3033446 - 04/09/09 04:07 AM
Well done Jason, great posts !!
Re. your third movement, called tilt/rotate. Do you mean you 1st adjust sec rotation (by physically rotating the secondary holder with all set-screws loose). And only after that, go on to adjust the secondary tilt using the set screws. Some collimation guides have these as separate stages. Precise rotation (not tilt) is a tricky one to measure in my mind and I'd be interested in tricks to make it easier. One way may be to adjust the set screws to purposefully skew the secondary tilt towards/ away from the focusser, and then rotate the secondary holder to get the laser dot to line up in the direction of the focusser. This comes from a Glatter guide, but I havent tried it yet. Apologies if I am not interpreting that guide clearly. He says someting about "tipping" the secondary to do this.
Another way would be to photograph the secondary sillhoute tru a collmation cap, rotate the secondary a bit (eg clockwise), get all the tilts correct again, then re-photograph thru the collimation cap and see if the secondary sillhoute rotation has got better or worse. Labourious way ! Can you temporarily phycially attach something to the tip of the secondary holder to act as a guide for secondary rotation ? The apparent elliptical shape of the secondary sillhoutte is quite subtle to look at.
So if rotation is correct, in the picture in your second post of this thread, the apparent elliptical shape of the secondary silhoute should appear to point away from the focusser. In your diagram the secondary silhoute to my eyes is not pointing to the red arrow, it is noticably off (to the south). But still way better than the picture in my post, where mine is miles out !! Presumably if the secondary rotation is somewhat off it will typically have very little effect on the scope performance as long as its tilt is correct.
Orion XT10i
Televue eyepieces :-)
Assorted binoculars
Astro-Systems (U.K.) FG-1 6" reflector
jonstarrysky
Reged: 01/03/09
Loc: England, U.K.
Re: Useful info about secondary mirror alignment [Re: jonstarrysky]
      #3033610 - 04/09/09 07:58 AM
Re. the "second movement" as listed in post #4:
With my XT10i I begun by adjusting the spider vanes thumb knobs as indicated (obviously this is the sensible way to do it). I later found that when the secondary mirror set screws are loosened there is significant play in the lateral placement of the secondary holder (not to be confused with rotation or tilt). So depending on how you are holding the secondary when the 3 set screws are tightened, you can shift the lateral position of the secondary achieving the same effects as adjusting spider vanes. I was not happy that you can do this. Might have been because to get step "movement along the OTA/UTA axis" correctly done I had to substantially move the secondary mirror towards the primary mirror. This increases the length of the central thick screw that actually holds the secondary mirror to the spider and hence its wobble. Another explanation is that this big screw is near its end of its travel and is dangling near its last thread. I hope not !
Orion XT10i
Assorted binoculars
Jason D
Reged: 10/21/06
Loc: California
      #3033972 - 04/09/09 11:35 AM
Thank you everyone for the compliments
Jason
4.5" StarBlast
6" StarBlast6
TV EPs
Jason D
Reged: 10/21/06
Loc: California
      #3033975 - 04/09/09 11:36 AM Attachment (74 downloads)
You do not have to loosen all 3 set-screws. Loosen few just enough to allow you to rotate the secondary. The amount of tilt show be small – and I mean small.
If the silhouette is pointing downward, the I rotate the secondary in such a way to bring the upper edge of the secondary closer to me. If the silhouette is pointing upward, the I rotate the secondary in such a way to bring the lower edge of the secondary closer to me.
Should you tilt first then rotate or vice versa, I do not think it matters. Regardless, the final fine tuning will have to be done by adjusting the tilt.
I do not believe you need a camera. Use you best judgment and accept the final result. If the silhouette direction looks good enough, then forget about it and focus on getting the primary mirror reflection edge to overlap as much as possible with the secondary mirror edge. Again, do your best and accept the final result.
It is an eye illusion. The silhouette in my photo is circular (as it should be) and is actually pointing towards the primary mirror. See attachment.
Jason
4.5" StarBlast
6" StarBlast6
TV EPs
Jason D
Reged: 10/21/06
Loc: California
      #3034000 - 04/09/09 11:46 AM
Before you start adjusting the lateral position of the secondary, ensure the secondary silhouette is pointing in the right direction, first. When you start adjusting the lateral position, avoid rotating the secondary and adjust using the set-screws. That is, do not loosen the set-screws when adjusting the spider vanes thumb knobs. Always keep in mind: Secondary position evaluation should be done ONLY when the focuser axes is aligned – getting the primary center spot reflection under the cross-hairs of the sight-tube or getting the laser beam dead centered in the center spot. So, do not lateral shift and evaluate simultaneously. Shift then align focuser axis then evaluate.
Jason
4.5" StarBlast
6" StarBlast6
TV EPs
Dennis Sakva
Reged: 10/19/04
Loc: Kiev, Ukraine
      #3035453 - 04/10/09 04:23 AM
Jason, thanks for very useful thread. I find this secondary mirror adjustment the most confusing of all collimation process.
Could you please tell which error leads to which results. Like tilted focal plane, uneven vignetting, etc.
Jason D
Reged: 10/21/06
Loc: California
Re: Useful info about secondary mirror alignment [Re: Dennis Sakva]
      #3035954 - 04/10/09 11:32 AM Attachment (51 downloads)
Let us review collimation fundamentals. When we collimate, we strive to meet 3 different and independent alignments:
1- Focuser axial alignment calls for positioning the secondary mirror surface to reflect the focuser axis to the dead center of the primary mirror. A relatively sizable focuser axial error (FAE) will cause the primary focal plane to be tilted with respect to the eyepiece focal plane which prevents bringing the whole FOV to focus.
2- Primary axial alignment calls for positioning the primary mirror axis to center the primary focal plane in the focuser. A relatively sizable primary axial error (PAE) will introduce coma on-axis (in the middle of the FOV).
3- Secondary mirror alignment calls for positioning the secondary mirror to center the 100% illumination area in the center of the focuser to optimize field edge illumination. A relatively sizable secondary mirror alignment error will unevenly distribute and reduce the overall illumination across the FOV.
The first two are critical. The third (which is the subject of this thread) is not as critical for visual observation but could be critical for astrophotography.
The following illustrates PAE and FAE
The attachment illustrates the secondary mirror alignment error
Vic Menard’s addendum website has more interesting information about secondary mirror alignment.
4.5" StarBlast
6" StarBlast6
TV EPs
Starman1
Vendor - Scope City
Reged: 06/24/03
Loc: Los Angeles
      #3036423 - 04/10/09 03:32 PM
Jason,
One of the curious things about using a sight tube to gauge concentricity of secondary outline and focuser that I've run into with the telescoping sight tube from Catseye is that I have to adjust the length of the sight tube considerably shorter than the f/ratio template suggests in order to see the outline of the mirror.
If I set the sight tube using the template to the f/5 of my scope, I have to pull the sight tube several inches out of my focuser in order to see the entire secondary. On the other hand, if I adjust the sight tube to be a couple inches shorter (say, around f/3.5), I can fully insert the sight tube and still see the entire outline of the secondary.
That makes sense, since the secondary-to-focal plane distance will vary substantially, even at the same f/ratio.
The sight tube length should be related to the distance from secondary-to-focal plane (often referred to as the intercept distance) so that the perspective from the peephole to the front lip of the sight tube to the outer edge of the secondary all line up.
A few simple diagrams show this quite well.
Don Pensack
12.5" Truss Dob, 5" Maksutov, Fujinon Binos
Sustaining Lifetime IDA member
3 registered and 4 anonymous users are browsing this forum.
Moderator:  Don W, werewolf6977, Jason B
