Relativist
Reged: 10/11/03
Loc: OC, CA, USA
Tool to start out ATM'n new
      #303433 - 01/07/05 05:38 PM
What do you think of the dremel 400 as a tool to start out with? All of your projects have encouraged me to consider making my 10" a Truss, so I can get experience for when I build a bigger Dob.
......Curtis
.......Curtis
20mm T2 Nagler, 10mm SW 82degrees, 5-8 SW Zoom:
All of the above replaced with WO Binoviewers!!!
Siebert OCA 1.25x-3.5x
10" OPT Starhunter (flocked & upgraded focuser)
10x50 & 15x70 Celestron Bino's
2" 2x GSO Barlow
rboeAdministrator
Numbfinger
Reged: 03/16/02
Loc: Phx, AZ
Re: Tool to start out ATM'n new [Re: Relativist]
      #303561 - 01/07/05 07:47 PM
Well, not much. I've burned out one Dremel building pistol grips (which it did pretty good at by the way) but for building a scope all it's good for is deburring metal parts.
You'd be better off buying a cheap circular saw. And I don't think too highly of them!
What tools do you have now?
The most used tool in my kit is the cordless drill/screwdriver. Not too much good for scope building but how often do you build scopes compared to other chores around the house?
Ron
NS11GPS
Pronto
16" dob
15X70 Obies
MMICKELSAdministrator
Aluminum Knight
Reged: 01/20/04
Loc: The Land of Shake and Bake
Re: Tool to start out ATM'n new [Re: rboe]
      #303564 - 01/07/05 07:51 PM
Curtis, have you got a design in mind?
Mark
"The only thing wrong with immortality is that it tends to go on forever."
Herb Caen
Relativist
Reged: 10/11/03
Loc: OC, CA, USA
Re: Tool to start out ATM'n new [Re: MMICKELS]
      #303605 - 01/07/05 08:40 PM
No design in mind, I don't need anything fancy, just something quick to set up. As for the Dremel, it's the new model I'm thinking of. As for tools I already have, well I can borrow almost anything, but I'd like to have something versitile to make up the gaps. This is the set I'm thinking of:
http://www.dremel.com/HTML/products/tools/400-690.html
........Curtis
.......Curtis
2" 2x GSO Barlow
Tom L
Reged: 01/07/04
Loc: Sunny Oregon
Re: Tool to start out ATM'n [Re: Relativist]
      #303686 - 01/07/05 10:05 PM
I've never used a Dremel, Curtis... Do you think they are robust enough? My most used tool sfor my scope to date (in order of use):
Random Orbital Sander
Plunge Router
clamps
table saw
misc tools...
Tele Vue 102mm f/8.6 on an EzTouch
Vixen 80mm f/5 A80SSWT on a grab-n-go mount
15 registered and 14 anonymous users are browsing this forum.
Moderator:  Don W, Joe Cipriano
Home
