stuper
Reged: 09/12/08
Loc: Central California
Thickness of Aluminum Pier Plate
#3040281 - 04/12/09 06:42 PM
I'm planning to make a 12-inch diameter concrete pier for my 10" LX200. If I use aluminum for the pier plate, how thick should the aluminum be?
Telescopeman54
Vendor - Trapezium Telescopes & Services, LLC.
Reged: 08/17/07
Loc: New Hampshire
Re: Thickness of Aluminum Pier Plate
[Re: stuper]
#3040313 - 04/12/09 07:07 PM
1/2" to 3/4" should be more than enough.
Steve
stuper
Reged: 09/12/08
[Re: Telescopeman54]
#3040366 - 04/12/09 07:49 PM
I can save a few bucks with 3/8". Would that be thick enough?
fetoma
Reged: 09/26/06
Loc: Southern New Jersey
[Re: stuper]
#3040479 - 04/12/09 09:07 PM
I would go for an inch thick. 3/8 is too thin. How much weight is the scope and mount together? This is what I used but you can go smaller in diameter:
http://www.speedymetals.com/pc-2458-8368-12-rd-6061-t6511-aluminum-extruded.aspx
DeanS
Reged: 07/12/05
Loc: Central Kentucky
[Re: fetoma]
#3040485 - 04/12/09 09:15 PM
I did a 1/2" plate that was 12" x 12" and it was too thin. 3/4" was better, 1" would be even better. Also you may have to tap some threads in it and 1/2" would be more difficult to do.
Strgazr27
Reged: 10/04/04
Loc: StonyHill Observatory
[Re: DeanS]
#3040562 - 04/12/09 10:14 PM
Mine is 1" X 12" X 12" 7075 Plate Plenty strong enough.....
stuper
Reged: 09/12/08
[Re: Strgazr27]
#3044169 - 04/14/09 08:14 PM
Sorry, been away for a while. Thanks for the tips. I didn't realize extruded rod came in such large diameters. I was pricing it as flat plat, which is more expensive. I will get a 1" thick piece of 8" or 9" diameter rod. Is 6061-T6 sufficient, or should I get 6262-T6511 or 7075-T651 or something else?
fetoma
Reged: 09/26/06
[Re: stuper]
#3044198 - 04/14/09 08:32 PM
It all depends on what $$$ you want to spend. I used 6061, but 7075 is better, but more expensive.
stuper
Reged: 09/12/08
[Re: fetoma]
#3045212 - 04/15/09 11:55 AM
Frank, does yours made from 6061 work OK? How thick is it? What kind of scope/mount do you have on it?
Edited by stuper (04/15/09 11:56 AM)
fetoma
Reged: 09/26/06
[Re: stuper]
#3045280 - 04/15/09 12:35 PM
Mine is 1" thick 6061 with a CGE on top. Works just fine.
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/3024425/page/2/view/collapsed/sb/5/o/all/fpart/all/vc/1
DrBuck
Reged: 12/10/08
Loc: Susanville, No. Calif.
[Re: fetoma]
#3049847 - 04/17/09 08:32 PM Attachment (26 downloads)
My CGE is mounted on a one inch aluminum adapter plate that I had machined to fit the CGE base. I then drilled and tapped it to fit the screws and bolted it to my 3/4 inch stainless steel leveling plate with a 1/2 inch bolt.
Hank w
Reged: 09/10/08
Loc: Loveland, Colorado
[Re: DrBuck]
#3049906 - 04/17/09 09:18 PM
Try this link " http://www.sandsmachine.com/alumweb.htm "best price and perfect for a pier plate. I've made several with there product Hank
