Privacy Policy |
Please read our Terms
of Service | Signup and
Wave Vector
Reged: 04/01/06
ASGT Cg5 Alignment Question
#3047295 - 04/16/09 02:58 PM
Some objects are not in the center of the eyepiece when I use GOTO. if I use the hand controller to bring the object to center, do I have to preform another alignment?
Reged: 07/06/07
Re: ASGT Cg5 Alignment Question
[Re: Wave Vector]
#3047311 - 04/16/09 03:10 PM
No. You would only have to realign if you undid the locks and moved the scope manually. A number of things can help with "off" go-tos, but one which will do the most good is always using only the UP and RIGHT keys when doing final centering of the alignment stars.
Wave Vector
Reged: 04/01/06
[Re: rmollise]
#3047344 - 04/16/09 03:31 PM
Thank you Mr. Mollise
I really needed that information. I am going out tonight, it is first clear night in a number weeks
Fred1
Reged: 09/19/07
Loc: Somewhere in the Orion Spur
[Re: Wave Vector]
#3047554 - 04/16/09 05:10 PM
Also, be sure that the mount has completed its GOTO. Often it will appear that the mount has stopped, but if you check the LCD on the hand control you will see a rotating image in the upper right corner, which indicates the mount is still moving. Wait until the rotating image disappears before trying to precisely center with the UP and RIGHT keys as Uncle Rod says.
17 registered and 27 anonymous users are browsing this forum.
