MtnGoat
Reged: 02/18/07
Loc: Columbia Gorge, WA
Can an LXD75 run a teensy bit slow (or fast)? new
      #3054690 - 04/20/09 12:03 PM
I've been trying to figure out the source of a slight drift over time in my images.
I've got the polar nailed (pier mounted) and get the 'less than 5'' messages each time I do an alignment. This is supported by the fact that I get very little if any DEC drift over any period of time.
However I am getting RA drift, which to me seems to indicate a slight speed issue with the RA drive.
It is possible I need to dial the RA drive speed up or down a percent or two? (haven't analyzed if it appears fast or slow yet, I just know I have RA drift).
Is this something I would deal with using the 'tracking rate' field in Autostar, or by changing the gear ratio a tiny bit?
JAT Observatory
NOT a Wimp
Reged: 02/20/05
Loc: In the Primordial Soup
Re: Can an LXD75 run a teensy bit slow (or fast)? new [Re: MtnGoat]
      #3054803 - 04/20/09 12:41 PM
There is a menu item that allows you to set the % of sidereal tracking speed. You need to change the % number to increase or decrease the tracking speed.
jgraham
Reged: 12/02/04
Loc: Dayton, Ohio
Re: Can an LXD75 run a teensy bit slow (or fast)? new [Re: JAT Observatory]
      #3054827 - 04/20/09 12:48 PM
Also, make sure the drive rate is set to sidereal and not lunar.
MtnGoat
Reged: 02/18/07
Re: Can an LXD75 run a teensy bit slow (or fast)? new [Re: jgraham]
      #3054886 - 04/20/09 01:12 PM
thanks for the tips so far. I'll make sure I check what my drive rate is set to.
am I crazy in thinking that the rate could need a tiny bit of tweaking? I mean...it's all digital timing with very accurate clocks and known gear ratios..how could this be?
sang33ta
Reged: 07/08/08
Loc: UK
      #3055083 - 04/20/09 02:34 PM
Make sure your weight is balanced in both axis if it's out it'll drag or pull.
gordianknot
Reged: 09/04/05
Re: Can an LXD75 run a teensy bit slow (or fast)? new [Re: sang33ta]
      #3055188 - 04/20/09 03:17 PM
I agree about checking balance. My first guess is that something is slipping.
MtnGoat
Reged: 02/18/07
Re: Can an LXD75 run a teensy bit slow (or fast)? new [Re: gordianknot]
      #3055270 - 04/20/09 03:56 PM
yes, checked the balance. if anything, it's a bit too balanced! I was going for the slightly E heavy approach, but backed off on it when I started noticing this.
Skywatchr
Reged: 06/03/06
Loc: North-Central Pa.
Re: Can an LXD75 run a teensy bit slow (or fast)? [Re: MtnGoat]
      #3056856 - 04/21/09 09:54 AM
The tracking rate can be affected by a small amount of extra friction somewhere slowing it down some. Could be the lube on the worm isn't spread out enough, or a bearing is dragging (polar bearing too tight), or something rubbing that shouldn't be. Being heavy on the East will slow it down a little unless it's only about an ounce or so. Just enough to take out any flex.
Jeff
17 registered and 34 anonymous users are browsing this forum.
