jbattleson
Happily Retired
Reged: 03/02/09
Loc: Nebraska
Pier mounting a CGEM
      #3057586 - 04/21/09 03:27 PM
I am getting ready to mount my CGEM 1100 on a pier. Does anyone have a drawing of the bolt pattern to attach it to the pier top plate?
I hate to take the scope down to get the info. but will do that if no one has a print.
John
DrBuck
Reged: 12/10/08
Loc: Susanville, No. Calif.
Re: Pier mounting a CGEM new [Re: jbattleson]
      #3061907 - 04/23/09 12:02 PM
I would call Celestron technical support. They should be able to get you a bolt pattern!!
Strgazr27
Reged: 10/04/04
Loc: StonyHill Observatory
Re: Pier mounting a CGEM new [Re: DrBuck]
      #3061973 - 04/23/09 12:26 PM
John,
The bolt pattern is the same as the Atlas (At least should be) 1 Center bolt and the bolt for the Az pin. A quick google search should turn up what your looking for.
This may help.
This
I think this is what you want
Hope those help.
jbattleson
Happily Retired
Reged: 03/02/09
Loc: Nebraska
      #3062763 - 04/23/09 06:10 PM
I call Celestron last week and they told me none were available. They will email one to me if they can find one.
So far nothing.
John
jbattleson
Happily Retired
Reged: 03/02/09
Loc: Nebraska
Re: Pier mounting a CGEM new [Re: Strgazr27]
      #3062775 - 04/23/09 06:18 PM
Thanks for the link. I don't think that will work.
The CGEM has 1 bolt in middle but there are 2 pilots
to locate. One is 65MM dia. and the other is 30MM.
I have a drawing now but thanks anyway for your help.
If anyone would like the drawing I could email to them.
John
jbattleson
Happily Retired
Reged: 03/02/09
Loc: Nebraska
      #3066877 - 04/25/09 07:29 PM Attachment (87 downloads)
I have attached a preliminary drawing of my pier.
Feedback and suggestions are welcome.
John
Strgazr27
Reged: 10/04/04
      #3067631 - 04/26/09 07:49 AM
John
The Atlas uses the same pattern. They are 2 different locations for the Azimuth pin. These simply allow you to position North either inline with a tripod leg or between 2 tripod legs. we set up 3 of these at NEAF.
Otherwise the pier looks like it will be VERY solid. You don't list a dimension for the distance between the 2 plates. Just make sure you leave enough to insert and remove the center bolt without having to remove the whole top plate. I speak from experience
jbattleson
Happily Retired
Reged: 03/02/09
Loc: Nebraska
      #3068015 - 04/26/09 11:13 AM
Thanks for the feedback.
I was going to leave 2 1/2 to 3 inches between the
plates on top. I can change that by using longer threaded rod
so shouldn't be a problem.
John
27 registered and 35 anonymous users are browsing this forum.
