Post a picture of your mount!! (Part 3)
Started by
Charlie Hein
, Apr 25 2009 01:25 PM
3135 replies to this topic
#1
Posted 25 April 2009 - 01:25 PM
- Charlespl and Seany79 like this
#5
Posted 03 May 2009 - 08:21 PM
My brand new Orion Skyview Pro...in pieces! It was a brand new floor model. When I got it I found the RA axis seized. Normally I'd return something that doesn't work for a new one, but I had read that giving these mounts an overhaul does wonders for its operation, and I'm the type of person that would perform such a task.
The RA axle and worm (the seized parts) are going to be repaired by the seller, and with the removal of the old gunk, deburring of the worm, good grease, and a careful adjustment, it should actually be better than new, so I'm not terribly upset at the moment...but check back in a couple weeks when the axle get back
- lunardave and No N in collimation like this
#10
Posted 06 May 2009 - 01:44 PM
Nice but I think you are going to need a longer peir....
#11
Posted 06 May 2009 - 02:10 PM
Oh yeah Daren...I keep it on that short pier to roll it around with the tube in its rings...so I can work on it.
The GEM and saddle alone will be mounted on a permenent steal pier in an OB. I wouldn't be able to even look over the trees if I left the 12" X 14ft scope fixed in this arrangement....
Rob
- Joe1950 and lunardave like this
#13
Posted 14 May 2009 - 09:32 PM
Here's a picture of my LX200 10 SCT with the fork mount and then on an Atlas EQ-G, and my wide field setup on the EQ-G. I decided to take the 10" sct off the fork mount so that I could switch easily between scopes for astrophotography.
- Scott Beith, mdowns, Orion68 and 6 others like this
#16
Posted 16 May 2009 - 03:05 PM
Oh my, Elvis is finally in the building. Just got the mount a few days ago. All I can say so far is that it was worth the wait. Can't wait to give a scope a ride.
Astro-Physics Mach 1 GTO on AP/Baader wood tripod with A-P accessory trays....
- Scott Beith, Tommy, boothee and 19 others like this
#18
Posted 19 May 2009 - 04:05 PM
Got a new CGEM last week, but last night was first clear skies to give it a trial. Worked great! Aligned it roughly north - did the 2 + 4 alignment, then the polar alignment routine on Arcturus. Everything was spot on. Imaged M53 - it was close to the meridian so I could check out the tracking across the meridian.
- Gary Z and lunardave like this
#20
Posted 23 May 2009 - 11:20 AM
I'm refurbishing my 10" newt (Orion) and I'm trying to decide if I should repurpose my Atlas from primary use with my refractors and CATs to an equatorial for the 10" newt. My viewing is from the SE to SW, not that great of an arc. Do you find the 10" comfortable to use on the Atlas, or is it a bit of pain?
#21
Posted 24 May 2009 - 08:40 AM
Pferendzo,
That is actually the 8" newt, not the 10". That said, I have no issues with it. The dovetail bar on top helps alot, it is a very good carry handle and also gives someplace to grab while putting it on and taking it off. I have mounted my camera & 500mm lens on top of the 8" on the top dovetail bar and the Atlas seemed to handle it fine.
#25
Posted 27 May 2009 - 08:05 PM
OK. Now for something COMPLETELY different!
My iOptron Mini Tower on an EQ wedge with a 1975 C8 w/ Moonlight two speed focuser, 8 x 50 finder and sliding CW. All held in place on a Losmandy D style dovetail and saddle plate. Note the new and larger CW shaft to allow use of the Losmandy CW!!
Steve
Steve
- Scott Beith, payner, Gary Z and 5 others like this
