ibase
Vendor Affilliate
Reged: 03/20/08
Loc: Manila, Philippines 121*E 14*N
Orion AZ-3 mount for 102ED? new
      #3065406 - 04/25/09 12:10 AM
Have an Orion AZ-3 mount coming for grab&go, can I use it also for a 102ED refractor or will it only be suitable for my ST-80? Thanks.
Best,
Starlighter
Reged: 08/03/07
Loc: Sunny California
Re: Orion AZ-3 mount for 102ED? new [Re: ibase]
      #3066271 - 04/25/09 01:04 PM
I doubt it will work well with your 102ED. The AZ-3 has rather flimsy aluminum legs plus the mount head isn't that beefy. Vibration will be the main problem when using your 102ED.
Joe Aguiar
Reged: 02/10/07
Loc: Toront,Ontario
Re: Orion AZ-3 mount for 102ED? new [Re: Starlighter]
      #3066334 - 04/25/09 01:37 PM
I have a Skywatcher 102 F/5 on the AZ3 but i mainly use it for land viewing,birdwatching or for large extended DSO viewing, like North American neb,Pelican neb,M31 etc etc.
For the 102ED its twice the length & you will be on your knees, so i would get something like an EQ3/ or EQ4 type mount better.
Joe
Starlighter
Reged: 08/03/07
Re: Orion AZ-3 mount for 102ED? new [Re: Joe Aguiar]
      #3066402 - 04/25/09 02:18 PM Attachment (40 downloads)
Or the Vixen Portamount II.
I have the older Portamount that I replaced the aluminum legs with wooden one from Hands On Optics. This makes for a very stable platform to mount a 102ED.
As you can see from the photo, I use my SV102ED on the Porta. Vibration time was cut in half by installing wooden legs. The slow motion controls work well.
Joe Aguiar
Reged: 02/10/07
Loc: Toront,Ontario
      #3066409 - 04/25/09 02:24 PM
true with large tripod legs the AZ3 can be much better for that scope.
Joe
gordianknot
Reged: 09/04/05
      #3066613 - 04/25/09 04:23 PM
I think the 102ED is seriously pushing it for AZ-3. I'd suggest checking out a Porta Mount or maybe an AT Voyager.
ibase
Vendor Affilliate
Reged: 03/20/08
Re: Orion AZ-3 mount for 102ED? new [Re: gordianknot]
      #3066936 - 04/25/09 08:21 PM
Thanks guys for the advices/guidance, I really appreciate it much. Actually I obtained the AZ-3 mount head only (used; it's hard to ship long tripod legs overseas) and will try to bolt/customize it onto the heftier Nexstar 8 or CG-5 tripods that I already have.
Best,
Terrance
Reged: 08/11/04
Loc: Near Portland Or.
      #3073344 - 04/28/09 05:13 PM
Some years ago I used a AZ-3 with an Orion ST 80mm f/5 refractor and it worked fine with that. However when I put an Orion 80ED f/7.5 on it, which was heavier, longer, and wider, it did not work at all. The problem was the altitude tension, and no matter how tight I tried to make it, it would not hold the weight of that scope so that it kept slipping down.
Some people have made the AZ-3 work with scopes heavier than the Orion 80ST by modifying the mount in some way, but I was too big a mechanical idiot to make that work.
I have used a SV 102ED (f/7) on a Vixen PortaMount, and that was very portable but marginal as to stability even when I replaced the aluminum tripod it came with, with wooden legs. (4-5 seconds damping time at 100x for either a tube or leg slap)
SV 102ED on WO EZ-Touch on Oberwerk Wooden tripod, and now on Vixen HAL-130 tripod is very solid, but not as portable.
ibase
Vendor Affilliate
Reged: 03/20/08
Re: Orion AZ-3 mount for 102ED? new [Re: Terrance]
      #3073772 - 04/28/09 09:23 PM
Terrance, thanks for sharing your experience on this.
Best,
Starlighter
Reged: 08/03/07
      #3073974 - 04/28/09 11:08 PM Attachment (29 downloads)
I have my SV102ED out right now on the Portamount. I put in a 6mm and then tapped the focuser. I counted 2.5 seconds. Then I tapped one of the wooden legs. Nothing. But then I have the tripod sitting on interlocking cement pavers. Maybe that makes the difference from what you found. When I'm viewing, my neighbor's cat Floyd can rub up against a tripod leg and I hardly see any vibration.
KWB
Reged: 09/30/06
Loc: Westminster,Co Elev.5400 feet
Re: Orion AZ-3 mount for 102ED? [Re: Starlighter]
      #3074072 - 04/29/09 12:24 AM
Been there,done that with this size refractor and the AZ/3 with solid wooden tripod. I give this setup a "F",as in an abysmal failure. A frustrating astro experience.
21 registered and 38 anonymous users are browsing this forum.
Calendar Event: 04/25/09
