Mittag55
Reged: 10/31/08
Loc: West Amboy, NY
LXD75 Proper dual mount new
      #3064045 - 04/24/09 10:15 AM
I have just ordered a new mount and plan for now using it for my 130 mm reflector and adding a 80 or 90 mm guide/imaging refractor on it...is there any proper physics or distribution of weights i should know about or can i just pair up the scope rings and balance the rig out.Any help or point to the right info would be helpfull.
Jerry3672
Vendor - Quantum Astronomy Products
Reged: 01/20/08
Loc: Lexington NC
Re: LXD75 Proper dual mount new [Re: Mittag55]
      #3064450 - 04/24/09 01:46 PM
The best tip for that LXD75 is to have your mount a little (East) heavy. The gears always should climb a bit. If you are balanced perfectly, then the backlash will allow the mount to bounce back and forth and you will have long stars.
I have my 90mm guide scope on top of my 10 inch SN reflector. I had to add a custom weight to the end of the shaft, but you won't have that issue with a 130mm scope.
Edited by Jerry3672 (04/25/09 01:23 PM)
Mittag55
Reged: 10/31/08
Loc: West Amboy, NY
Re: LXD75 Proper dual mount new [Re: Jerry3672]
      #3064829 - 04/24/09 05:21 PM
Thanks for the input...West heavy it will be.
EricJD
Reged: 07/24/07
Loc: Chesapeake VA
      #3064957 - 04/24/09 06:37 PM
Eh mate, don't you mean East heavy so that as it rotates it's always pressing against the gears? I always balance east heavy and get nice round stars at 6 minutes on my LXD75.
jgraham
Reged: 12/02/04
Loc: Dayton, Ohio
Re: LXD75 Proper dual mount new [Re: EricJD]
      #3065275 - 04/24/09 10:42 PM Attachment (28 downloads)
The LXD75 should handle that easily. Mine carries an LXD75 SN6 with a 90mm MCT as a guide scope. I usually balance mine evenly on both axis, then shift a small counter weight to make it just a tad east-heavy so it climbs against the load. Also, while guiding I use either north-only or south-only on the dec.
My standard imaging kit...
Jerry3672
Reged: 01/20/08
Loc: Lexington NC
Re: LXD75 Proper dual mount new [Re: jgraham]
      #3066246 - 04/25/09 12:55 PM
Opps- You are corerct- East heavy so the gears are climbing.
Jerry3672
Reged: 01/20/08
Loc: Lexington NC
      #3066248 - 04/25/09 12:56 PM
Take note of where John has his camera. I have seen his image before and use his Idea to keep the mass in the correct place. This is the best place for the camera
Mittag55
Reged: 10/31/08
Loc: West Amboy, NY
      #3066843 - 04/25/09 07:08 PM
Thanks...this is why i read the posts...lots of neat tricks and tips to keep me out of trouble.
Mittag55
Reged: 10/31/08
Loc: West Amboy, NY
Re: LXD75 Proper dual mount [Re: Mittag55]
      #3075547 - 04/29/09 05:48 PM
Well i have a 105 mm Antares coming to go on my mount so all is well. i will try it balanced at first to see how smooth the mount is and ofset East if it needs sit...Thanks all for the help
10 registered and 39 anonymous users are browsing this forum.
