David PavlichAdministrator
Transmographied
Reged: 05/18/05
Loc: Mandeville, LA USA
Pempro Polar align... new
      #3070621 - 04/27/09 01:59 PM
I want to fool around with Pempro's Polar Align program, but I have a question. Pempro states to point the scope south and place it near the celestial equator. My southern exposure is a phalanx of pine trees.
I can point south, but because of the pines, it's above the CE by a substantial amount. How will this affect the aligment routine?
Thanks! David
Jaxdialation
Reged: 04/01/07
Loc: Northeast, FL
Re: Pempro Polar align... new [Re: David Pavlich]
      #3071396 - 04/27/09 07:37 PM
Hey David, I'm going to suggest that you pose this question on CCDWare's forum if you can't get an answer here.
I hope Pempro will work for you. I got it to help me with my AP1200, which IMHO has a pathetic polar scope. Pempro does a suberb job and is my tool of choice.
Chris Curran
Reged: 06/14/05
Loc: Brandon, FL
      #3076519 - 04/30/09 07:26 AM
David:
??? You read the documentation? Can you see where your meridian and celestial equator intersect? If so you're golden. If not, may I suggest this solution: click here
Psst: I assume you know that *you* don't have to point that scope - PEMPro will do it for you.
Jax:
Pathetic? Hmmm... Well, it's not as accurate as my Tak PS, but, it's not as complicated either. IMHO, it works very well for its intended purpose. A Shaker would call that "perfect".
Transmographied
Reged: 05/18/05
Re: Pempro Polar align... new [Re: Chris Curran]
      #3076646 - 04/30/09 09:42 AM
David:
Jax:
Very good, Chris! I can easily see where the CE and the meridian intersect; it's about 2/3 of the way up a rather tall pine. I'm probably the only person that built a roll-off observatory that has a roof that rolls off to the south. My southern horizon (that's an oxymoron) is that bad.
And no, I didn't know that Pempro will point the scope. Of course, it can't see the pines, either. I was hoping to try it out this weekend, but the weather doesn't look too promising.
David
Chris Curran
Reged: 06/14/05
Loc: Brandon, FL
      #3077461 - 04/30/09 05:02 PM
Something else to keep in mind... Just because a star in "in the trees" doesn't mean you can't get to it with your scope. Polaris in impossible for me to see from my driveway - unless the wind is blowing...
Transmographied
Reged: 05/18/05
Re: Pempro Polar align... [Re: Chris Curran]
      #3077575 - 04/30/09 06:11 PM
Funny that you mentioned that. I got my 250 in the winter, well, winter for SE Looziana, but there's a tree that blocks my view of Polaris when the leaves are on it (it's not a pine). But I can find Polaris when the leaves are off....or when it's windy. The only problem is that it blinks in and out.
I did the alignment using the iterative method which seems to have worked just fine. But it's been about 6 months, so I thought I'd do it again just to ensure the alignment is still good to go.
David
22 registered and 29 anonymous users are browsing this forum.
