Pages: 1 | 2 | 3 | 4 | 5 | 6 | 7 | (show all)
Tarzanrock
Reged: 12/07/08
Loc: Los Angeles
AS CG5 GT New Software Alignment/Calibration Stars
      #3081299 - 05/02/09 03:38 PM
Hi all:
Yesterday, Celestron upgraded my old AS CG5 GT Hand Control Device with the newest software, versions 4.15 and 4.16, by replacing the old HC with a brand new HC device which contained the newest software installed in it.
According to the Celestron's literature (and the internet astro discussions); the newest software will create a far better model of the sky which is supposed to result in greater precision for tracking and pointing of the telescope.
Since my SCT is used in the same location in the southern California desert, I would like to use the new software to create the best possible sky model which would result in the most precise pointing for the upcoming Spring and Summer. If I recall properly I believe that Celestron's literature further states that the new software gives the Mount a greater ability to remember the sky model that was created; which information is or may be saved in the Mount's memory; and, can be thereafter improved upon with subsequent calibrations in the course of further modelling of the sky.
I am certain that many of you who have the luxury of a permanent observatory have considered these issues as well. Towards that end, I am wondering which alignment procedure(s) would be most effectively utilized with this new software by incorporating which alignment and which calibration stars to create the best model of the sky for the computerized Goto of the AS CG5 GT Mount.
Any such tips, pointers, suggestions or other such help would be much appreciated.
Currently, I am thinking of the following procedure:
1.) Polar Align it as accurately as possible in the intial set-up with bore sighting Polaris through the Mount's hole; and, use the polar alignment scope to center Polaris and physically align the Mount to the NCP as precisely as possible in the course of the initial set-up.
2.) Auto 2 star align per the directions with a 12.5 mm reticule eyepiece. Use a barlow as well to really hone in on the star to intially align the intial alignment stars. The question is "which" two alignment stars would be best to create the initial sky model? I suspect that these may likely be the two brightest stars picked by the computer; and, I understand that they need to be on one side of the meridian -- the question is how spread out should they be across the the half dome of the sky in order to obtain the best possible mapping?
3.) Thereafter, align with 4 calibration stars. The next obvious question is which 4 calibration stars are next best for the creation of the initial sky model? The further question is since the calibration stars are on the other side of the meridian, which ones and how spread out across that portion of the half dome of the sky should they be?
4.) Use Celestron's Polar Align function to really precisely set the polar alignment. [I note that there is talk on the forums about doing an iterative alignment between Polaris and Dubhne or other stars, but I don't know about that -- others talk about doing an interative alignment between Polaris and another stars that are 90 degrees away on the celestial equator for better polar alignment. I'm interested in this but I have never done it. The question is how to do it and which stars to use for that procedure?]
5.) Perform an Auto 2 star align again for the second time per Celestron's instructions. The question now is since the initial sky mapping has been done with the first 2 star alignment (and the 4 calibration stars); then which 2 stars should be utilized for the second 2 star alignment, i.e. should I use different ones than the original 2 stars plus the 4 calibration stars? I would suspect so, but I don't know. If so, then which subsequent stars which are different from the initial 6 stars are best utilized to create the best sky map? I would think that this issue is likely important since the choice of the second set of stars will likely more precisely model the sky's map that the computer is creating.
The question, of course, is which ones should they be, i.e. should the initial 6 alignment and calibration stars be spread across the entire half dome of the sky; and, the subsequent 6 alignment and calibration stars be chosen in a much smaller area of the sky? Or what? What is the criteria for choosing the second set of alignment stars to achieve the best possible sky mapping profile for the computer?
6.) After the second 2 star alignment, then align with 4 subsequent calibration stars.
7. Use precise GoTo with M57 in Lyra to probably Sulafat (which is what I did with the old auto 3 star alignment procedure on the old software.) If not M57 then which other DSO's or objects would best serve to best fine tune the sky mapping model that the computer is creating?
8.) Thereafter slew to a DSO object from the list in the hand control and see just how close the above alignment puts DSO in the center of the eyepiece.
9.) Figure out how to do it better.
10.) How to use the "Synch" function effectively?
11.) Once an effective and precise sky model is created as referenced above -- how to use the "hibernate" function to store such information; and, thereafter improve on the accuracy of it.
I suspect that someone has already figured this out and that they must have this information available from their personal experience in the observatory or from setting the AS CG5 GT Mount for astrophotography.
This is the type of information I am looking for; and, I suspect that many other novice users of the AS CG5 GT Mount would like to know it as well.
Thank you all in advance for any help. Feel free to PM me with any additional information, PDF files, etc. which may be too large to put into a response. Thanks again.
Best regards,
William
WadeH237
Reged: 02/24/07
Loc: Snohomish, WA
Re: AS CG5 GT New Software Alignment/Calibration Stars new [Re: Tarzanrock]
      #3081487 - 05/02/09 05:45 PM
It seems like you're making it more complicated than it needs to be.
Here's what I do.
- Set the mount down roughly pointed north (I just us a compass for this) and with the latitude adjusted for your location.
- Power the mount on and enter the date/time information.
- Do a two star alignment.
- Add 4 calibration stars.
- Use the list of named stars to go to a star near the celestial equator in the south.
- Do the All Star polar alignment, accessed by hitting the <Align> key.
- Enjoy good pointing and tracking.
If you need to power down the mount, you can turn it back on, enter the date/time and do a two star alignment. If you haven't physically moved it or changed the OTA, you can skip the calibration stars and polar alignment.
To ensure accuracy, make sure that you always center the alignment and calibration stars using the up and right keys on the hand controller.
I don't have a polar alignment scope. It's completely unnecessary with this mount. The reason that I use a compass to find north above is that I usually set up before dark. If you wait until after dark, you can just look through the hole where the polar alignment scope would go and sight Polaris. This will get you plenty close for the All Star polar alignment to finish it up. Also, I don't bother with a reticule eyepiece. I just use whatever I'm going to observe with. If it's a wide field eyepiece, you can defocus the star to a doughnut to make it easier to visually center.
I hope this helps,
-Wade
http://www.faintfuzzy.net
Stuff
Visual Stuff (shared with wife and kids, 10 & 12): Generic 6" F/8 Dob, C8-SGT, CGE-1400, Orion ED80 on a CG5-GT, Coronado PST, 6" Meade Schmidt-Newtonian, Astroscan, 12x70 Binoculars.
Imaging Stuff: Meade 8" LX200ACF with Optec TCF-S focuser on a CGE mount, SBIG ST-10XME with CFW8 and remote guide head, Astro-Tech AT66ED guide scope, Astrodon filters, QHY8PRO, DSI Pro, Canon EOS 20D, Hyperstar 3 for C8.
Tarzanrock
Reged: 12/07/08
Loc: Los Angeles
Re: AS CG5 GT New Software Alignment/Calibration Stars new [Re: WadeH237]
      #3081899 - 05/02/09 10:10 PM
Wade:
Thanks for the reply. I understand what you are saying.
What I am interested in ascertaining is what others, who have used this new software, have done with respect to creating the type of model of the sky as is suggested in the Celestron's literature by the 2 star alignmnet and 4 calibration stars; and, the subsequent modelling of the sky as occurs in the second alignment sequence (2 stars and 4 calibration stars).
Towards that end, I am interested in knowing which stars are selected for the first model (i.e. 2 alignment stars and 4 calibration stars); and, which stars are selected for the second model (i.e. 2 alignment stars and 4 calibration stars).
I would like to know if someone has information about how the initial alignment star pattern is spread out in the half-dome of the sky; and, I would like to know how the subsequent alignment star pattern is to be spread out in the sky in the second alignmnet pattern after the 1st alignment pattern is completed.
I believe that someone must have considered this issue heretofore; and, has aligned their scope in such a manner to achieve a very high level of accurate pointing with this software.
If anyone has done so or has information about how to do so I would most welcome their input.
William
waassaabee
Reged: 11/26/07
Loc: Central California Coast
      #3082490 - 05/03/09 10:21 AM
I setup similar to Wade, though my CG5 has a Polar Scope and I would align close but not too concerned about it being dead on.
I do not use a reticule ep. I sight through my DSLR aligning on the center dot, and as Wade mentions finishing each calibration/alignment star with up and right.
I let the software pick my 2 alignment stars and 4 calibration stars (I figure it knows best).
Slew to a star for the AllStar per Celestron recommendation.
2+4 using the same stars.
Slew to first target and I can image with this alignment. No need to make it more difficult in my book.
If you want to do a drift alignment to fine tune, this is the time.
At the end of the session, slew Home, Hibernate, power down. You have to leave the mount in position for this to be effective, but next night, power on and go.
Gary
34N 120W
-My kingdom for blue squares!-
WO Megrez 90FD/TV 0.8x FR/FF
AT8RC
mini Borg 50/Q-Guide/PHD
CGEM
Canon 350D Hap Griffin Baader mod - o.o
My Friend Flickr
WadeH237
Reged: 02/24/07
Loc: Snohomish, WA
      #3082496 - 05/03/09 10:25 AM
I use the 4.15 firmware with my CG-5.
The firmware selects alignment and calibration stars based on the time and site information. If you've entered the information accurately, the firmware will select the alignment stars on one side of the meridian and the calibration stars on the other. I just take the stars that the hand controller suggests in the order that it suggests them. If one of the stars happens to be behind an obstruction, I hit undo and use the next one.
I do the same thing on my CGE with 4.15 when I am imaging. The gotos put objects anywhere in the sky near the center of my CCD. In the case of the CGE, I shut down in the morning - I don't bother hibernating. Then for the next night, I just turn it on and pick Last Alignment and get the same results. Since the CGE has a real time clock, I don't even bother with the date and site information.
This works so well that I don't know what practical advantage you'd gain by choosing stars other than what it suggests.
-Wade
Stuff
wsuriano
Reged: 11/13/07
      #3082808 - 05/03/09 01:32 PM
Do you guys redo the 2-star alignment plus calibration stars after the All Star Polar Alignment following the instructions of "unsyncing" and then realigning the original alignment and calibration stars, or just skip this? Do you do it if the All Star Polar Alignement requires a large adjustment?
Meade 8" LX90 GPS w/wedge
Meade 5000 80mm APO
Vixen 5" Newtonian
Orion 120mm f/8.3
Orion ST 80mm
Meade ETX90 PE
CGEM
CG-5 ASGT
iOptron MT
donsinger1
Reged: 10/28/07
Re: AS CG5 GT New Software Alignment/Calibration Stars new [Re: wsuriano]
      #3083090 - 05/03/09 04:20 PM
With my CGEM, I unsync and resync on the original two alignment stars and add several calibration stars...takes just a few minutes and my gotos and tracking are good.
D
Fun Stuff:)
Portland, OR
Tarzanrock
Reged: 12/07/08
Loc: Los Angeles
Re: AS CG5 GT New Software Alignment/Calibration Stars new [Re: donsinger1]
      #3083116 - 05/03/09 04:40 PM
Hi Guys:
Thanks for the replies. They are most helpful to me. I have sent Celestron and their technical support an e-mail message making a similar inquiry as was initially stated above. We will see what they have to say.
I am confident that whomsoever actually wrote the 4.15 software program must know which stars; in what sequence; and, in what location of the sky are best, in the course of each of the two separate 2 Star Alignment Procedures, for the purpose of creating the most accurate model of the sky.
I have not yet personally used the software as the equipment is in the southern California desert and I'm in L.A., but I will try to get out there and try it out by the next New Moon. Hopefully, by then I shall know far more about the software and how to use it than I now know.
I'm additionally interested in whether or not anyone has used the "Sync" functions; the "Hibernate" functions; the "Solar Align" functions of this software; and, with what results?
William
waassaabee
Reged: 11/26/07
      #3083216 - 05/03/09 05:50 PM
+1 Don & Wade!!
LA? Whereabouts? I'm north of Santa Barbara a bit.
Gary
34N 120W
AT8RC
CGEM
My Friend Flickr
WadeH237
Reged: 02/24/07
Loc: Snohomish, WA
      #3083252 - 05/03/09 06:09 PM
I don't.
I've found that as long as I'm careful about centering the star during All Star alignment, I haven't needed to re-align. It's a good idea to un-sync, though.
As my rule of thumb, I do a two star alignment (or just update the two alignment stars while running) if something has happened to change alignment, like the mount powered off or a clutch slipped, etc.
The purpose of the calibration stars is to give the mount a model to correct for orthogonality issues (this is where the mount's RA axis and the OTA may not be in perfect alignment.) The result of this calibration is stored in the hand controller's non-volatile memory. As such, I only do the calibration stars when I've just put on the OTA and this has worked well for me.
-Wade
Stuff
Patrick
Reged: 05/16/03
Loc: Franklin, Ohio
      #3083366 - 05/03/09 07:05 PM
Hi William,
Since you will be doing a precise polar alignment later on in your alignment procedure, doing a precise polar alignment through a polar scope at the beginning of the process may not be necessary. I've found doing a rough polar alignment through the polar axis hole, plus making sure the mount is level to be all that is required. In fact the CGEM manual (I'm referring to the manual for the CGEM since it's up to date with the latest firmware) essentially says the same thing on pages 14 and 15 where it describes the process for 'Adjusting the Mount'. The manual doesn't mention leveling the mount, but I suspect it assumes that it is level.
Which magnification you use may be more of a function of the focal length of your telescope. If you have an SCT, a 12.5mm reticle may be just fine. If a shorter f/l scope, then perhaps a 5mm reticle or a barlow would be better. One important thing to do whatever the focal length of your reticle eyepiece is to do the final movements with the right and up arrow keys to always keep the gear backlash out of the equation.
2.) The question is "which" two alignment stars would be best to create the initial sky model? I suspect that these may likely be the two brightest stars picked by the computer; and, I understand that they need to be on one side of the meridian -- the question is how spread out should they be across the the half dome of the sky in order to obtain the best possible mapping?
Are you looking for specific names? If so, that totally depends on when you're observing, of course. But, I don't think that's what you mean. I think you mean how does Celestron decide which stars to use for the first and second alignment stars. I don't know except they're in the western hemisphere, and they are usually a star in the southern and then northern sky, or vice-versa. So, I think that means they're spread out as far as possible to get the largest angular dimension that it can...which makes total sense.
At my own observing site, I have a lot of trees and the house blocking a substantial part of the sky, so I have to use the up and down arrow keys to select the stars that I can see. I try to keep them as far a part as possible.
One other thing to consider when picking the alignment stars it to not pick a star too close to the horizon because of atmospheric refraction. The star may not really be exactly where you think it is.
The CGEM manual, page 19, says "it
is recommended that you add as many as three calibration stars for optimal
point accuracy". Personally, I've found that adding two calibration stars provides excellent goto accuracy.
Also from the CGEM manual, page 19: "Calibration stars that are near the equator offer the best results than stars near the poles."
This is a technique that has been employed to avoid doing a drift alignment. I think the new Celestron polar alignment routine will relegate the technique to the back burner.
5.) Perform an Auto 2 star align again for the second time per Celestron's instructions...should I use different ones than the original 2 stars plus the 4 calibration stars? I would suspect so, but I don't know.
I don't see any reason why you couldn't reuse the original alignment stars. If the alignment was thrown off by the polar alignment routine, then you're just telling the computer where the stars are really located again. By the way, you can sync and un-sync at any time. If a goto is off a little, I will routinely put the object in the center of the fov and sync on it.
I don't think you will need to add the calibration stars. Goto an object you'd like to see, and if it's not centered in the fov (it should be close), then center it and sync on it.
Patrick
10" f/6 Truss Tube Newtonian
Celestron C6S-GT SCT
AT66ED Refractor
Oberwerk Ultra 15x70 Binocular
475B Geared Tripod & 501HDV Head
Celestron Regal 8x42 Binocular
Canon XSi; Meade DSI;SPC900-NC
Vixen GP2 Photo Guider Mount
My Astronomy Pages
bdjeep
Reged: 01/29/07
Loc: Bolton, MA
Re: AS CG5 GT New Software Alignment/Calibration Stars new [Re: Patrick]
      #3084375 - 05/04/09 10:21 AM
Have you tried the "Select Alignment Stars" utility at Nexstarsite.com? This should tell you which stars are good choices for your initial alignment given the time & location. However, I've never had a problem with the choices from the hand controller.
Are you a visual observer, or are you going to be imaging? If visual, I think you are making the process entirely too complicated.
Here is my process for visual use:
Just plop the scope down, level the tripod (approximately), align index marks, adjust alt-az until you get Polaris in the finder and then in the main scope. Turn on the mount, enter date/time, etc. Pop in a 25mm eyepiece, align on 2 stars (hand controller choice is usually fine.) Calibrate on 2 more. Observe and enjoy. This is simple, easy, and almost never fails to put objects in the FOV of my 25mm Plossl.
When I'm doing some planetary imaging, I'll be a little more careful with the initial polar align, followed by the new All Star polar alignment. Sometimes I'll add a couple of extra calibration stars if I'm feeling particularly motivated.
Tarzanrock
Reged: 12/07/08
Loc: Los Angeles
Re: AS CG5 GT New Software Alignment/Calibration Stars new [Re: bdjeep]
      #3084824 - 05/04/09 02:32 PM
Have you tried the "Select Alignment Stars" utility at Nexstarsite.com? This should tell you which stars are good choices for your initial alignment given the time & location."
I did previously before I posted the original e-mail message -- but I could not open the program. I'll try it again today.
I would like to create an alignment map to use along the parameters which Celestron has used in their software program. I am very interested in having this type of an "alignment map" for the Spring/Summer stars; and, a second one for the Autumn/Winter stars.
I really want to understand exactly how this new software works and how to effectively use it on the AS CG5 GT mount. I was quite impressed with the precision of the old software with the old auto 3 star align when it was carefully polar aligned; and, thereafter carefully aligned with the 3 object stars under the old software.
After reading the literature on the new 4.15 and 4.16 software I am even more persuaded that the capabilities of the new software far supercede the old software.
I am fully persuaded that once an appropriate mapping of the sky is carefully modeled by the computer (likely along the lines some of you have suggested)with 12 reference stars for the computer to use in the process -- then the pointing is likely to be highly accurate -- which is necessarily important for a novice like me to use in order to locate 13th - 15th magnitude objects, i.e. the Quasar 3C273; and, other such distant, dim Deep Space Objects.
I did send Celestron's tech support a similar e-mail message requesting further details on this same sort of stuff. I'll let you know their response.
William
Edited by Charlie Hein (05/05/09 07:19 AM)
Patrick
Reged: 05/16/03
Loc: Franklin, Ohio
      #3084855 - 05/04/09 02:48 PM
Have you seen the hand controller's "precise goto" feature? It's designed to do exactly what you're describing.
Patrick
AT66ED Refractor
My Astronomy Pages
Tarzanrock
Reged: 12/07/08
Loc: Los Angeles
      #3084884 - 05/04/09 03:04 PM
Patrick:
Yes. I've used it with the old software (4.12, I think it was).
Don Pensack sent me an e-mail message in response to my questions. I'll summarize his thoughtful responses and post them soon as I am able to do so as I think that you and others may find those thoughts as useful as I have.
Best regards,
William
Tarzanrock
Reged: 12/07/08
Loc: Los Angeles
      #3084934 - 05/04/09 03:34 PM
Patrick:
Please be advised that I read somewhere in Celestron's literature that Celestron does, in fact, recommend for their 2 Star Alignment Procedure: 2 Alignment Stars and 4 subsequent Calibration Stars. If I remember correctly I think that this procedure was specific to the AS CG5 GT Mount. I will check on that issue and get back with you on it since I know that you use that mount as I do.
Here is a summary of what Don advised me when he responded to my rather poorly phrased questions on this issue which I have put in a Q and A format:
Question: From looking at Celestron's literature, it seems that the intial 2 alignment stars are all on one side of the meridian and that they should be as widely spread apart as possible. The question is which stars should one use on the East and which on the West for the initial 2 star alignment? I would assume that one would select the ones that the computer picks, but that may not be the case; and, it well may depend upon what calibration stars are selected as well as where the initial stars are located in the sky, i.e. lower half of the sky dome or upper half of the sky dome.
Answer: "Accuracy is highest, from what little knowledge of cartography I possess, when one star is south of the equator, one star is north (both east), and one star is near the equator (in the west), though as long as the triangle is large, calculations should pick up cone error. Do not use any star near the pole as smaller and smaller movements of the mount result in larger and larger errors."
Question: As for the 4 subsequent calibration stars, the same question applies --which ones and where should they be located on the opposite side of the meridian for the creation of the sky model for purposes of the best alignment?
Answer: "Using alignment stars near the field of primary target results in the greatest accuracy, which is the raison d'être of Precise GoTo."
Question: "This is relevant because in trying to understand how the computer program algorithms work it may be that the alignment stars and calibration stars selected in the intital 2 star alignment (and subsequent 4 calibration stars) need to be selected in the bottom half of the sky's half dome (i.e. in the area from the horizon to say 45 degrees up from the horizon) or would they need to be selected in the upper half of the sky's half dome (i.e. say 45 degrees up to the zenith).
Answer: "Stars near the horizon suffer from refraction and choosing them will cause errors. Never chhose an alignment star closer to the horizon than 30 degrees."
Question: If the computer is creating a model of the sky I think that this may be important to know because a more accurate model would obviously be created depending upon how the program's algorithms work. This is important because if the next step is to do the computer's polar alignment [which is based upon the initial 2 star alignment (and 4 calibration stars)]; then after the polar alignment, a second 2 star alignment is required (with another 4 calibration stars).
> The issue for purposes of the creation of an extremely accurate sky model in the computer becomes which stars are now to be chosen in the second 2 star alignment (and 4 calibration stars)?
Answer: "They can be the same stars. The accuracy will depend on accurate centering of the stars. You don't need to worry about the speed with which you choose the stars, either, as the clock is running while you select. Your confirmation of the location of the second star confirms the "twist" of the celestial globe relative to the first star."
Question: If, in the initial alignment the stars in the lower half of the sky's half dome are selected (i.e. stars from the horizon level to say 45 degrees up); then in the second 2 star alignment procedure, should stars in the upper half of the sky's half dome be selected (i.e. stars from 45 degrees to the zenith)?
> The central question is which stars of the 12 stars which are used in the alignment process (i.e. the 4 alignment stars and 8 calibration stars utilized in 2 separate alignment procedures) should be used; and, in what sequence should they be chosen, in order to create the best model of the sky for the Celestron 4.15 and 4.16 software program to create the most effective model of the sky.
Answer: "I'm not sure it's real critical because I've used the 3 stars chosen by the mount, I've chosen them myself, I've had them close together, and far apart, and the pointing accuracy has been good in every case."
Question: I am sure that somebody knows the answer to this question, but I don't know who. I checked Mike Swanson's website and could not find the answer there. I googled it without success so far. I've posted the question on CN and the last time I looked I there was no response which answered the question. Celestron's software engineers should know or at least the person who wrote the program should know. If all else fails, I plan on writing to Celestron to try to ascertain this information.
Answer: "The program was written by Synta Corporation, so I hope you speak Chinese."
Question: On Mike Swanson's website there is a computer program called "Best Pairs" which was written for the Meade LX 200 fork mount which selects the best pairing of stars for the Meade autostar program. Something similar must exist for Celestron.
> Moreover, since other computer programs interface with Celestron's 4.15 software [such as Starry Night Pro and The Sky] there must be something out there which identifies which 12 stars and in what sequence best align the telescope's mount.
Answer: "The accuracy should be highest with the greatest separation so long as no star is below 30 degrees (meaning alignment stars could be as much as 120 degrees apart)."
I like Don's reasons as they make sense to me. When I have some time this coming week I would like to create an "alignment map" of the night sky to be used in the early evening (dusk and thereafter) to use to model the sky according to the parameters that Don has set forth plotting out the 4 Alignment Stars and the 8 subsequent calibration stars.
Maybe someone who has more free time available and a similar interest may beat me to the punch on this; and, if so, I would be interested as there is no need to re-invent the wheel. On the other hand, others may well have thought this matter through along a similar path and have some input to offer as well. It certainly would be welcomed.
Finally, as previously stated I am really interested in learning how to fully use this new software, including all of its functions such as "Solar Align;" "Polar Align;" "Precise GoTo;" "Synch Function;" the "Hibernate Function;" and, the other functions.
Best regards,
William
Patrick
Reged: 05/16/03
Loc: Franklin, Ohio
      #3085170 - 05/04/09 05:37 PM
William,
It's nice that Don is confirming most everything I've said. The one thing I didn't know was that the software was developed in China. Regarding the algorithms, I think you will find that they are highly proprietary, meaning 'trade secrets'. I don't know if you recall the 'goto wars' that Meade and Celestron fought out in court several years ago, but the bottom line was that Celestron had to redesign a number of their products, including their software. Because of that, I'll think it's highly unlikely you'll get the depth of information that I think you're looking for.
If I read Don's responsed correctly, he did not advocate using 4 alignment stars and 8 calibration stars, rather you quote him as saying, "I'm not sure it's real critical because I've used the 3 stars chosen by the mount, I've chosen them myself, I've had them close together, and far apart, and the pointing accuracy has been good in every case." I read that to be a total of three stars. That mimics my experience as well, except I generally use a total of 4 stars (2 alignment and 2 calibration stars), as recommended in the CG5-GT manual.
I'm pretty sure Celestron has designed their new firmware upgrade to make it easier to get a good alignment, not harder. I can't find anywhere that Celestron makes the statement to add 4 calibration stars, and in fact, the CG5GT manual recommends only 2 calibration stars be added for 'optimal' accuracy (page 19 in the CG-5GT manual). If you can find the other recommendation, please let me know.
One practical thing you might try is to play around with the mount during the daytime. You could simulate the time, date and location of your planned observing trip and go through the alignment routine to see which stars it picks and in which order. If you have a planetarium program like the Sky 6, you could then plot the stars to identify their location and create the mapping program you're interested in seeing for those times and dates. With the planetarium program you can also see what the star elevations are and if there are any other good choices for alignment stars that the hand controller didn't pick. For reference you can use the Nextstar Resource site to obtain a list of all the named stars that Nexstar uses for it's alignment stars.
Patrick
AT66ED Refractor
My Astronomy Pages
Chris Rowland
Reged: 02/28/05
      #3085341 - 05/04/09 07:15 PM
I don't know where these rumours come from.
The AS-GT software is NOT developed in China. I know the developer and he isn't Chinese.
Synta do separate software for their mounts, I don't know where that's developed.
As for selecting alignment stars, my suggestion is not to get too hung up with selecting precisely the "correct" stars, a pair of stars that are reasonably well separated, by which I mean more than 40 degrees and less than 140 degrees, will do.
More importantly IMO is to do a good job of centring the stars you are using. Use a reticle EP.
Similarly for the calibration stars, choose reasonably well separated stars. If the alignment is going well then by the second or third star the alignment will be good enough that the next star is already almost centred.
There aren't any magic stars, the "secret", if there is one, is to do a good and consistent job of centring the ones you are using.
Chris
Patrick
Reged: 05/16/03
Loc: Franklin, Ohio
Re: AS CG5 GT New Software Alignment/Calibration Stars new [Re: Chris Rowland]
      #3085561 - 05/04/09 09:27 PM
Chris,
That's good to know. Thanks for clarifying who developed the software. I also agree with you that by the third or fourth alignment star the goto's are pretty close to being dead on. After that, if more precision is required, then the 'precise goto' feature can be employed, but quite frankly, I've never had to resort to that. I've even imaged faint objects without being able to see them in the eyepiece and only knew they were there after taking a photo.
Patrick
AT66ED Refractor
My Astronomy Pages
Tarzanrock
Reged: 12/07/08
Loc: Los Angeles
      #3085625 - 05/04/09 10:00 PM
Hi Patrick:
It seems that it is my mistake about the four (4) calibration stars. I must have gotten that wrong from all that I've been reading trying to figure this out.
I again checked the Celestron website as well as Swanson's and the Celestron Manuals -- they appear to recommend 3 calibration stars. I believe that they do recommend a first 2 star alignment with 3 calibration stars; then their polar alignment process; and, then a subsequent 2 star alignment process with 2 alignment stars and at least 3 calibration stars.
I have some planetarium software (The Sky version 6.2 or something like that and Starry Night Pro); and, I fooled around with it this afternoon using the parameters that Don recommended.
I'm interested in figuring out the alignment mapping for the New Moon in May around May 20th or so because that is likely the next time in which I may be able to get out to the desert to play with the telescope.
Given the 30 degree upwards parameter that Don advocates -- it looks as though the easiest and brightest stars on the East are: Arcturus; Spica; Vindemiatrix; Alakid; Mizar/Alcor; Izar; and, Murphid.
On the West it appears that the easiest and brightest stars are: Pollux; Castor; Procyon; [Capella (a little below the 30 degree line)]; Alphad; Regulus; Algieba; and, Denebola.
When I have some more time, I will set down with a more detailed map and try to figure out which alignment and which calibration stars have the greatest distance in terms of what you and Don have been discussing with me.
Once I determine which 2 intial alignment stars and which calibration stars within those parameters; I will then consider a second set. I am most interested to know how well the mount will perform once this stuff is figured out.
I have downloaded the CGEM Manual that you have discussed and am in the process of studying it.
At page 19 it states in italics: "Calibration stars that are near the equator offer the best results than the stars near the poles." Aside from the grammatical error in the sentence structure, I am curious what Celestron actually means by the use of the term "equator" because it is vague and ambiguous as it is used in this sentence in their manual. In figure 3-3 on page 20 Celestron defines what they mean by "The Meridian" but they do not define what they mean by their use of the word "equator." Moreover, Celestron's "May - June Sky" Map at about p. 66 has the "ECLIPTIC" drawn onto it.
There are two circles drawn near the edge of that map. I understand the the exterior circle is the map's boundary, but I do not know the significance of the interior circle next to the boundary demarcation. The question is whether the inside circle is supposed to represent the "equator" or is it merely the horizon line? It's pretty vague. On that map Celestron's alignment stars of Capella, Castor, Pollux, Regulus are clearly drawn near that line.
By the way, Celestron still has not responded to the e-mail message that I sent to them. I think that they are giving it due consideration and I anticipate a positive response.
Lastly, have you calibrated your Mount using the Calibrate Mount feature under the utility features as set forth on pages 28 and 29 of the CGEM manual? I am interested in the R.A. Switch Feature (p. 29) and I would assume that you would be interested in the Goto Calibration feature at page 29 since you do astrophotography.
William
7 registered and 3 anonymous users are browsing this forum.
