brianb11213
Reged: 02/25/09
Loc: 55.215N 6.554W
Alt-az mount warning
#3101833 - 05/13/09 06:59 AM
Nearly had a nasty accident with my WO FLT 110 / EZ Touch last night. I was carrying it "over my shoulder" to a better location to see an object low in the east, the tube swung round & clouted me on the head hard enough for me to see many unfamiliar constellations, in fact I was stunned for a few minutes and could easily have dropped the whole caboodle.
No damage to scope or mount, only a bump on the head which would probably have been worse if I hadn't been wearing a nice thick wollen beanie.
Must remember to check that the axes are tightened down before carrying the scope this way in the future.
Chase McNiss
Reged: 08/17/06
Loc: New Hampshire
Re: Alt-az mount warning
[Re: brianb11213]
#3101859 - 05/13/09 07:37 AM
Brian,
Glad you didn't drop anything and that you are OK but wondering if you came up with any names for the constellations you saw. Thanks for the heads up.
C
Starlighter
Reged: 08/03/07
Loc: Sunny California
[Re: brianb11213]
#3102356 - 05/13/09 12:27 PM
The exact same thing happened to me only with my Portamount with the SV102ED mounted.
I had loosened the tension on the azimuth since that scope needed it. As I picked it up, the scope swung around and clobbered me good! I though I was seeing stars only not through the scope!
Fortunately, I was able to set the rig down before I nearly fell down. I ended up with a nice bump on my noggin.
So people, like Brian said, be careful when you pick up an AZ mount with the scope still attached, especially if it's a heavier one. Make sure the tension is secure.
antilles72
Reged: 03/06/07
Loc: Rhode Island
[Re: Starlighter]
#3102412 - 05/13/09 12:53 PM
Thanks for the heads up as well. I always keep it tightened anyway, but I am human...
GShaffer
Reged: 02/28/09
Loc: Bogart, Ga USA
[Re: antilles72]
#3102947 - 05/13/09 04:46 PM
Better yet.....remove the OTA and carry them independantly..... your noggin and perhaps ultimately your pocket book will thank you
zjc26138
Loved By All
Reged: 02/24/05
Loc: Mingo Junction, Ohio
[Re: GShaffer]
#3103120 - 05/13/09 06:09 PM
Sorry about the bump on your head, but at least your scope and mount are ok.
I did the same thing with my AR5 and Skyview Pro Alt-Az, I didn't tighten the tension while moving the set-up and the AR5 swung around and hit me in the head. I survived and so did my equipment.
Starlighter
Reged: 08/03/07
[Re: GShaffer]
#3103122 - 05/13/09 06:09 PM
Well, the problem for me is I sometimes only have to move the mount several feet. That's because the object I'm viewing has gone behind the limb of a tree. To go to the effort of removing the scope each time would make it a royal pain.
zjc26138
Loved By All
Reged: 02/24/05
[Re: Starlighter]
#3103141 - 05/13/09 06:16 PM
Same for me.
GShaffer
Reged: 02/28/09
Loc: Bogart, Ga USA
[Re: Starlighter]
#3103169 - 05/13/09 06:28 PM
While I understand your point..... 10 feet or 1000 feet doesnt really matter if you knock yourself out or do major damage to the equipment as a result.....but then all life is a gamble
Jim7728
Reged: 04/10/05
[Re: brianb11213]
#3103275 - 05/13/09 07:22 PM
OUCH!
I took a good whack to the head when the 11lb weight attached to my Giro swung around while I was bringing it back into the house.
Luckily I have a thick head...luckily I have a brick head...
The bar counterweight now rests on my shoulder whenever I carry the tripod around.
brianb11213
Reged: 02/25/09
Loc: 55.215N 6.554W
[Re: Chase McNiss]
#3104012 - 05/14/09 05:09 AM
The Lumpy Head, The Wobbly Knees and The Compensation Lawyer
Seriously, though, it looks as though I'm not the only one to have had this particular accident ... if I've helped anyone else avoid similar, or worse, I'm happy.
