Alvin Huey
Reged: 10/18/05
Loc: NorCal
LXD-75 mount question - power adapter new
      #3105926 - 05/15/09 01:22 AM
I borrowed a friend's LXD-75 mount and forgot to get the power connector. Can someone tell me if I can get an adapter from Radio Shack, so I can make a power cord from my 12v power tank to the mount? Secondly is the positive terminal in the middle or side?
jrcrillyAdministrator
Refractor wienie no more
Reged: 04/30/03
Loc: NE Ohio
Re: LXD-75 mount question - power adapter new [Re: Alvin Huey]
      #3105927 - 05/15/09 01:26 AM
The center is positive. The connector is 5.5mm outside diameter, 2.5mm inside diameter and yes, Radio Shack has 'em.
Alvin Huey
Reged: 10/18/05
Loc: NorCal
Re: LXD-75 mount question - power adapter new [Re: jrcrilly]
      #3105944 - 05/15/09 01:47 AM
Thanks John. By any chance you have the part number from Radio Shack? so I don't have to bring the head there to match up.
LLEEGE
True Blue
Reged: 03/03/05
Loc: Cloud-chester,NY
      #3105949 - 05/15/09 01:54 AM
If you are going to buy a power supply, I'd suggest ordering one. Radio shack is way too expensive. Plus, their adapters can have the tip either P or N. If you mistakenly plug the connector in in wrong , bad things will happen.
Alvin Huey
Reged: 10/18/05
Loc: NorCal
Re: LXD-75 mount question - power adapter new [Re: LLEEGE]
      #3105964 - 05/15/09 02:17 AM
I'm not getting a power supply, but just the plug. Since John told me that the center is positive...slam dunk. Once I get the right adapter, I can wire it accordingly and plug it in my power tank or 12v lead acid battery.
Reged: 04/30/03
Loc: NE Ohio
      #3106165 - 05/15/09 07:31 AM
Dunno the part number, but the dimensions I supplied earlier should get you the right one.
Alvin Huey
Reged: 10/18/05
Loc: NorCal
      #3106356 - 05/15/09 09:54 AM
Thanks John, I'll make a run to Radio Shacck and get one. And bring the mount to be sure that I got the right one.
Alvin Huey
Reged: 10/18/05
Loc: NorCal
Re: LXD-75 mount question - power adapter *DELETED* new [Re: jrcrilly]
      #3106357 - 05/15/09 09:54 AM
Post deleted by Alvin Huey
jgraham
Reged: 12/02/04
Loc: Dayton, Ohio
      #3106385 - 05/15/09 10:11 AM
I don't have the part number, but I believe it's a size N connector.
Jerry3672
Vendor - Quantum Astronomy Products
Reged: 01/20/08
Loc: Lexington NC
Re: LXD-75 mount question - power adapter new [Re: jgraham]
      #3106627 - 05/15/09 12:50 PM
Size N is correct, just beware that the Radio Shack N will be a little loose and can cause a power loss. I used a radio shack n and ended up spreading the post out a bit to get good contact.
Alvin Huey
Reged: 10/18/05
Loc: NorCal
Re: LXD-75 mount question - power adapter [Re: Jerry3672]
      #3106826 - 05/15/09 02:26 PM
Got the part...going to work on it tonight.
Thanks all.
26 registered and 37 anonymous users are browsing this forum.
