azure1961p
Reged: 01/17/09
Loc: USA
OK - I'll throw this out there...
#3109629 - 05/16/09 11:37 PM
For $500 - what equatorial moutn with a clockdrive will securley hold a 40 pound load? Doesnt need computer anything - just an equatorial mount with drive and pedestal or tripod.
Has to be able to hold 40 pounds.
Im not interested in $2000 mounts . Totally out of the question. Ofcourse Ill considered decent used equipment.
Pete
Al Canarelli
Reged: 12/06/07
Loc: Central New Jersey
Re: OK - I'll throw this out there...
[Re: azure1961p]
#3109703 - 05/17/09 12:39 AM
While you're looking for your $500 EQ mount, let me know if you happen to run into a red sports car for me. Must cost $3,000 or less, get up to 200 mph in 6 seconds or less and get 40 miles/gallon or better.
Skylook123
Reged: 04/30/05
Loc: Tucson, AZ
[Re: Al Canarelli]
#3109771 - 05/17/09 01:43 AM
Unfortunately for Pete, Al will find his vehicle before Pete will find his mount.
Joe Aguiar
Reged: 02/10/07
Loc: Toront,Ontario
[Re: Skylook123]
#3110130 - 05/17/09 09:18 AM
The only one that can handle 40 lbs thats not expensive is EQ6 mount but not the newest one the older one & it going to be in the used market.
Even that it may be in the 600 to 700 range. It does have hand controller, drives but not goto & 2" steel legs.
If you can find the oringional black Skywatcher EQ6 you may find it in that price range if its a bit beat up but i think you will need go to 600 to 700 & they dont come by that often.
I would also reccommend the HEQ5 but that cant hold 40 lbs it rated for 30 the HEQ5, so it has to be the EQ6
Joe
Edited by Joe Aguiar (05/17/09 09:24 AM)
Joe Aguiar
Reged: 02/10/07
Loc: Toront,Ontario
[Re: Joe Aguiar]
#3110138 - 05/17/09 09:21 AM
Ok i found one for you in Canada again its the one i memtioned the older oringinal model.
Its on the Canadian verson astro-mart.
Its $750 cdn which is about $630US
PS this is not my add or my scope but i thought i seen one not too long ago & thought i pass the info to you to help you out. Si i did a seacrch & found it here the link.
http://www.astrobuysell.com/propview.php?view=14645
Joe
Hope that helps you
Reged: 07/06/07
[Re: Al Canarelli]
#3110211 - 05/17/09 09:57 AM
Me? I want a pony!
As for the cheapest mount that will handle 40-pounds? The Atlas might, barely, but to really accomodate that payload, at least a CGE or a G11 is my recommendation. That means about 2000 used.
Skylook123
Reged: 04/30/05
Loc: Tucson, AZ
[Re: rmollise]
#3110377 - 05/17/09 11:40 AM
Mine's doing 40 pounds OK, but I only do visual work. Picture taking-wise, Rod is certainly correct.
zjc26138
Loved By All
Reged: 02/24/05
Loc: Mingo Junction, Ohio
[Re: Skylook123]
#3110393 - 05/17/09 11:47 AM
I think the best thing to due is save up for a used Celestron CGE.
azure1961p
Reged: 01/17/09
Loc: USA
[Re: Al Canarelli]
#3110523 - 05/17/09 01:19 PM
I found it. Unfortunatley its as old and used as the equatorial mount I turned down. I think its an alfa spider.
I thought I made it clear I was accepting used. Now you have to go to california and pick it up.
Pete
Joe Aguiar
Reged: 02/10/07
Loc: Toront,Ontario
[Re: azure1961p]
#3110650 - 05/17/09 02:33 PM
Just to be clear the Atlas is the same as the Skywatcher EQ6 just so Pete knows.
Joe
Joe Aguiar
Reged: 02/10/07
Loc: Toront,Ontario
[Re: Joe Aguiar]
#3110653 - 05/17/09 02:34 PM
Hey pete you found one great how much was it if you dont mind. Do you have a link of the add?
Was it like my link?
Just curious.
Joe
