David Rivas
Reged: 05/29/04
Loc: Lima, Peru
Old Celestar 8 OTA on CG5?
#3113274 - 05/18/09 08:47 PM
Hello, I got a trusty Celestar 8 Deluxe, optically it has always been superb. However as I attach more and more accessories(those ones necessary for planetary imaging), it's prone to vibrations(RA motor vibrations). I'd like to know if there is a way to attach my Celestar 8 OTA to a CG-5GT ... BTW, it's on "clearance sale" at OPT ( $ 590.00 ) Perhaps someone could tell me if there's a dovetail that fits my Celestar 8(or any other way). If so, where can I purchase what's necessary to mount it properly on it? Thanks in advance!! David
LLEEGE
True Blue
Reged: 03/03/05
Loc: Cloud-chester,NY
Re: Old Celestar 8 OTA on CG5?
[Re: David Rivas]
#3113329 - 05/18/09 09:27 PM
You need a vixen style dovetail for the C8. OPT sells them too.
David Rivas
Reged: 05/29/04
Loc: Lima, Peru
[Re: LLEEGE]
#3113469 - 05/18/09 11:01 PM
Thank you very much Luke! I did see OPT had such dovetails, but I didn't know the CG-5 was a Vixen style one  Now, would any vixen style dovetail do the job, or is there any recommended?? Thanks!!! David
Joe Aguiar
Reged: 02/10/07
Loc: Toront,Ontario
[Re: LLEEGE]
#3113472 - 05/18/09 11:04 PM
vixen bars are sold by almost every in this hobby, I just measured my Celestron 8 SCT & its 13".
There is one thing though, my Nexstar8 I tried to remove it from the fork arm & put it on the newer SE mount & got a bar just like you are doing but that scope did not have maching holes to put a vixen bar.
So get OPT to look & see if your OTA has holes to put a vixen bar. because the oringinal Nexstar8 was meant for the none removeable fork arm they did not put match holes on the front to back of the ota there were a couple screws holes but it would have been on an angle.
Hope that helps
Joe
Rusty
Reged: 08/06/03
Loc: Brooker, FL
[Re: Joe Aguiar]
#3113525 - 05/18/09 11:32 PM
You'll need "radius blocks" to mate the OTA to the dovetail. Screw holes should match up.
Joe Aguiar
Reged: 02/10/07
Loc: Toront,Ontario
[Re: Rusty]
#3113541 - 05/18/09 11:42 PM
it should match but didn't in my case so better make sure & if you buy the vixen bar from them ask them to install it before shipping it out to you. They should be able to do this if you are buying a bar & OTA.
Joe
Qkslvr
Reged: 06/23/06
Loc: NE Ohio, US
[Re: Joe Aguiar]
#3113945 - 05/19/09 07:25 AM
I bought some 8" rings and mounted a dovetail to that to mount my Nexstar 8 OTA on a CG-5, Works just fine.
ibase
Vendor Affilliate
Reged: 03/20/08
Loc: Manila, Philippines 121*E 14*N
[Re: Joe Aguiar]
#3113950 - 05/19/09 07:31 AM
David, I used this Vixen-type dovetail bar on my de-forked Nexstar 8 OTA:
http://www.amazon.com/Orion-8-Dovetail-Mounting-Plate/dp/B000YPRVFI/ref=sr_1_1?ie=UTF8&s=electronics&qid=1242731777&sr=8-1
and these curved mounting blocks to make unnecessary drilling any hole on the OTA:
http://www.astronomics.com/main/product.asp/catalog_name/Astronomics/category_name/CUHH9F3HKV579LMJ8CC9R6WV80/product_id/VCB8
No drills used or any holes inflicted whereever; all stock off-the-shelf parts. Does the job and the 8 OTA is now securely perched atop my newly acquired CG-5 GT. Hope this helps.
Best,
ibase
Vendor Affilliate
Reged: 03/20/08
[Re: ibase]
#3113953 - 05/19/09 07:37 AM
Oops, I mean this dovetail:
http://www.amazon.com/Orion-13-Dovetail-Mounting-Plate/dp/B000YPTZU2/ref=sr_1_3?ie=UTF8&s=electronics&qid=1242732927&sr=1-3
David Rivas
Reged: 05/29/04
Loc: Lima, Peru
[Re: ibase]
#3114176 - 05/19/09 10:14 AM
Joe, Rusty, Mike, Hernando, THANK YOU SO MUCH TO EACH ONE OF YOU GUYS!! Now I got more than enough info to ask a lot of questions to OPT... you all have helped me a lot, thanks!!! Best regards,
David
Joe Aguiar
Reged: 02/10/07
Loc: Toront,Ontario
[Re: David Rivas]
#3115095 - 05/19/09 04:41 PM
good luck & let us know how it goes.
Joe
David Rivas
Reged: 05/29/04
Loc: Lima, Peru
[Re: Joe Aguiar]
#3116014 - 05/20/09 02:46 AM
Joe, Thanks a lot for your kind and valious input! I will keep you informed once I do the purchase. THANK YOU!!! David
