shelley
Reged: 03/08/09
Loc: Massachusetts, USA
Well, last night I had my first chance to try the scope (Meade ETX 125EC). I had a great view of Saturn with the 9mm EP. It was extremely hard to track it manually as I am used to it with my Dobs. I connected the electronic controller and it was a breeze!. One thing I noticed when focusing is , if I am going clockwise it focus fine but if I go over slightly the focusing point backing up the knob counter clock wise does not bring it back into focus I have to make a whole turn and then go at it again from the clock wise direction. Is there something I can do to adjust this? or is it the nature of the Mak design? I guess I am used to the 2 speed Crayford style focuser on my Dobs which if I go over slightly I can bring it back into focus by going in the reverse direction. I hope this can be rectified by some type of adjustment. any suggestions will be greatly appreciated..!
Thanks...!
-------------------- Zhumell Z10 deluxe Dobsonian-
Meade ETX-125EC Maksutov Cassegrain-
brianb11213
Reged: 02/25/09
Loc: 55.215N 6.554W
It's not correct. Try working the thing over its whole range - in and out - a few times, just in case the grease has congealed, this will even it out.
There is usually a bit of backlash in the focus knob but nowhere near a whole turn!!!
John Carruthers
Skiprat
Reged: 02/02/07
Loc: Kent, UK
Sounds like a little play where the focus screw runs in the mirror carrier. A stronger spring would help or a shim to take up the slack, a nylon or teflon washer would be good. (ignore the "bezel popped out" bit, that was another scope)
-------------------- Jc
ATM 10" F6.1, 1/25th wave spec (max wavefront error +/- 1/12.6 in zone 4 of 6, sodium light )
6" F7 spec
127mm F9.4 Refractor
10 x 50 bin
ETX80 (finder)
Canon 20D
PST
DSI 1
and a curious mind
Edited by John Carruthers (05/22/09 07:34 AM)
JT5
Reged: 11/08/07
Loc: Ozarks of Missouri
Shelly. Check for an Astronomy club in your area. If you contact them you should be able to get some hands on help from a member. The Meade ETX scopes are fairly common. I would hesitate in suggesting a "newbie" try to dig in and fix the problem.
John
My wife shares my love of the night skies and tolerates all of my other hobbies.
Televue Pronto w/Starbeam pointer and Televue tripod
Meade 2045D, ETX-125PE, 12" Lightbridge
Celestron: 7Amp PowerTank, 15X70mm binoculars
Meade, Swan and Televue Lenses (33, 26, 20, 15 & 9mm), Televue Barlow
Catsperch Observing Chair
Member: Astronomical Society of Eastern Missouri
jgraham
Reged: 12/02/04
Loc: Dayton, Ohio
I don't know if it's 'nomral' or not, but I've long had the habit of always setting the focus in one direction; if I over-shoot I'll turn back and try again. I don't think I've ever seen a stock focusser on any scope that I could afford that didn't have some backlash. I even use the stock focussers on my imaging scopes with the same procedure.
-------------------- -John
Homebuilt scopes from 4.25-16.5"
Meade LXD75-N6/SN6/SC8, DSX-90, ETX-60BB, ETX-125PE, DS-2130
Orion StarBlast, BinoViewers, Coronado PST
Rebel XT/XTi, DSI Pro (I, II, & III), DSI, LPI, Electronic Eyepiece, Phillips SPC900NC
Tasco 60mm Refractors
2 registered and 4 anonymous users are browsing this forum.
Moderator: Shadowalker, oldsalt
