Privacy Policy |
Please read our Terms
of Service | Signup and
morden8uk
Reged: 03/01/05
Loc: Southampton, England
Help!.. need instructions to build a dob mount
#3118287 - 05/21/09 07:51 AM
Hi All,
I'm trying to find some instructions on how to build a dob mount for 8" Orion Optics OTA. I'm currently using the 1200mm tube on a CG5, but would prefer a dob setup. The Orion Optics dob base costs £260!! - £over $300 which is criminal... surely I could build my own?.
Any help gladly received.
Thanks Rob
LLEEGE
True Blue
Reged: 03/03/05
Loc: Cloud-chester,NY
Re: Help!.. need instructions to build a dob mount
[Re: morden8uk]
#3118355 - 05/21/09 08:38 AM
You may want to post this in the ATM forum.
morden8uk
Reged: 03/01/05
[Re: LLEEGE]
#3118383 - 05/21/09 08:56 AM
Ahh, yes... thanks
Doug76
Long Achro Junkie
Reged: 12/05/07
Loc: Refractor Heaven
[Re: morden8uk]
#3118416 - 05/21/09 09:11 AM
And they are very easy to build. When I bought my Dob Driver for my 12" Lightbridge, I didn't want to cut or alter my original mount, so I built a new one. Easy.
John Carruthers
Skiprat
Reged: 02/02/07
Loc: Kent, UK
[Re: morden8uk]
#3118896 - 05/21/09 01:37 PM
Hi, first find the ballance point of your tube with all the finders/EPs etc attached, this will give you an idea how high to make the rocker box sides. Decide how big the side alt bearings will be, similar to the mirror diameter is a starting point, larger is good = lower rocker sides = less flex. Now you can draw up a plan that allows the tube to reach both the zenith and slightly below horizontal (I found this out trying to watch the transit of Mercury as it rose from the sea). The tube needs to be a snug fit between the sides or you get slop when you slew. Fit textured hard laminate to the base and alt bearing surfaces. Make a ground board, triangular for less weight or round so you can fit a setting circle later. Aply teflon blocks so the overall loading is around 14 psi, ymmv. Some glue etched teflon, I countersink and pin it. Point and go.
beachchairbill
Reged: 11/06/08
[Re: John Carruthers]
#3119748 - 05/21/09 09:43 PM
Ask Dennis at Dobstuff.com and see if he can help you
BB
30 registered and 36 anonymous users are browsing this forum.
Calendar Event: 05/21/09
