lowdog
Reged: 09/15/08
Loc: N. Suburbs Chicago
G11 Dec. Clutch Knob Problem new
      #3136551 - 05/30/09 09:56 PM
Tonight I was setting up for imaging session and when it came time to balance I could not loosen the dec. clutch knob. The dec. shaft will move when I try to loosen the knob but not freely enough for balancing. The knob is locked tight. Have any other G11 owners had a similar problem. Please let me know.
Jeff
revans
Reged: 09/26/05
Loc: Fitchburg, MA
Re: G11 Dec. Clutch Knob Problem new [Re: lowdog]
      #3136587 - 05/30/09 10:23 PM
Why not cover a pipe wrench with a towel so as not to leave any marks behind, and force it loose? You could also use some WD40 spray sparingly and see what happens after a couple of hours...
Just my 2 cents... I just got my G11 a couple of days ago, so I'm not particular expert on this mount...
Rick Evans
Charlie HeinAdministrator
Reged: 11/02/03
Loc: 26.06.08N, +80.23.08W
      #3136696 - 05/30/09 11:33 PM
Jeff
I've not seen this. Do you have the upgrade clutch knobs?
LLEEGE
True Blue
Reged: 03/03/05
Loc: Cloud-chester,NY
Re: G11 Dec. Clutch Knob Problem new [Re: revans]
      #3136731 - 05/30/09 11:52 PM
NO! Do not use a pipe wrench. Even with a towel it will mar the surface. If you must, try a strap wrench.
lowdog
Reged: 09/15/08
Re: G11 Dec. Clutch Knob Problem new [Re: Charlie Hein]
      #3136735 - 05/30/09 11:53 PM
Yes, I have the upgrade knob on both axis so I try not to tighten them to much.
blueman
Vendor Blue Sky Accessories
Reged: 07/20/07
Loc: California
Re: G11 Dec. Clutch Knob Problem new [Re: LLEEGE]
      #3137605 - 05/31/09 01:13 PM
Agreed, a pipe wrench is not the answer.
Have you grabbed the top saddle and tried to turn the knob?
Blueman
lowdog
Reged: 09/15/08
Re: G11 Dec. Clutch Knob Problem new [Re: blueman]
      #3137791 - 05/31/09 02:57 PM
I was finally able to loosen the knob today by tapping on one of the knob spokes with a rubber mallet. I don't know how it got so tight because I only hand tighten them. I store it in a square plastic tub on top 4 inches of foam padding. It lays on its side so maybe their was to much pressure on a spoke causing it to over tighten. Thanks to all who replied.
Jeff
blueman
Reged: 07/20/07
Loc: California
Re: G11 Dec. Clutch Knob Problem [Re: lowdog]
      #3138669 - 05/31/09 10:29 PM
Probably the temp difference between when you tightened it and tried to loosen it?
Blueman
12 registered and 36 anonymous users are browsing this forum.
