tjay
Reged: 02/03/07
Loc: Brooklin, Ontario (just east o...
I just won an auction on eBay for a Meade 497 that I'm going to use with my ETX-80. I hope I didn't incorrectly recall that the 497 works properly with the ETX-80.
Does anybody have any tips for setting one up with an ETX-80? The one I've won is unused, in new condition, just old stock from a liquidated retailer. Will I need to upgrade the firmware before it will work properly?
-------------------- Clear Skies
Nexstar 8 GPS
GSO 8" Dob
Meade ETX 80
Canon XSi (unmodded)
Kendrick Dew Heater
11mm, 20mm Agena Astro UWA
40mm, 32mm, 26mm, 20mm and 15mm Meade Series 4000 Super Plossl
25mm and 10mm GSO Plossl, GSO 2x barlow
GSO 2" Dielectric diagonal
Antares f6.3 focal reducer
Philips SPC900NC
AlexDJ30
Reged: 09/02/08
Loc: Monterrey, Mexico
Yes has far i know its compatible, but if its old it means have a older firmware, you will need to upgrade the firmware for the latest one (because in the old ones doesnt appear the etx-80 on the list of scopes, many choose the etx-70 one in this older controll so the scope works fine) but i think its a better idea to upgrade the firmware to the latest so the etx-80 appears on the list plus maybe maybe better tracking and less bugs around.
-------------------- Equipment:
- ETX 125 AT
- C6 ASGT
- WO 66mm SD
- 2.5X ED Barlow, 8-24mm Zoom Eyepice
- Canon EOS Rebel XSi
- Celestron Nextimagen
- Orion Starshoot CCD cam
tjay
Reged: 02/03/07
Thanks for the reply. I'll definitely look at upgrading the firmware once I get it.
Nexstar 8 GPS
GSO 8" Dob
Meade ETX 80
Kendrick Dew Heater
Philips SPC900NC
yock1960
Reged: 06/22/08
Loc: SW Ohio, USA
It works and having the number buttons is nicer!
Steve
-------------------- LXD75 GEM
Orion Starblast 4.5" Imaging Reflector
William Optics Zenithstar 66 SD APO
Meade DSI II OSC
Meade DSI III OSC
Orion Starshoot Autoguider
Televue Powermate 2.5x
Discovery 6" Dobsonian
Nikon Action Extreme 10x50's
Gallery
tjay
Reged: 02/03/07
Steve
Thanks Steve, that's what I'm hoping
Apparently the package has made it through Canada Customs this morning, so I'll probably get in Monday sometime.
Nexstar 8 GPS
GSO 8" Dob
Meade ETX 80
Kendrick Dew Heater
Philips SPC900NC
tjay
Reged: 02/03/07
I got my #497 last night, and it seems to work properly when tested indoors, or at least it will go through the alignment, slew when I pick objects. I'll be trying to get the Meade 505 cable set this weekend so that I can upgrade it to the latest firmware version.
Are there any gotchas with upgrading these guys? I think I've got firmware version 22e on it right now.
Nexstar 8 GPS
GSO 8" Dob
Meade ETX 80
Kendrick Dew Heater
Philips SPC900NC
Joe Lalumia
Reged: 01/24/07
Loc: Rockwall, Texas, USA
Once you upgrade the firmware do a RESET -- then Calibrate motors and train drives again-- be sure to re-enter TIME- DATE- and SITE-- and Daylight Savings Time = YES.
Calibrate motors with the same power supply you will use outside--
Clear Skies!
-------------------- LX90 8" LNT, SV Nighthawk & TelePOD, SV 80/9D & M4 mount, ETX 90, Orion XT10i, 20x80 binoculars, SV-BV3s-- www.texasastro.org
"Great minds discuss ideas;Average minds discuss events;Small minds discuss people." Unknown
caheaton
Reged: 05/26/09
Loc: SW Ohio
Like Joe said...but also, change the time (or at least double check it) AFTER you change the menu setting for daylight savings time to yes. I changed DST after setting the time and the first time I used my scope, it was consistenly off base. A check of the time showed it was an hour fast (so the scope was correct...it was just slewing into the future)  Craig
-------------------- Craig
Ancient Tasco 4.5" (from back when Tasco's were good)
Meade ETX-80
Orion XT10i
Meade Super Plossls 6.4, 9.7, 15 & 26mm
Zhumell Z Planetary 3mm
Agena Ultra Wide 30mm
tjay
Reged: 02/03/07
Clear Skies!
Joe, thanks. You seem to have the answers to a lot of my questions
Nexstar 8 GPS
GSO 8" Dob
Meade ETX 80
Kendrick Dew Heater
Philips SPC900NC
tjay
Reged: 02/03/07
Thanks Craig. I'll make sure I double check that.... Nice to learn from somebody else's mistakes.
Nexstar 8 GPS
GSO 8" Dob
Meade ETX 80
Kendrick Dew Heater
Philips SPC900NC
3 registered and 6 anonymous users are browsing this forum.
Moderator: Shadowalker, oldsalt
