sang33ta
Reged: 07/08/08
Loc: UK
You can get GPS for Autostar. Perhaps Meade didn't sell it direct (I can't remember) but Celestron did, I always thought it was a clock conspiracy. Pre LNT of course, now it's an atomic clock module.
-------------------- Hioptic 152mm f12.5 Maksutov, CG5-AGT, Meade Super Plossl Set, Casio QV-2900UX
Edited by sang33ta (04/12/09 10:30 PM)
Reged: 07/06/07
Celestron does sell one, but it won't work with Meade scopes. Meade has not sold one direct or otherwise. A couple of 3rd parties have sold GPS receivers for the ETX, but IMHO they were a little kludge-licious, and with the coming of the LNT, not nearly so desirable.
-------------------- Uncle Rod
Rod's New Book:
Choosing and Using a New CAT
Available now!
ryanAg
journeyman
Reged: 03/15/09
It worked!!!!
Ok, took out the scope last Friday night, despite having mosquitoes all around me, to give the scope one more shot. Well, I went through Auto align and like normal the scope was way off when it pointed to the alignment stars. I adjusted the scope and centered the stars. After getting both it said, "Alignment Sucessful." I thought, "Yeah Right!" I go to the tour and the first object is the Moon. I don't even bother putting a filter on the eyepiece because I know it won't land anywhere near the moon. Well, it slings and finally beeps. I take a look through the EP and am suddenly blinded!! It landed smack dab in the middle of the moon! I couldn't believe it! I figured it was just dumb luck so I decided to go to Saturn. It slings and beeps, I take a look and it has Saturn nearly dead center in the FOV! I can't believe it! I then go to Vega with the same results. At this point I'm getting devoured by bugs so I quickly pack everything up and leave. I don't get it. I haven't done anything to the scope since my last failed attempt and I haven't even done any drive training! I don't know what happened but I'm loving the scope now!
Quads
Reged: 09/07/08
Loc: Central Sands, Wisconsin
That's great news!
-------------------- I'm a "just for fun" photographer that also takes nighttime sky pictures.
Meade ETX-80AT-TC-BB
Canon PowerShot SX100 IS
Affordable Astrophotography
Powered by Ni-MH Rechargeable Batteries
brianb11213
Reged: 02/25/09
Loc: 55.215N 6.554W
It obviously only works when chock full of hungry mossies.
ColoHank
Reged: 06/07/07
Loc: western Colorado
Now that you've finally got your scope doing what it's supposed to do, go to Wallyworld, or wherever, and get yourself a portable Thermacell mosquito/black fly repellant gizmo. It's cheap, it'll work every time, and you'll be able to observe without having to worry about feeding those pesky bugs.
Questar 3.5 standard - pyrex and BB coatings
Powerguide II
8mm, 12mm, 16mm, 24mm and 32mm Brandons
modified Bogen 3030 w/ homebuilt wedge
Homebuilt Galileo scope
other odds and ends, including iPod Touch with StarMap Pro (what a marvelous combo)...
"Nothing exists but atoms and empty space. Everything else is opinion."
Titus Lucretius Carus 99-55 B.C.
JT5
Reged: 11/08/07
Loc: Ozarks of Missouri
This is a question, not a suggestion....In the initial set-up, isn't Calibrate Sensors required to get best alignment from the LNT? I'm assuming this corrects any misalignment of the LNT from accurate level and pointing.
John
My wife shares my love of the night skies and tolerates all of my other hobbies.
Televue Pronto w/Starbeam pointer and Televue tripod
Meade 2045D, ETX-125PE, 12" Lightbridge
Celestron: 7Amp PowerTank, 15X70mm binoculars
Meade, Swan and Televue Lenses (33, 26, 20, 15 & 9mm), Televue Barlow
Catsperch Observing Chair
Member: Astronomical Society of Eastern Missouri
Joe Lalumia
Reged: 01/24/07
Loc: Rockwall, Texas, USA
Calibrate sensors adjusts the LNT for your magnetic deviation at your SITE-- your first alignment star should be CLOSER after this calibration---
PS-- personally I may still need to move the scope a little bit to get the first star inside a 20mm eyepiece..... sometimes. But like I have said-- for public observing I usually setup during the daytime and just push the ENTER key for each alignment star (which I cannot actually see yet!) --- then later GOTO a NAMED star, center and SYNC.
I know this is NOT in the manual but it works!
-------------------- LX90 8" LNT, SV Nighthawk & TelePOD, SV 80/9D & M4 mount, ETX 90, Orion XT10i, 20x80 binoculars, SV-BV3s-- www.texasastro.org
"Great minds discuss ideas;Average minds discuss events;Small minds discuss people." Unknown
JT5
Reged: 11/08/07
OK, thanks Joe.
John
0 registered and 8 anonymous users are browsing this forum.
Moderator: Shadowalker, oldsalt
