CyberJeepEric
Reged: 05/11/09
Loc: Pompano Beach, FL
Since I cannot get mt scope to power up, the LNT viewfinder is useless. I am thinking about trying the Telrad Reflex Sight on it. Any opinions? Should I get the standard Meade 828 8x50 finderscope?
Also, does anyone know if the jack on the side of the LNT is a power jack? If so, does anyone know voltage/polarity/size?
Joe Lalumia
Reged: 01/24/07
Loc: Rockwall, Texas, USA
I would recommend the Rigel Quickfinder-- see these-- http://www.cloudynights.com/documents/finders.pdf
here is a picture -- http://www.flickr.com/photos/boatman1/2145341118/
ETX90 is behind the LX90 on a table
-------------------- LX90 8" LNT, SV Nighthawk & TelePOD, SV 80/9D & M4 mount, ETX 90, Orion XT10i, 20x80 binoculars, SV-BV3s-- www.texasastro.org
"Great minds discuss ideas;Average minds discuss events;Small minds discuss people." Unknown
CyberJeepEric
Reged: 05/11/09
Thank you for the input. From that review, looks like the Telrad is a better choice. Why do you recommend the Rigel for the ETX125?
Edited by CyberJeepEric (06/01/09 05:28 PM)
Joe Lalumia
Reged: 01/24/07
Because it's not the "same" size as the scope!!! well almost!
Captain Gadget
newbie
Reged: 03/20/09
Loc: Desborough, Northants
The Jack on the side of the LNT unit is for the atomic clock update module.
Meade ETX 125PE
Revelation 10" Dobsonian
Various Televue Eyepieces
Swamp Fox
Reged: 12/26/06
Loc: Goose Creek, South Carolina
I would recommend the Rigel Quickfinder....
+1 on the Quickfinder...works great!
-------------------- Tele Vue 102
Tele Vue 35mm Pan; 22mm T4 Nagler; 17mm T4 Nagler; 12mm T4 Nagler; 10mm Radian; 2x Powermate
Meade ETX 125PE
Meade 4000 26mm SP; 24.5mm SWA; 15mm SP; 14mm UWA; 9.7mm SP; 8.8mm UWA; #140 2x Barlow
JT5
Reged: 11/08/07
Loc: Ozarks of Missouri
Why does your scope not power-up? Did you replace the batteries? Is the Autostar Dead? Or is it that you just don't have a need for a scope with the tracking capabilities of the PE?
Curious? John
My wife shares my love of the night skies and tolerates all of my other hobbies.
Televue Pronto w/Starbeam pointer and Televue tripod
Meade 2045D, ETX-125PE, 12" Lightbridge
Celestron: 7Amp PowerTank, 15X70mm binoculars
Meade, Swan and Televue Lenses (33, 26, 20, 15 & 9mm), Televue Barlow
Catsperch Observing Chair
Member: Astronomical Society of Eastern Missouri
KWB
Reged: 09/30/06
Loc: Westminster,Co Elev.1646Meters
IMO this scope can benefit from using a finder,even if it's operating properly and used in the manual mode. A RDF similar to the one Orion sells as the reflex deluxe would be handy tool. I wish this finder existed when I owned my EXT-125.
-------------------- Kenny
"Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe." - Albert Einstein
CyberJeepEric
Reged: 05/11/09
Long story of what I've checked so far with the power issue, see my other post. I just received my Telrad last night. I haven't had a chance to use it due to South Florida weather, but as far as the size, I think it is ok on the ETX-125. I'll post an update as soon as I get to actually use it.
JT5
Reged: 11/08/07
Eric I went back and reviewed your other posts. Have you contacted anyone at an Astronomy Club near you? If not there is a list at:
http://www.astronomyclubs.com/1/190/11/0/club.aspx
This lists all of the Florida Astronomy Clubs. Members of Astronomy Clubs almost always have a member or two that has the talent to assist in finding the problem with your scope. They just need to dig into the scope and find the problem. The ETX scopes are so common, someone in the club is likely to have one that could try their cables and controllers with your scope. It could be a damaged wire or blown circuit board or the like you should be able to trace the problem to and get a replacement item once the problem is narrowed down. Club members would also likely know where to obtain the items without having to deal with Meade directly.
John
StarWars
Reged: 11/26/03
Loc: CyberSpace
Here's a Rigel on a ETX-PE..
(not mine)
-------------------- Sony Digital Media player..
MX 460 earbuds
Celestron 2x Barlow Lens
Orion Collimation Eyepiece
Rigel Quick Finder
Assorted Bino's
sailor70623
Reged: 01/12/08
Loc: Ok.
I used a Daisy red dot on my ETX127 along with the cheesey optical finder it came with. Less than $10 bucks. Heck it's a 5" Mak, It's not for DSO work, but is a geat solar system scope. Brighter DSOs ar eay enough to find, especailly with the COL. Good luck fixing your scope, hope it's something simple.
-------------------- Corornado PST
LB 16" & 12"
Z 10"
LX50 8"
8" CPC
ETX127
102&90mm MAKs
80mm Richfield APO
70mm refractor
ETX60
