adamsp123
Reged: 11/20/08
Loc: welshpool mid wales UK
Guiding a Vixen Sphinx new
      #3162339 - 06/14/09 12:21 PM
Setup was C80ED on a Vixen Sphinx mount with Starbook controller, QHY5 guidecam, netbook PC.
Software used QHY5(1024) driver and PHD....
Ok ....connect PC to QHY5 and QHY5 to Starbook autoguider port (there is no port on the mount)
So using "CCd labs Q Guider" for the Camera selection, and "On camera" for the mount, start images, I get pics of the stars on the Screen and focus, select star I get green box around the star.
I call up a grid and click PHD box to start guiding! I get H and V dotted lines through the guidestar but the mount doesn't correctly track, you can see the star dirfting slowly out of position. The green box is still there tracking the star but dotted cross hairs stay where star was originally located on the PC screen.
What have I not done, or done wrong??
Your ideas most welcome and thanks for any response.
Pete
tim53
Reged: 12/17/04
Loc: Highland Park, CA
Re: Guiding a Vixen Sphinx new [Re: adamsp123]
      #3162437 - 06/14/09 01:25 PM
I'm not familiar with your particular setup, but with my Tak mounts I have to make sure that I've set the mount up for the slowest guiding speed possible via the hand controller.
Similarly, I need to make sure that I set up Astro IIDC (that I use for guiding) to calibrate with reasonable durations on each axis, and reasonable pixel deviations. If I do it wrong, guiding doesn't work. But when I get it right, it does a fabulous job.
-Tim.
jrcrillyAdministrator
Refractor wienie no more
Reged: 04/30/03
Loc: NE Ohio
      #3162444 - 06/14/09 01:30 PM
Pete
Hi, Pete.
Any diagnosis will require a description of what you observed during calibration. That's when you can see what is and what isn't working properly.
karlpenney
Reged: 01/04/07
Loc: Halifax, NS
      #3162482 - 06/14/09 01:59 PM
What version of the firmware do you have in the Starbook? I think it needs to be at least 1.2 build 29 to allow autoguiding without entering keycodes.
adamsp123
Reged: 11/20/08
Re: Guiding a Vixen Sphinx [Re: karlpenney]
      #3164047 - 06/15/09 02:28 PM
This seems to be the problem I have build 28 doh! so update and try again.
Thanks to all for responses, most welcome.
17 registered and 31 anonymous users are browsing this forum.
