Jason BAdministrator
My wife says I am Obsessed...
Reged: 06/21/04
Loc: Mid-Michigan
"Motor Unit Fault"
      #3173790 - 06/20/09 09:17 PM
I am in the process of adapting some LXD55 Motors to my Vixen GP mount. When I first got them all mounted, etc, it worked great. After I got everything together, scopes mounted, etc, the hand control now reads "Motor Unit Fault".
I checked and everything is balanced, mounted correctly, etc. All I basically did was mount the motors, check to make sure the gears worked, move the mount around a bit with the hand controller and then shut it off. I then mounted the scope, got ready to observe/test it out and turned it on. That's when I got that message.
Any help or suggestions are greatly appreciated.
John Carruthers
Skiprat
Reged: 02/02/07
Loc: Kent, UK
Re: "Motor Unit Fault" new [Re: Jason B]
      #3174181 - 06/21/09 06:32 AM
First guess; loose conector.
Second, something's too tight and the motor's stalling.
3rd, low power?
crud on the encoder? (grasping at straws now)...
BCB
Undercover Saboteur
Reged: 11/24/03
Loc: Look over your shoulder
Re: "Motor Unit Fault" new [Re: John Carruthers]
      #3174302 - 06/21/09 09:41 AM
Try doing a "calibrate motors" after initial power up. Something may have changed. Then retrain the drives.
Those items should be in the utilities section of the menus..
Reged: 06/21/04
Loc: Mid-Michigan
Re: "Motor Unit Fault" new [Re: BCB]
      #3175060 - 06/21/09 06:44 PM
Thanks guys. No matter what button I hit, it goes to "Motor Unit Fault". I will try some of these suggestions though and report back.
Thanks! Keep em coming....
BRisley
Reged: 09/04/06
Loc: SW Florida
      #3175064 - 06/21/09 06:46 PM
Check with the Roboscoping Yahoo group.
Brian
sxinias
Reged: 10/04/08
Loc: Greece
Re: "Motor Unit Fault" new [Re: BRisley]
      #3175688 - 06/22/09 01:57 AM Attachment (37 downloads)
This croped up on the iOptron forum for the Nova GOTO. The problem there was power related .. too much line loss in power cord, too dirty or low voltage output from ac adapter, weak battery, etc.
Joe
Meade 2045 on DS2000
Celestron C6S on Skywatcher AZ GOTO
ccs_hello
Reged: 07/03/04
      #3175884 - 06/22/09 08:00 AM
Jason,
Meade "MUF" is a catch-all error message. Since you did the GOTO adaptation, the error reasons can be many. Few things I would check first are: proper cabling, wiring incorrectly, encoder light shield, and proper power source.
Clear Skies!
ccs_hello
Reged: 06/21/04
Loc: Mid-Michigan
Re: "Motor Unit Fault" new [Re: ccs_hello]
      #3175953 - 06/22/09 09:14 AM
Thanks guys!
7 registered and 27 anonymous users are browsing this forum.
