Privacy Policy |
Please read our Terms
of Service | Signup and
buckeye_hunter
Reged: 12/07/08
Loc: Ohio
Who else has a Takahashi EM-2S Mount?
#3174712 - 06/21/09 02:24 PM
Could I send you my hand controller to see if it works on your mount?
Thanks in advance...
Bob
buckeye_hunter
Reged: 12/07/08
Loc: Ohio
Re: Who else has a Takahashi EM-2S Mount?
[Re: buckeye_hunter]
#3181814 - 06/25/09 10:15 AM
No one. Really?
Chris Curran
Reged: 06/14/05
Loc: Brandon, FL
#3181870 - 06/25/09 10:37 AM
Why not send it to TNR instead?
buckeye_hunter
Reged: 12/07/08
Loc: Ohio
[Re: Chris Curran]
#3182286 - 06/25/09 02:31 PM
I spoke with Art at TNR. He was very helpful and this is not in any way meant to disparage him or TNR, but when he suggested sending it down but could not tell me whether parts were available or what the cost would be, I felt that was a bit too open-ended. I don't want to end up with a huge repair bill on a 20 year old mount that could go toward something else.
I know that TNR can get me a new stepper motor ($195), so if I can be assured the hand control works, I can buy the new motor.
I know that TNR cannot get me a new hand controller.
Clear Skies!
Bob
zawijava
Reged: 10/06/07
Loc: Wells, Maine 04090
#3184178 - 06/26/09 02:40 PM
Clear Skies!
Bob
Bob,
I used to have a Tak EM-1 mount, similar to yours...a bit older. It is quite a simple mount. I would venture a guess that any knowledgeable tech at Radio Shack could put a tester on the output leads of the hand control and verify if it's putting out power. Or even better, the mount is so light you could take the entire head in. With the motor cover(s) removed and hand control attached(with power) the tech could test it quite easily. BTW, is this a RA axis drive only or Dec axis as well? If dual axis drive, are they both not working? It's not likely that you'd have two drive motors fail at the same time.
Tim
GJJim
Reged: 09/09/06
Loc: Western CO
#3185247 - 06/27/09 08:59 AM
Please describe the hand controller you have. I owned a Tak EM-1 (RA drive only) and it had a simple controller with only two buttons - 2X and stop. There are no active electronics in the thing, just two switches and the interconnect cable to the mount. All of the electronic components are inside the mount itself, and it would run at the siderial rate even if the hand controller is disconnected.
buckeye_hunter
Reged: 12/07/08
Loc: Ohio
[Re: GJJim]
#3185616 - 06/27/09 12:52 PM
Tim,
This is a RA drive only. I am not so trusting of techs at Radio Shack. I do know that the stepper motor pulses when I connect to power source, so I know that the hand controller is receiving and sending power.
Jim,
The hand controller for the EM-2S has a power switch; a direction switch (hemisphere); a pause button; and a speed-up button. Sounds quite the opposite of the EM-1.
I have not been able to locate a schematic for the electronics. I know that the hand controller contains a crystal oscillator to send pulses to the stepper motor at a precise frequency to attain siderail rate. My brother used an oscilloscope and could not get a signal from the oscillator, so our best guess at this point is that the crystal is faulty. It is an odd frequency (821.444KHz) and so far I haven't been able to source a replacement to try. If I could confirm that the hand controller is shot, we could start building a new programmable stepper motor controller.
I was sent this link by someone on AstroMart:
http://www.telescope-service.com/Boxdoerfer/start/boxdoerfer.html
Very nice, but VERY PRICEY! Over $500 USD.
I would still love to find another EM-2S to test my hand contoller!!!
Thanks and Clear Skies!!!
Bob
tim53
Reged: 12/17/04
Loc: Highland Park, CA
#3185979 - 06/27/09 06:32 PM
What does your hand controller look like?
My old EM-500 mount has two toggle switches and 2 dec and 2 RA buttons on it IIRC. None of my current Tak mounts (the ~1993 EM-500 non-goto, 2000 NJP Temma PC, EM-10 Temma 2 Jr) have powered hand boxes - they're just switches that plug into the mount.
Have you ever seen this Tak history web page?: Tak mount history
There are a couple of pics of EM-2 mounts on it, but they don't show the hand controller. But one of the other mounts pictured might have the same hand controller.
-Tim.
buckeye_hunter
Reged: 12/07/08
Loc: Ohio
[Re: tim53]
#3186457 - 06/28/09 12:45 AM
Scroll down in the manual
http://www.takahashiamerica.com/manuals/EM_2S%20Manual.pdf
Page 5 shows the hand controller.
Bob
7 registered and 24 anonymous users are browsing this forum.
