gaz-in
Reged: 12/17/07
Good Evening All,
Now that I have figured what size secondary to order for my 14.5 inch Telekit project, my question is: How good of a secondary do i need. I realize this is a very subjective question. But I am interested in any input. Has anyone used a $75 secondary, replaced it with a $175 one, and noticed a difference? How about the difference between quartz and pyrex?
Thanks in advance for the input. Dan
bbasiaga
Reged: 05/10/06
Here's the thing - the optical system is only as good as its weakest link. I'd hate for that to be a major optical component such as the secondary. Stick with a good name brand like Galaxy or Protostar. Others will chime in with those they've had good luck with I'm sure.
I'd be interested to know how the quartz ones perform as well. I don't think they're common in the size I need for my project, and are quite a bit more expensive. Still, I'd be interested to know what their advantages are besides thermal stability.
I hope you're enjoying your telekit project. Have you actually received it yet? I did a 15" f/5 Telekit a few years back. Love it. I also used Randy for the secondary holder and spider for my current DIY. If you've got any questions as you go along with the telekit, let me know I'll be glad to help. Randy is quite accessible too, and his instructions are very good, so you may not need me, but I'm here if you do.
-Brian
-------------------- Vixen 80EDSF
Stellarvue 102ED2
Orion Atlas 11 EQ-G
15" Astrosystems Telekit w/ Discovery Optics
Lust for something Larger
Lust for something Larger than that
Past Lovelies:
Oberwerk 20x100 binocs
Meade AR5
Meade LX10 8" SCT
All sold to a good home
llanitedave
Humble Megalomaniac
Reged: 09/26/05
Loc: Amargosa Valley, NV, USA
It's my understanding that the surface of quartz can be given more micro-smoothness than pyrex. I haven't heard that this is a real issue in any practical sense.
Someone with broader knowledge than me will have to chime in about whether there's a real quality difference. To answer the original question, I'd advise to get the highest quality secondary you can afford. Fortunately, they aren't hard to find. The brands mentioned above have excellent reputations.
-------------------- "Since the process of science generates more mysteries than it solves, I predict that we'll never learn everything: and we'll continue to generate new ignorance at the speed of knowledge."
"S.O.E." (Sauron's Other Eye), with 16" Royce conical mirror: A permanent work in progress.
10" Homebuilt dob, old Coulter mirror
Under Construction: The "Eye of Sauron" Observatory!
Bird
Reged: 08/07/03
Loc: Canberra, Australia
I'd suggest spending as much as you can afford... to quote Ripley, "It's the only way to be sure"
Bird
-------------------- Deep Sky Optics 13.1" f/5.5 newtonian,
PGR Dragonfly Express, PGR Dragonfly 2
RedHat Linux + Coriander
http://www.acquerra.com.au/astro/
Mike I. Jones
Reged: 07/02/06
Loc: Fort Worth TX
Agree - without posting up a bunch of supporting ZEMAX analysis and/or quoting Suiter, I can tell you with certainty that diagonal curvature more than 1/10 wave P-V is enough to generate astigmatism at high powers. 1/20 wave P-V in fused silica so it keeps it shape in changing temps is the way to go. Mike
walt r
Reged: 02/13/07
Loc: Doylestown, PA
Jay (look for his posts on Green Goblin scope) had two GSO secondaries that were astigmatic. Once he bought a high quality secondary the scope gave good images. Don't skimp.
-------------------- Walt
Obsession 18" f/4.45 #1370 AN/SC
MK67 Deluxe 6" f/12 Mak-Cass, Super Polaris GEM, JMI MicroMax DSC
DIY 60mm f/6 Achromat
Cookbook 245 CCD
Edited by walt r (07/02/09 11:56 PM)
Houdini
Reged: 07/13/07
Loc: Europe
Please do post a couple of ZEMAX analyses, I don't accept your certainty without proof .
Robert
-------------------- 16" f/4.9 motorized alt-az, 25" f/5 Dobson, 43" f/4 alt-az under construction
Mirror Edge Support Calculator
Mark Harry
Reged: 09/05/05
Loc: Northeast
My basic rule of thumb, a good smooth 1/8-1/10th surface error; no edge hook. General viewing, it'll kick butt on 99% of what you want to do. Try to keep any variance in the outer 1/4" of the secondary's aperture. Planetary or other hi-rez/hi-x stuff, get the best you can possibly afford. (big apertures will put you several hundred $ in the hole.) I tested one of Jay's secondaries when he was having trouble. Pretty sad! Mark
-------------------- So many projects, so little time!
Mark Harry
Reged: 09/05/05
Loc: Northeast
Might bring this point up to keep things on the same page. ************** Flats are tested to accuracies expressed as SURFACE ERROR, PV. (because they are basically just transmission elements, and the angles of incidence, and final systems error varies with application.) M.
Mike I. Jones
Reged: 07/02/06
Loc: Fort Worth TX
OK Rob you got it - a fair swap for your very fine deflection analysis of my 24" tapered blank a while back. Which one of your scopes do you want analyzed? How bout that 43" megascope? .... How far inside focus is your diagonal, and what diameter fully illuminated field?
I have initally assumed a 43" mirror radius of 344" (exactly f/4) and placed your diagonal 29" inside focus. For a 1" diameter fully illuminated FOV the diagonal is 8.25" x 11.668", in-plane offset 0.715", lateral offset 0.506" away from the focuser and toward the primary. Optical analysis next.
Houdini
Reged: 07/13/07
Loc: Europe
Mike,
Try a 16" f/5 with a 3.1" diagonal 12.6" from focus (my current planetary "grab & go" scope). Assuming a perfect primary and a 1/10 wave P-V diagonal curvature, how much astigmatism does one get?
I'm asking the question because this page claims that you can have 4 or 5 waves of curvature on the diagonal without problem.
Robert
jayscheuerle
Reged: 01/16/06
Loc: S. Philadelphia, PA
Yah... 2 mentions of my problems...
Secondaries get overlooked because they're smaller and they're flat, so it looks like no big deal, but when they're off, they can ruin all the good work your primary has done.
I've been very happy with my Protostar secondary. If you start off with a bad one and your experience is not great, it can be very frustrating trying to hunt down what your problem is. If you figure it out and replace it with yet another inexpensive one because you're pinching pennies and THAT one is astigmatic as well... THAT is maddening and throws your sleuthing confidence way off!
Buy a good one and forget about it. - j
-------------------- Fight indignorance!
The Green Goblin - 12" of dobsonian excellence!
The PortaBowl-a $100 4.5" f/8 ball-scope YOU can build!
Eero2-a 6" f/5 ball-scope you probably can't.
Mike I. Jones
Reged: 07/02/06
Loc: Fort Worth TX
Let's respect the OP first. Dan, what's your mirror EFL, diagonal distance inside focus, and desired FOV diameter? I'll ZEMAX up your system then do Rob's.
I looked at that website and am thoroughly unconvinced. His very first point is bogus - it's a lot easier to make flat parts very flat on a continuous ring polisher than to make spheres and conics. Been done there that - a guy that knows how to set, tool and weight his CP can pull 1/10 to 1/20 wave parts off all day, right to the edges. I ain't buyin' no 3 wave diagonal! Back in a while.
gaz-in
Reged: 12/17/07
Cool Mike her are the stats:
14 inch mirror 70.6 inch focal length 10.85 inch distance from the center of the secondary to the focus point. .5 100% illuminated immage size.
From my (admittedly crude) calculations I think I need a 2.6 inch secondary.
Mark Harry
Reged: 09/05/05
Loc: Northeast
Do 'em one at a time, with conventional polisher!!!!!!!
 Mark
