pizzaboy71
Reged: 12/27/06
setting up a cg5 gt to autoguide with hc ?
      #3195892 - 07/02/09 08:34 PM
have the cables hook up to the handset and running to my usb ..have ascom drivers, but it don't show a cg5 gt mount to select from , and running newest phd with a Phillis web cam..I just can not get phd to connect to the mount. Its going to be clear tonight and any help would be great..
mclewis1
Thread Killer
Reged: 02/25/06
Loc: New Brunswick, Canada
Re: setting up a cg5 gt to autoguide with hc ? new [Re: pizzaboy71]
      #3195918 - 07/02/09 08:59 PM
Along with the ASCOM platform you also need the Celestron mount driver. Then you should be able to select Celestron Scope Driver in the ASCOM Telescope Chooser dialog box that comes up when you press Connect to Telescope within PHD (the button with the telescope on it).
pizzaboy71
Reged: 12/27/06
Re: setting up a cg5 gt to autoguide with hc ? new [Re: mclewis1]
      #3199171 - 07/04/09 05:59 PM
ok got the celestron scope driver ,but when you go to properties to select mount there is no cg5 ast to select or do you select a different name mount to work with the cg5 ast mount ? some where i read you dont even need to select the mount type ? is this true ?
mclewis1
Thread Killer
Reged: 02/25/06
      #3199240 - 07/04/09 06:50 PM
Assuming the ASCOM platform and Celestron Scope driver have been installed properly when you press "Connect To Telescope" in PHD you will get a diaglog box called ASCOM Telescope Chooser. Choose "Celestron Telescopes" (in PHD 1.6) or "Celestron Scope Driver" (in PHD 1.1) in the drop down menu. The Properties button will then bring up a Celestron Driver Setup where you can choose the scope/mount type (I use the first CG-5 on the list "Advanced C5-SGT").
pizzaboy71
Reged: 12/27/06
      #3199694 - 07/05/09 01:32 AM
thanks i got, i love everyone support thank you mark
31 registered and 35 anonymous users are browsing this forum.
