John K
Reged: 12/26/05
Loc: Vernon BC Canada
Obsession Owners Help Please new
      #3195825 - 07/02/09 08:03 PM
Hi
I just received a set of UTA clamps for my clone scope.I just need some shots of the clamps so I can see how it assembles.What parts are captive?I didn't get the metal ring that sits on the top of Plywood.What is it exactly so I can try and find one locally.
Thank you
John
RASC Member (Okanagan)
Home built 15"F5 Obsession clone
Bushnell 76mm Modified Dob (Little Richie)
Celestron Skymaster 15x70
Howie Glatter laser pointer/Blug
Astronomik filters OIII UHC
Televue Eyepieces 31mmNagler,32mmPL,15mmPL,13mm Ethos,11mm PL,2X Barlow
10mm Speers Waler
Jim Moscheck
Reged: 01/08/07
Loc: Under the SE Michigan lightdom...
Re: Obsession Owners Help Please new [Re: John K]
      #3195937 - 07/02/09 09:08 PM Attachment (25 downloads)
Here is the only pic I have of my scope without the shroud covering the clamps, and I needed to crop it quite a bit so I'm sorry for the poor quality.
I didn't like the pin going through the end hole and instead used a washer and nut threaded all the way to the ends of the thread which then sits on the inside of the ring to keep the screw in position. My friend who was helping me out while I was building my scope showed me this and it works great. An added benefit is that I can tighten up the clamp for transport.
Jim Moscheck
Ford Amateur Astronomy Club
ATM truss dob
Stevens 14.5" f4.3
"A mind is like a parachute. It doesn't work if it's not open." - Frank Zappa
Edited by Jim Moscheck (07/02/09 09:11 PM)
cuzimthedad
Just Be Cuz
Reged: 04/09/06
Loc: Sonoma, Northern California
Re: Obsession Owners Help Please new [Re: Jim Moscheck]
      #3196029 - 07/02/09 10:05 PM Attachment (14 downloads)
Hi John. Here are a couple pics of the clamp assembly and the hole the pin goes through with the metal base on top (?) and the tube holder below. The base that keeps the pin lock from scratching the plywood is pressed in and should be available from a hardware store or cabinet shop supply. The terminology is mine. Sorry.
Dan
20" f/5 Obsession
Antares 1529
TV102
Various Naglers, Ethos, UO Orthos and TV Plossls
The Off Fisher Lane Irregulars
cuzimthedad
Just Be Cuz
Reged: 04/09/06
Re: Obsession Owners Help Please new [Re: cuzimthedad]
      #3196033 - 07/02/09 10:07 PM Attachment (17 downloads)
Here is the clamp assembly
Dan
20" f/5 Obsession
Antares 1529
TV102
John K
Reged: 12/26/05
      #3196052 - 07/02/09 10:17 PM
Hi My little pins that attach to the clamp are not attached where do you attach them?
Sorry for all the questions I am in the process of putting this on the UTA.
10mm Speers Waler
cuzimthedad
Just Be Cuz
Reged: 04/09/06
      #3196297 - 07/03/09 01:14 AM
The keeper pin is on a string that is attached between the tube holder and the lower uta ring as shown in the first pic.
Dan
20" f/5 Obsession
Antares 1529
TV102
John K
Reged: 12/26/05
Re: Obsession Owners Help Please [Re: cuzimthedad]
      #3196394 - 07/03/09 02:58 AM
Thanks for your help! I have it up and running now.I just had to cut the extra length off the center pin to get it cam properly.
10mm Speers Waler
9 registered and 10 anonymous users are browsing this forum.
