mike bacanin
Reged: 03/19/07
Loc: united kingdom
I have just re-acquired a pair of 12mm pentax orthos.
i have a denk std with SCD holders in Tak 128.
i've just viewed the moon and whereas i normally have no problem merging the images, i seemed to have a little trouble.
does anyone use .965 inch eyepieces? normally these ep's are not a perfect fit in their 1.25 adapters and get slightly offset when the adapter locking screw is tightened.
am i right this can decenter the eyepieces in the binoviewer and cause merging issues?
also i just tried a pair of 6mm 1.25 inch orthos and just cannot merge at x260
are these too small in fl?
mike
Covey32
Reged: 12/09/04
Loc: Georgia
For many people, merging issues begin at around 10mm and below. In my case I get better results overall (and no merging problems) by keeping my shortest focal length eyepieces to 10mm and using a barlow or corrector ahead of the binoviewer in the optical train.
-------------------- Hank
12.5" Mag1 Portaball
Orion 120mm F5 Refractor
Skywatcher 120ED F7.5 Refractor
1982 Celestron C8 Orange tube
Celestron ED80 Refractor with Lunt 50mm HA
mike bacanin
Reged: 03/19/07
Loc: united kingdom
i have an ocs on the diagonal giving focal lengths of 1456mm and 2600mm with powerswitch, so yes i agree that 10mm or longer is good. anyone comment on the .965 issue?
mike
suburbanskies
Reged: 12/18/04
Loc: New Jersey, USA
Regarding the 0.965" to 1 1/4" adapter issue, your reasoning seems to make sense, Mike.
Frankly even with 1 1/4" eps in a Baader V binoviewer, I have to rotate the eps in order to get a good merge. A good merge always seems to require some fiddling, at least in my experience. Try backing off on the set screw and rotating. Hopefully you can find the sweet spot...
I like the idea of 12mm Pentax SMC orthos binoviewed. One day I hope to try a pair of 18mm Pentax orthos myself!
Mark
mike bacanin
Reged: 03/19/07
Loc: united kingdom
Hi Mark,
what i have done is use an even paper shim to try to centre the eyepieces in the adapter, that should centre them fairly well. there is a noticeable offset if you simply put the eyepiece in without any packing and just tighten the adapter setscrew. i suppose ideally a custom machined adapter with friction fit for the eyepiece would ensure perfect centring.
mike
walt99
Reged: 08/23/08
Hi Mike,
If you ask him, Russ will send you a pdf with simple instructions for collimating the SCD's.
I found that a little tweaking with the object in view works best.
You can email him through the Denk website, But I will PM his email address.
Good seeing, Walt
suburbanskies
Reged: 12/18/04
Mike, if you can see a noticeable offset I think you can be quite sure that that's your problem. It'd be great if your paper idea works. If it does not and you are willing to spend some money, try obtaining Takahashi 0.965" collet holders and having a machinist attach it to a 1.25" sleeve. I've seen it done and looks great (and presumably works well), but pricey like your custom adapter idea.
Now that I think of it, finding a good 0.965"/1.25" adapter is one of the reasons why I've held off on finding a pair of 18mm SMCs!
Mark
mike bacanin
Reged: 03/19/07
Loc: united kingdom
I just redid the adapter shimming by using pro grade masking tape. i applied a single even layer around the inside of the adapters,resuling in a perfect friction fit for the pentax's. i noticed last night that the adapter setscrews fouled on the denk ep holders, so i've retapped the setscrew holes for 4mm metric stainless hex head grub screws, here's the result.
mike
suburbanskies
Reged: 12/18/04
Looks very nice and tidy. Always great to find a simple, inexpensive solution! Let us know how your first light goes...
Mark
mike bacanin
Reged: 03/19/07
Loc: united kingdom
Hi Mark
just did a daylight test on some very distant trees, detail was very impressive. hope the night performance is good!
suburbanskies
Reged: 12/18/04
I bet it'll be just as good at night. Problem solved
mike bacanin
Reged: 03/19/07
Loc: united kingdom
Thanks Mark! I'll post an update when we get a clear night.
ps, i have a pair of 16mm zeiss jenas on the way, should be really nice to bino,
roadi
Reged: 08/18/07
Loc: Denmark
Mark
Second that!
I have a Baader/Celestron unit with 60 degr bent and with the units original EP collets I never manage to get the pictures merged when EP much under 32mm used. Until I modified it with a pair of Takahashi collets! The problem is solved but stil some litle problems with 8mm and under but as Mark says loosen the clamps and a litle fidling will do it
In short.. I believe the slightest off centering or tilt of the EP will become evident when short focus EP are used, 9mm > - and the shorter the F-ratio of the scope the worse it'l be IME.
When using 24.5 mm EP you'll have slop two times.. between the EP itself and the adapter and between the adapter and collet wich isn't favourable!
-------------------- Regards Rodi
60mm Polarex, Sky90, µ210, SKW150 Binoscope
Vixen GpDx, Astro5, LX200
Modified Baader/Celestron Binoviewer.
Panoptics, Tak LE's, Baader Ortho's, Antares Erfle's
Couple of diagonals..
Edited by roadi (07/05/09 05:26 AM)
suburbanskies
Reged: 12/18/04
12mm Pentax and 16mm Jena orthos...a sweet line up, indeed!
mike bacanin
Reged: 03/19/07
Loc: united kingdom
I just received the collimating instructions from Russ for the SCD's. A critical check has just shown that one eyepiece was producing a tiny degree of horizontal error in the right side. this pretty much vanished with a slight rotation of the eyepiece. i actually think the difference was so small it may not be noticeable. i suppose considering the potential issues with these .965 inch ep's in adapters, that's a good result. I'll certainly try to make sure the 16mm zeiss pair are shimmed carefully,although i suspect the longer focal length should help.
rogerandgarf
Reged: 06/01/05
Loc: Arlington, Wa
Would either of these .965 adapters solve your problem?
http://www.alpineastro.com/eyepiece_adapters/eyepiece_adapters.htm#Reducers
http://www.agenaastro.com/0-965-Telescope-Adapter-s/201.htm
-------------------- Roger Johnson
18"F4.2 Goto Starmaster
12"Antares Dob
Televue Genesis
5" Mak
ZAOIIs w/barlow
Denk II BVs/x switch
Swarovski, Leica, Canon IS,
Fuji, Obie bins/Unimount
mike bacanin
Reged: 03/19/07
Loc: united kingdom
Hi Roger, thanks for the link. i have sorted the problem with careful shimming and retapping for a hidden grub screw instead of the set screw. the adapter in first link is very similar to what i have, you would still have the same problem of the eyepiece being a slack fit in the adapter.
rogerandgarf
Reged: 06/01/05
Loc: Arlington, Wa
Mike, I was left with the same impression despite the product description that accompanied the Baader adapter.
However, the adapter that Agena stocks (temporarily out) attracted my attention in that it has a brass compression fitting, the kind we are all used to seeing in the 2"/1.25" adapters. I would think that would hold more promise.
I am still at a loss sometimes to explain why a more precise adapter isn't readily available, especially given the $$ that many of the .965 oculars command.
Good luck in your efforts!
12"Antares Dob
Televue Genesis
5" Mak
ZAOIIs w/barlow
mike bacanin
Reged: 03/19/07
Loc: united kingdom
Roger,
the answer i think, is a self centring collet type adapter similar to the 1.25 inch ep holder on my Tak 128. however i've searched and cannot find a .965 inch version.
crazyqban
Reged: 12/16/08
Loc: Miami, Florida
Mike, I use eye guards the are made by Orion on all of my bino eyepieces and I believe that they help out immensely. You might want to consider giving them a try. Another benefit is that they block out stray light...
Sergio
-------------------- Takahashi TOA-130F (for sale) / Takahashi Sky 90 / PST-DS
Takahashi Teegul Alt-Az / Takahashi EM-200 USDII (for sale)
Zeiss Abbe II's pair / AP/Baader Mark V
Televue 3mm-6mm Nagler Zoom / 41mm Panoptic / Two 24mm Panoptics
Two 15mm Panoptics / Two 13mm Nagler Type 6 / Pentax 14mm XL
