JimmyStar
journeyman
Reged: 05/26/09
Collimation problem on a LB16 new
      #3196523 - 07/03/09 06:57 AM
Hi !
First of all, sorry for my english !
I'm using the catseye collimation tools on my lightbridge 16".
I follow all the steps (center the secondary under the focuser, center the primary in the secondary, then center the primary). My focuser is, as well, well centered in the tube
The problem comes when i use the auto-collimator. When i look into it, i see the dark zone i'm suppose to, but when i do the adjustement to get all the triangles together, my secondary goes in that position :
http://img510.imageshack.us/i/secondarymovelj1.jpg/
Everything is well centered but it seems that i loose some light here
Any ideas ?
Thx a lot !
Renaud
http://astro400.blogspot.com
Asbytec
Reged: 08/08/07
Loc: La Union, PI
Re: Collimation problem on a LB16 new [Re: JimmyStar]
      #3196592 - 07/03/09 08:18 AM
It's centered until you use the auto collimator, you say. From the image, it looks as though your diagonal might have to be rotated a bit or moved "up" a bit. But, if you rotate it and use the auto collimator, then you'll likely rotate it back to that location. Maybe a bit of movement "up" might actually "center" it a little better.
I don't use an auto collimator, so hopefully someone who has experience with them will reply. But, from an "eyeball" point of view..."up" might seem the way to go.
12" Zhumell
La Union, Philippines
calibos
Reged: 11/18/07
Loc: Ireland
Re: Collimation problem on a LB16 new [Re: Asbytec]
      #3196601 - 07/03/09 08:24 AM
Looks like your focuser might not be square with the tube or your spider is not centred, forcing you to tilt the secondary too much??
Keith D.
Knightrider - 16" Meade Lightbridge - See Here
Moonlite CR Focusser with Rigel motofocus and Filterslide (2" Orion Variable Polorizer,UHC & H-Beta, Lumicon OIII)
Stellarvue F80M2 80mm Finder
Dewbuster and DewNot Dew Control
Servocat & SkyCommander
Howie Glatter Holograhic Collimator and Blug
Baader Hyperion 21/32mm,17mm,13mm,8mm,5mm,3.5mm EP
JimmyStar
journeyman
Reged: 05/26/09
Re: Collimation problem on a LB16 new [Re: calibos]
      #3196606 - 07/03/09 08:29 AM
To correct with the auto collimator, i have to rotate the secondary(clockwise if you're in the front of the tube) that's why i've got this black gap on the seconday. I don't understand why the collimation is ok on the autocolimator with this misalignement of the secondary :/
panhard
Mongo
Reged: 01/20/08
Loc: Markham Ontario Canada
      #3196699 - 07/03/09 09:26 AM
Welcome Renaud your English is just fine.
Jason D
Reged: 10/21/06
Loc: California
      #3196805 - 07/03/09 10:27 AM
Jimmy, centering/rounding the secondary mirror under the focuser is accomplished by the sight-tube -- not the autocollimator. Stacking reflections with the autocollimator is independent of the secondary mirror position under the focuser. Check the following animation. Each frame shows good axial alignment but for a different secondary mirror position. Also refer to the following link
Questions:
1- Do you stack the autocollimator reflections by only adjusting the secondary mirror?
2- Do you iterate between the autocollimator and the cheshire until both show good alignment?
3- Do you use CDP (explained in Catseye documentation and website)?
Jason
XT10 classic with premium optics
Tri-knob CR2 with compression rings
Round Table Platform
4.5" StarBlast
6" StarBlast6
TV EPs
JimmyStar
journeyman
Reged: 05/26/09
Re: Collimation problem on a LB16 new [Re: Jason D]
      #3197064 - 07/03/09 01:00 PM
Hi jason !
thx for your replies
I do center the secondary with the ajustable sight tube from catseye. In fact I do all the steps until the autocolimator step. Then if I stack all the triangle, my secondary goes wrong (as the picture show) and it's not well centered under the focuser anymore :/
I just move the secondary in this step. If i use the cheshire in this part, i just go in circles because the autocolimator makes me move the secondary (as shown in the picture) and in the cheshire I have nothing to do except put it in the first place lol
Jason D
Reged: 10/21/06
Loc: California
      #3197073 - 07/03/09 01:17 PM
Jimmy,
If you use the sight-tube to achieve good collimation and good secondary alignment then using the autocollimator and the cheshire should only "fine" tune collimation with small adjustment. It is not clear to mewhy you are dramatically adjusting your secondary mirror after collimating your scope with the sight-tube – this should not be the case.
Your photo suggests a tilt/rotate error. To fix it, you will have to rotate your mirror in such a way to move the top secondary mirror edge as shown in your photo closer to you and the bottom secondary mirror edge away from you. The amount of rotate has to be SMALL -- just a touch. Then only use the secondary mirror adjust setscrews to stack the autocollimator reflections. Do not forget to check your final setup with a cheshire. If it is off, then iterate between the cheshire (by only adjusting the primary mirror) and the autocollimator (by only adjusting the secondary mirror) until both tools show good collimation.
Do you have the XL or XLK version of the autocollimator?
Jason
4.5" StarBlast
6" StarBlast6
TV EPs
bbasiaga
Reged: 05/10/06
      #3197081 - 07/03/09 01:19 PM
Does the secondary allow tilt adjustments? I have the cat's eye set as well. I rotate the secondary around its axis until the cross hairs of my sight tube are centered in the hole in the cat's eye triangular center mark. Then I use the cheshire and center the triangle as described in the instructions. At this point the autocolimator usually has the triangles all in there, but spread out. My secondary has four screws I can use to tilt it without rotating it to get the trinagles to stack up. I usually don't need more than two iterations of cheshire, autocollimator, cheshire... to get everything all lined up.
Hopefully this helps. Sometimes just hearing the procedure in someone else's words can help.
-Brian
Vixen 80EDSF
Stellarvue 102ED2
Orion Atlas 11 EQ-G
15" Astrosystems Telekit w/ Discovery Optics
Lust for something Larger
Lust for something Larger than that
Past Lovelies:
Oberwerk 20x100 binocs
Meade AR5
Meade LX10 8" SCT
All sold to a good home
Jason D
Reged: 10/21/06
Loc: California
      #3197099 - 07/03/09 01:29 PM Attachment (9 downloads)
Hi Keith,
Actually, it is possible to determine whether the issue is due to tilt/rotate or misaligned focuser/spider_vanes. Check attachment.
Jason
4.5" StarBlast
6" StarBlast6
TV EPs
JimmyStar
journeyman
Reged: 05/26/09
      #3197181 - 07/03/09 02:13 PM
I found your last attachement very usefull !
So my problem is a rotate problem. But i find the fact that the triangle only stack when the secondary is in that position
Asbytec
Reged: 08/08/07
Loc: La Union, PI
Re: Collimation problem on a LB16 [Re: JimmyStar]
      #3197612 - 07/03/09 07:42 PM
Jimmy, as Calibos mentioned, it appears your focuser might not be truly square. Start from scratch to square your focuser once more.
12" Zhumell
Jason D
Reged: 10/21/06
Loc: California
      #3197906 - 07/04/09 12:07 AM
Jimmy, as I mentioned in an earlier post, the autocollimator has nothing to do with the secondary mirror alignment under the focuser. That is, you will be able to stack all reflections of the autocollimator perfectly for different secondary mirror alignments. I pulled out the following animations from the thread I referred to in an earlier post. Every frame represents a good axial alignment yet each frame includes a different secondary mirror alignment.
Jason
4.5" StarBlast
6" StarBlast6
TV EPs
JimmyStar
journeyman
Reged: 05/26/09
      #3198564 - 07/04/09 12:01 PM
I think I might have found where the problem comes from...
It looks like the center triangle...is not centered !
here's what I did (tell me if something is not logical there)
i very precisely centered the secondary under the focuser, and the primary reflexion into it with the sight-tube. then i took...a laser !
ok so theoretically the laser spot might be right in the middle of the triangle now (am I wrong ? don't think so). and guess what. The spot is landing in one of the corner of the triangle (my laser is well centered, if i rotate it in the focuser, it's position doesn't move on the primary.)
ok, let's continue anyway...
Still with the laser, i'm centering the primary (this step is normally done with the blackcat cheshire.)
Now last step, if i look in the auto-colimator, i can see all the ghost images really close, and a minor secondary ajustement allow to stake the triangle and only one of it's ghost (of course not the 4 of them, cause the spot is not well centered, am i wrong again ?)
after that, i can check with the sight tube and the laser (and auto-colimator) everything's in place...
what do you think ? Did a miss something there or am i right ?
Renaud
Starman1
Vendor - Scope City
Reged: 06/24/03
Loc: Los Angeles
      #3198624 - 07/04/09 12:28 PM
Renaud
This presumes the laser is perfectly collimated and that you have perfectly centered everything else, which is highly unlikely by eye. So I don't think this is a test of the centering of the triangle on the primary.
Try measuring the distance from the center of the triangle to the edge of the mirror in several directions. If it's as close to center as you can read with a tape measure, then the centermark IS centered and the problem is simply miscollimation.
Don Pensack
12.5" Truss Dob, 5" Maksutov, Fujinon Binos
Sustaining Lifetime IDA member
Jason D
Reged: 10/21/06
Loc: California
Re: Collimation problem on a LB16 new [Re: Starman1]
      #3198744 - 07/04/09 01:43 PM
Jimmy,
I concur with Don. I do not believe your approach in assessing the center mark location is adequate.
There is a much simpler approach. You do have the Catseye tools; therefore, it is fair to assume you still have the transparency template that comes with the tools. Use that template to assess the placement of your center mark.
By the way, all ghost reflections can still be stacked precisely even if the center mark is slightly off.
I still strongly believe your problem is simply a rotate/tilt issue. Based on your drawing, the discrepancy between the primary and secondary mirror edges it too large to be contributed to a “slightly” off-center mark. The center mark will have to be an inch or so off to create the scenario you have described which I doubt to be the case.
Jason
4.5" StarBlast
6" StarBlast6
TV EPs
5 registered and 5 anonymous users are browsing this forum.
Moderator:  Don W, werewolf6977, Jason B
