nobbygon
Reged: 03/20/09
Loc: Australia
EQ6 Pro power solution new
      #3192333 - 07/01/09 04:57 AM
I just bought a new skywatcher EQ6 PRO goto mount today and i noticed it doesn't come with a power supply. The power cable it did come with had a cigarette lighter power adapter for a car on it.
I was wondering what everyone else uses for a power supply. Do you have to buy a new power cord with it??
Cheers, Angus
neptun2
Reged: 03/04/07
Loc: Bulgaria
Re: EQ6 Pro power solution new [Re: nobbygon]
      #3192337 - 07/01/09 05:05 AM
I use the power cord which came with my heq5 pro in combination with Skywatcher 17Ah power tank. The peak power cosumption of this mounts is around 2 ampers so 17Ah gives me enough power for the night.
Skywatcher Explorer 200P 8" f5 newtonian reflector
HEQ5 Pro Synscan Equatorial mount
Nikon Action 12x50 , Nikon D5000
Nagler type 6 11mm , Pentax XW 7mm , Televue 2x barlow 1.25"
Reged: 07/06/07
      #3192465 - 07/01/09 07:58 AM
Cheers, Angus
Most popular are the jump start battery packs from automotive and discount stores. Look in Walmart in the U.S. and Asda in the UK.
Uncle Rod
Rod's New Book:
Choosing and Using a New CAT
Available now!
Kenny2004
Reged: 08/17/04
Loc: Toronto, Canada
Re: EQ6 Pro power solution new [Re: rmollise]
      #3192584 - 07/01/09 09:14 AM
You could use an AC adapter. Ie. 2.1+Amps at 12V-13v with a tip of I believe 2.1mm with a "+" center at the tip.
Skywatcher Black Diamond 80ED /w HEQ5 Pro
Celestron 8" SCT /w XLT
Celestron CPC800XLT
Meade DSI-C on a homebrew guidescope
ATik 314L+
Philips SPC900NC Webcam
mewmartigan
Reged: 07/02/08
Re: EQ6 Pro power solution new [Re: Kenny2004]
      #3192784 - 07/01/09 11:17 AM
I use the 7Ah Celestron Power Tank. It works great and has two "cigarette lighter" ports and a few others, along with a red light and very bright spotlight.
Marcus
Orion XX12
8" LX200R
ST80 guidescope
Atlas EQ-G w/EQMOD
Canon XSi unmodded
Astronomik CLS clip-in filter
Meade DSI Pro
nobbygon
Reged: 03/20/09
Loc: Australia
Re: EQ6 Pro power solution new [Re: mewmartigan]
      #3194700 - 07/02/09 09:42 AM
Thanks for all your help. I ended up getting a 12V DC 10A jump start battery from a local hardwear store. Works fine with my mount.
Cheers, Angus
tommyhawk13
Reged: 09/28/07
Loc: Jacksonville, Fl
      #3195763 - 07/02/09 07:31 PM
I've been using a Harbor Freight jump box without issues for all nighters, except when I add the dew-zapper.
I'm going to go with a deep cycle marine battery in the future, but for now I am using a small spare car battery just for the dew-zapper.
Meade Starfinder 8,Meade SN-8 OTA, Orion Atlas, and a handfull of film cameras
dvb
different Syndrome.
Reged: 06/18/05
Re: EQ6 Pro power solution new [Re: tommyhawk13]
      #3195807 - 07/02/09 07:53 PM
I have the various power supplies mentioned above, but when I am at home I prefer the AC "Wall wart" power supply. I think it is available through Orion.
"But seeing through a telescope is 50% vision and 50% imagination." - Chet Raymo
Skywatcher 10" f/4.7 Newt on Matilda
Celestron CF 9.25"
Vixen CF 8" f/4 Newt
Meade 8" SN f/4
Celestron C6 SCT
Skywatcher ED100
Skywatcher ED80
EQ6 Pro "Matilda"
AT Voyager
Canon 15x50is
Mallincam HyperColor Plus
John J
Reged: 11/05/07
Loc: Sioux Falls SD
Re: EQ6 Pro power solution [Re: nobbygon]
      #3197713 - 07/03/09 09:03 PM
If you want reliable AC power take a look at one of these.
http://www.mpja.com/prodinfo.asp?number=7722+PS
Things are looking up!
http://inskysd.org/gallery/
My Flicker Astro Site
3 registered and 9 anonymous users are browsing this forum.
