Privacy Policy |
Please read our Terms
of Service | Signup and
Cary
Vendor (Optic Wave Labs)
Reged: 07/07/04
Loc: Rancho Cordova, CA
Hello,
I'm looking for a layout / ZEMAX prescription for a Cass test setup using a long focus parabola. Any help here? I know there are a couple of ZEMAX brainiacs that could spit this out in a second.
-------------------- Cary Chleborad
http://www.opticwavelabs.com
DAVIDG
Reged: 12/02/04
Loc: Hockessin, De
Are you trying the test the secondary or the complete scope? Also what size cass and what size parabola and what is it focal length ?
- Dave
-------------------- Homemade 'scopes 8"f/7,6" f/5", 6"f/4, 4.25" Schief. 60mm Coronagraph,60mm H-alpha system, 4.25" White-light Solar Newtonian,solar spectroscope, 4.5" f/16 Schupmann Medial refractor, 14 Stellafane awards 7 in optics
Engineering = Taking what you have and making what you need.
Cary
Reged: 07/07/04
Whole scope....
DAVIDG
Reged: 12/02/04
Loc: Hockessin, De
All you do is put a small light, like a LED at the focus of the parabola. The light coming off the parabola is now parallel, at least in theory. You then aim the cass. at the parabola and either knife or ronchi test at the focus of the cass. The parabola has to be of very good quality, since any error in it will also add into any error in the telescope under test. The parabola should be as large or larger then the 'scope your testing but if it's smaller you can move the cass. so the edges then the middle are illuminated and get a good feel for thr over all correction.
- Dave
Cary
Reged: 07/07/04
As I mentioned before, I'm looking for help getting the test into ZEMAX. Not just theory.
Ed Jones
Reged: 04/06/04
Loc: Sin-sin-atti
What are you looking to do specifically?
-------------------- Ed Jones
Mike I. Jones
Reged: 07/02/06
Loc: Fort Worth TX
Something like....this?
12.5" f/4 parabola, fed at its focal point by a single-mode fiber with an LED at the other end. Cassegrain, Mak, refractor, or anything else can now be placed in collimated light for testing.
Ehh? Mike
Mike I. Jones
Reged: 07/02/06
Loc: Fort Worth TX
The ZMX file is attached. Mike
Cary
Reged: 07/07/04
I had a feeling Mike would come up with it. Thanks!
Mark Harry
Reged: 09/05/05
Loc: Northeast
Nothing of "theory" about it. Basic idea, it's a Newt aimed at a Cass. You have to validate the quality of the Newt to a good high degree, and the F/D doesn't matter. Dave was correct. Carrying it a step deeper- What -DOES- matter, is the quantification accuracy desired!!!!!!!! That requires iterations that ZEMAX can do easily. Along with our 2 'MAX designers.
(Did I get it right, Mike? If not just tell me to shut-up.) Mark
-------------------- So many projects, so little time!
3 registered and 8 anonymous users are browsing this forum.
Moderator: Don W, Mike I. Jones
