Pedestal
Reged: 03/11/06
Loc: Smoggy Bottom, Baytown,Texas
Smoggy gets a mod new
      #3187174 - 06/28/09 02:36 PM Attachment (20 downloads)
Every since I built my little observatory, I've been plagued by "drips" when it rains. So I decided to fix that, as it seems we are in a long, dry spell.
Took the old slot doors off an then made a batch of these:
Hubert
www.smoggybottom.org
Pedestal
Reged: 03/11/06
Re: Smoggy gets a mod new [Re: Pedestal]
      #3187176 - 06/28/09 02:37 PM Attachment (16 downloads)
The wooden arcs form a raise "lip" around the slot opening:
Hubert
Pedestal
Reged: 03/11/06
      #3187179 - 06/28/09 02:39 PM Attachment (14 downloads)
Another look at the raised lip
Hubert
Pedestal
Reged: 03/11/06
      #3187181 - 06/28/09 02:40 PM Attachment (12 downloads)
The slot doors fit down over raised lip
Hubert
Pedestal
Reged: 03/11/06
      #3187183 - 06/28/09 02:43 PM Attachment (12 downloads)
The upper door folds down overlapping the lower door about 4", and also overlaps the side. I uses solid plastic piano type hinges on the lids.
Hubert
Pedestal
Reged: 03/11/06
      #3187186 - 06/28/09 02:44 PM
I think a new paint job is gonna be done, soon as I recover...
Hubert
4Texans
Reged: 12/08/07
Loc: TX
      #3187878 - 06/28/09 10:26 PM
I understand the recovery part with the heat wave we're having.
Meade LXD-75 8" S/N
Meade 826C
Tal 100R
7x50 binoculars
quantumac
Reged: 12/17/07
Re: Smoggy gets a mod new [Re: 4Texans]
      #3187933 - 06/28/09 11:09 PM
Suggestion: might want to check your work with a garden hose, just to make sure everything is sealed properly. Best to know before Mother Nature discovers any problems for you.
Scope: Meade 10" LX200R
Guide/Planetary Camera: Imaging Source DBK41AF02.AS
DSO Camera: QHY8
Guide Hardware: Celestron OAG, Shoestring Astronomy GPUSB
Software: Mac OS X, Starry Night Pro, Nebulosity, PHD Guiding, PixInsight, Astro IIDC. No Windows anything.
Chris SchroederModerator
Reged: 12/11/04
Loc: N.E. WI Sky Glow
Re: Smoggy gets a mod new [Re: quantumac]
      #3188372 - 06/29/09 08:28 AM
Looks great Hubert, I would second the garden hose idea as well.
Chris
Mallincam Color Hyper Plus
10" DSH with SC DSC, CPC 800 XLT
M110 Doublet ED, AT 102Achro, ZS80FD 10th Anniv, ZS66SD, PST
CG5-AGT, EZ-Touch, Voyager
POD XL3 http://POD.SchroederCity.com
Pedestal
Reged: 03/11/06
Re: Smoggy gets a mod new [Re: Chris Schroeder]
      #3189306 - 06/29/09 04:56 PM
Ya know, I tried the garden hose thing, and the grass reached up and grabbed the hose out of my hand! I barely managed to get the valve turned off...
Hubert
hm insulators
Reged: 01/22/07
      #3189336 - 06/29/09 05:14 PM
Pedestal
Reged: 03/11/06
Re: Smoggy gets a mod new [Re: hm insulators]
      #3198897 - 07/04/09 03:14 PM Attachment (5 downloads)
Got the doors finished, and repainted the whole obs with the white RV paint. However, since my weather station is on the fritz, I have not had a chance to check temps. Anyway, here is a couple of shots with the lids open.
Hubert
Pedestal
Reged: 03/11/06
      #3198904 - 07/04/09 03:16 PM Attachment (6 downloads)
I also changed the opening mechanism so I can open the lids standing on the floor, instead of having to use a stool.
Hubert
csa/montanaModerator
Den Mother
Reged: 05/14/05
Loc: montana
Re: Smoggy gets a mod [Re: Pedestal]
      #3198990 - 07/04/09 04:12 PM
Hubert, Outstanding job! That really looks nice; & it's so much better for you opening it up!
Carol
AstroTech 16" Dob (Thanks ASTRONOMICS!)
Vixen 80MF/AstroTech Voyager
Masuyama's 7.5, 15, 25W, 35mm,
Pentaxes; 5XW, 7XL, 10XW.
14mm Meade 4000 UWA
TV Panoptics; 22, 35
DreamCatcher Dobservatory, #2
AlienFirstClass
Reged: 02/13/09
Re: Smoggy gets a mod new [Re: csa/montana]
      #3200364 - 07/05/09 01:22 PM
The doors on the dome...how have they worked out for you?
I understand that you are adding the lips to the dome but you apparently are not changing the doors themselves.
How did they seal before the modifications?
texag
Reged: 05/24/07
Loc: SE Texas
      #3200502 - 07/05/09 02:49 PM Attachment (4 downloads)
Hubert.
I hope the elastomeric paint on the building walls helps moderate the temperatures in your observatory. I started monitoring the temperatures in my dome on Thursday. Friday morning I painted the walls with the elastomeric paint. The daily high temperature is now lower in the observatory than the recorded high here in town.
Thursday (unpainted walls) Observatory high: 98.4 League City high: 98
Friday (painted walls) Observatory high: 98.1 League City high: 100
Saturday Observatory high: 97.5 League City high: 99
Kevin
Pedestal
Reged: 03/11/06
      #3200686 - 07/05/09 05:07 PM
Yeah, Carol, climbing up a stepstool, trying to use the scope for balance without putting any pressure on it wa not fun!
Hubert
Pedestal
Reged: 03/11/06
Re: Smoggy gets a mod new [Re: AlienFirstClass]
      #3200707 - 07/05/09 05:19 PM
Although they look the same, the doors are new. Since I was going to the trouble, I also made the slot about 6" longer, as I found the original slot a bit "tight" at zenith. There was a low "lip" originally, and the old doors laid down flat on top of the lip. I probably could have got by just making new doors with a lip, but decided to just make sure. Basically a case of my inadequate design from the getgo.
Hubert
Pedestal
Reged: 03/11/06
Re: Smoggy gets a mod new [Re: texag]
      #3200715 - 07/05/09 05:24 PM
Kevin, thanks for the info, it looks like it's working for you. I should have my weather staion back in a few days, and can start monitoring.
(I really like your dome!)
Hubert
AlienFirstClass
Reged: 02/13/09
      #3201109 - 07/05/09 10:01 PM
Thought so...I figured the doors would change.
As for it being a case of inadequate design...no my friend...it is a case of ONGOING design. ;<)
In my experience, one is never done tweaking a design to make it even better.
5 registered and 3 anonymous users are browsing this forum.
Moderator:  Chris Schroeder, csa/montana
